- Is my MPU9150 9DOF dead? (Only shows 65535)
- Parallel GPIO to DMA with non-continuous external clock
- Teensy, riding along in my autombile....
- Teensy 3.1 Makefile problems
- Arduino v Teensy float and double
- Is there a limit to the number of HW Interrupts?
- analogWriteResolution, analogWriteFrequency and PIT frequency questions
- WS2812 LEDs: Merging data and power lines?
- direct port manipulation help
- Did I break it?
- Teensy + ADS129x ADC + SD card
- driver troubles
- Teensy 3.1 / MS5637 Pressure Sensor / Data Logging / SD Card / Latency
- Teensy Analog Output / Audio Library - More then 2 Outputs?
- How can you determine what caused a watchdog reset?
- How to reset the USB connection so Windows driver will reconnect?
- ADC interrupts and channels selection
- Teensy USB MIDI - expanding PrintIncoming example
- Trying to get Audio Shield FFT working with Teensy 3.1 but all bins show 0!
- Dumb cell phone wants to be a Teensy 3?
- USB-MIDI - delay when processing commands
- Problem with external button
- problem bit banging using digitalPinToBitMask et. al.
- Teensy 3.1 will not go back into programming mode!!! Help :(
- Bug in mk20dx128.h, FTM_SC_PS defined incorrectly
- Porting Mega Timers to Teensy 3.1
- Teensy Joystick Enumeration?
- USB expert help needed - Windows driver issue
- AudioStream example fails to compile
- Teensy3.1/Octows2811 and added caps and resistors
- Teensy3 and RCSwitch Library for 433mhz home automation and alarm devices
- KS0108 Fast/DMA Driver for Teensy 3.0/3.1?
- Teensy 3.1 and Audio Adapter : Compilation problems
- Teensy 3.1 does not appear on Arduino Board List
- Teensy 3.1 / SD card test request
- Teensy 3.1 Voltage issue
- COSA, Arduino object oriented libraries including SPI
- Out of memory just printing a struct...
- USB <-> /dev/ttyACM0 communication problem - "host echo?"
- Paul... Mike at RadioHead needs...
- Audio library WAV file looping feature request
- Help needed with DIY teensy please!
- Has anyone tried running the GSL16880 capacitive touchscreen controller with Teensy3?
- Teensy 2.0 and VBAT
- Unable find Teensy Loader
- Teensy 3.1 & HMC5883 Mag Issue - No restart with power up change
- Teensy USB driver "hijacks" Samsung Galaxy S4 phone USB function?
- HalfKay backup possible?
- Teensy Potentiostat - Help with Mains Hum
- teensy 3.1 internal rtc problems
- Teensy 3.1 float and double DC motor position control
- Teensy Joystick HID and encoder assign to buttons
- I2C on Teensy 3.0 and Teensy 2.0
- Mini54 for Teensy 3.1 Bare-Metal Project?
- SPI-DAC / DMA-Driven SPI on Teensy 3.0/3.1?
- How to identify Cat6 cable for use with Octows2811
- RAM used by Serial buffer
- AudioAnalyzeFFT256 Frequencies?
- Cryptography used in Teensy?
- usbMIDI sendRealTime
- Using YIELD for both Arduino and Teensy targets
- Turning a rotary encoder slowly
- Teensy 3.1 MIDI Controller Issue
- Install Teensyduino in Kali Linux
- Advice needed: Teensy 3.1 - OctoWS2811 - SD card all together
- Teensy 3.1 current drawn
- Blink program does not work on Linux with Teensy3.0
- Can I use the audio library to do an FFT on both L and R channels?
- Teensy 3.1 USB_MIDI NRPN Support
- Progress on the pin 33 issue?
- DMA SPI and SPI transactions
- Problems with the GT511C1 Fingerprint Scanner
- How to use the second I2C port on Teensy 3.1. RTC + Adafruit OLED
- Platform-agnostic USB upload procedure?
- SdFat and SD libraries for teensy 3.1 in non-arduino build environment (Code::Blocks)
- Analog Input and Output DMA
- teensy 3.1 analog input
- advanced analog read soon?
- Where is the definition of SPCR in teensy3 core?
- Easy way to read from UART
- Teensy++ 2.0: Counterfeit confirmation?
- Issues w/ SmartMatrix Library Teensy 3.1
- How does Arduino IDE reset the Teensy?
- Advice on code optimisation or prevention thereof
- Where is the 470 Ohm Resistor on Teensy 3.1?
- IRRemote issues.
- Using Teensy2.0 on Mac
- Is it ok to get time using micros() within IntervalTimer ISR ?
- octo 'basic test' give me all white
- Background SD write. Is it possible?
- <ADC.h> library
- MK20DX256 MINI54 alternatives?
- detachInterruptVector?
- Teensy 2++ Pin layout
- How to connect a teensy++ 2.0 (without pins) to a breadboard
- Wireless access of SD card data
- Using Teensy 3.1 with SD memory card as a flash drive
- teensy 3.1 and ILI9341 problem
- Teensy 3.1 and printf
- Encoder library - works fine on Uno R3, not on Due
- Teensy 3.1 as an ISP programmer for Attiny85 - missing signature
- Teensy 3.1 rarely starts.
- WS2811 library, DMA reset rate
- making a teensy display what its doing on a
- How to seperate the +5V of USB on teensy++2.0?
- Problems using Adafruit electret mic amp and Audio library
- Powering Teensy 3.1 with external 3.3v
- Mouse Mover teensy 3.1
- Teensy 2.0 Boot Loader Question
- Programming Teensy 3.1 for 3DS/2DS
- Using a 4051 with teensy2 for midi controllers.
- USB mouse and serial print - how?
- Help With Array for Input Pull Up Joystick Buttons.
- Can a Teensy 3.x detect when my computer sleeps and wakes?
- Teensy++ 2.0 does not work as USB Keyboard
- Teensy 3.1 & FRAM - 3.1-specific compile problem
- Teensy3.1 USB Type SD
- USBMidi with Serial Midi: Teensyduino 2.0 ++ using USBMIDI, then sending UART
- dogm128 LCD using the dogm128 arduino library
- Teensy short circuit: Vin and GND pins are common
- WAV table pulse generator
- sd card + SPIFIFO or spi4teensy3
- Teensy 2.0 ++ and flash
- ihex: parse error line 1 with Teensy 2.0
- Digital Outputs, Interrupts, and PWM
- Teensy 3.1 serial on OSX - can't see any serial device
- 2nd SPI Interface on Teensy?
- copy remote file to eeprom
- How to remap pins so that the T3 built-in LED isn't OR'd with the SPI SCK?
- Wiring a Pot on Teensy w Pins/Octo combo
- DMA Modes
- octows2811 teensy and python communication
- Syntax for attachInterrupt with Teensy 3.x
- LCD w/ Pushbuttons - Troubles
- Power from GPIO pins?
- Number of Touch Sense Pins?
- Did cutting the VUSB / VIN Ruin my Teensy 3?
- Serial stops transmitting after a few seconds
- Multiple switches on Analog input
- Using Teensy Audio with another class
- MIDI UART not successfully communicating with all receiving devices
- Using ADC and DMA with Teensy3.1
- undefined reference to `std::__detail::_List_node_base::_M_hook() and unhook()
- SPI read error with an accelerometer (LIS302DL)
- Working Code for 8pins into 1 using 4051 Mux and teensy 2.0 - MIDI notes via Buttons
- help with pre-programmed MINI54 setup
- Teensy + Encoder + Interrupt to wake up.
- Simple joystick button reduction
- Synchronisation of RTCs between multiple Teensy 3.1
- <functional> callback functions
- USB read, help is needed
- Bitwise operator question
- Issues calling time functions every loop
- Teensy 3.1 temperature rating
- Teensy 3.1 and Bluegiga WF121 Wifi module
- Oled display
- teensyduino 1.20, non-arduino IDE, and a linker error
- custom pcb using Pre-programmed ATMEGA32U4, sd with mass storage?
- Option to license boot loader as commercial company
- Teensy 3.1 Xbee API transmit issue using Series2_Tx
- IntervalTimer.cpp bug?
- ILI9341 LCD panel gets very toasty
- Teensy 3.0 HID Joystick under OS X 10.9.4 Not seen as joystick/gamepad
- Multiple single colour 5v leds; most effective solution?
- Bluetooth module over Teensy-USB-Port
- No serial with Teensy 3.1
- Movie2Serial maxPorts
- USB Host/OTG project
- Teensy 3.1 - "USB Device Not Recognized" - HELP!
- Best practice printing a field on a graphics display or spoiled by 4d Systems........
- Read two bit signal with SPI - Teensy 3.1 can use two channel SPI?
- I2C Speed on Teensy 3.x
- +3.3v Line Shorted to GND
- Programming multiple Teensy 3.x simultaneously
- FreqMeasure lib issues
- Program not runnin at power up Teensy 3.1
- teensy timer interupts
- teensy pin change
- Teensy 3.1 Radio Head
- Led strip WS2812 . problem with code and hw response
- Compile Error using struct pointer in function
- Problem with usbMIDI.read() fonction
- SPI compiler error with ILI9341_t3 (Teensy 3.1)
- Teensyduino compile error on example MIDI projects
- Emulated serial monitor issues...
- uGFX Port for Teensy 3 / ChibiOS available?
- Apple-Ignorant
- windows 7 drivers
- teensy 3 wiimote or wii remote blob data to serial stream
- Audio problems? Try a different micro sd card.
- Teensy 3.1 EEPROM
- XBEE and Teensy3.1 hardware flow control
- analog in pin question
- My code behaving weirdly for 22 x pots with 3 x 4051 Mux's - Teensy2
- Syncing the RTC with milliseconds
- GPS / UART / Passing NMEA strings to RX3 / TX3
- too much bytes received on Teensy 3.1 ?
- Teensy3.1 Audio adaptor with 12 touch pins
- Mac OS X 10.9 No Serial Ports for Teensy 3.1
- Serial LED problem
- deleting alarms in TimeAlarms library
- Teensy 3.1 - Possible to compile via gcc in text mode Linux (i.e. no desktop)?
- RTC Issue
- How to detect when no RAM left for a malloc? It seems to just keep going (Teensy 3.1)
- How to create array for four 4051s on teensy2 analog pins
- Dead Teensy3.1? Help needed.
- How to Re-map Serial ports 1 and 2 on Teensy 3.1
- Adjusting PWM value on Pin 20
- Sparkfun LCD module w/daughter board
- Serial Monitor doesnt show anything
- teensy 3.1, windows 8, and "unknown USB Device (Device descriptor request failed)"
- TEESNY3.1 Glediator+SD
- Teensy 3.1 with SIM908 breakout
- setting teensy3 to low speed usb mode
- Interrupt vector table moved to RAM for Teensy 3.x - replace and/or hook?
- program upload options
- Disable USB Mouse/Joystick From Keyboard/Mouse/Joystick Trio on Teensy?
- Issues with SPI
- How many PWM channels/pins can I use simultaneously on Teensy 3.1?
- key press problems
- Teensy 3.1 + Adafruit CC3000 is failing
- Shorted Pin, fried resistor..
- Problem with Timer1 on Teensy 3.1
- Kernel input driver problems in Fedora 19
- Digitalwrite not reliable (Teensy2)
- Compiling help!
- Compile warning error help...
- Teensy ++ 2.0 clock output or external oscillator
- teensy 2.0 with HID
- analogWriteFrequency and Teensy 3.1
- ov7670 w/o fifo and Teensy 3.1 - Need Teensy 3.1 to output clock of 8,16 or 24mhz
- My Teensy doesn't work
- MINI54 and MK20DX256VLK7
- (slightly OT) GitHub re-sync fork (help)
- update: fixed issue with RTC. Resynching limits?
- Problem with TinyGPS++ and U8GLIB on Teensy 3.1
- advice for embedded & simplified Teensy 3.1 needed
- PWM max frequency teensy 2.0 and 3.0
- Reassign pins SD library Teensy 3.1
- Problem with 1.8" Color TFT LCD display with MicroSD Card Breakout
- OCTOWS2811: 8 strips via 8 pins vs. one pin and one looong strip?
- Can I output a samplevalue through I2S with the Audio-library like "analogWrite"?
- Teensyduino uploads sketch repeatedly
- Reading LED Matrix Size from SD Card Text file and configure OctoWS2811 memories
- analog inputs during power off
- LSM303 library issues
- override yield - functionality of default...
- Possible RAM overflow on Teensy 3.1?
- State Variable Filter (why does it do this)
- Arduino 1.0.6
