- Reading DC RMS voltage from a PWM signal.
- IntervalTimer priorities
- multiple adc inputs + Audio library, no Audio shield
- NewPing Library Incompatibility with Teensy 3.1
- Teensy cli loader and Teensy 3.1
- Using spi4teensy3 with 74hc595
- Teensyduino 1.19 Installer doesn't see arduino-1.0.6 install
- Teensy 2.0 UART with Fosc < 16MHz
- Teensy +2 general hardware interrupt question - use of pullups required on INTx pins
- how to create a timealarm for a specific date and time ?
- Teensy 3.1 hangs on Wire.endTransmission()
- Teensy3.1 i2c
- A new DYI guy :)
- Teensy 3.1 & PROGMEM pgm_read_word() fails
- Power a Teensy via MIDI Port
- i2c liquid crystal display not working on teensy 3.1
- Teensy 3 and pySerial
- Teensy3.x strncpy_P() bug
- Teensy 3.1 & Encoder library with powered encoders?
- Teensy 3.1 + 4051 and ground (GND or AGND?)
- Loading Teensy 2.0 USB serial driver
- Changes to PGA1 also change PGA0 on Teensy3.1
- Teensy 3.1 need to output 8mhz clock on digital pin
- Audio Library causing delays in interrupt based timing
- Reading low resistance using an lt3092 constant current source
- SGTL5000 Audio adapter board - headphone out as input
- LCD wiring
- Teensy 3.1 is dead after Erase All Blocks Command :-(
- using #if test against things like Serial1 Serial2...
- Controlling a USB fan with teensy
- Connecting several teensies via serial
- Teensy I2C and stepper problems
- usb_serial and Teensy 2
- Powering Teensy 3.1 with 2s 3.7v batteries
- Hard Shutdown When Uploading Sketch
- eval() type function?
- Detecting the state of a switch?
- Teensy 3.1 executing code before setup
- Teensy 3.1 raw hid dying intermittently.
- Teensy 2++ Hardware Problem ?
- How to view all of the verbose complier ouput in Arduino?
- Teensy 3.1 Cortex M4 Specification Verification
- Teensy3.1:Project Directory Structure
- DigitalWrite and AnalogWrite on the same pin hate each other?
- Can Teensy 2.0 run with Arduino 1.5.7 Beta IDE, GCC version 4.8.1, C++11?
- I2C NVRAM odd behavior
- Serial frustration
- Burned the onboard LED; which pin is that LED attached to?
- Looping Sound Samples / Audio Lib
- Corrupted Serial after 32 characters - Teensy 3.0
- Corrupt USB comms?
- TEA5767 radio module on teensy?
- New Teensyduino won't install on Mac
- Teensy Audio Board size?
- How to wire CC3000 and Audio shield at the same time?
- Problems powering Teensy 3.1 from ATX PSU
- How do I connect 2 Teensy 3.1s wirelessly (not WiFi or BT)
- Did I killed my teensy?
- Teensy3.1 loader not working
- Teensy 2.0...what is the extra set of bottom pads for?
- Real Time Crystal
- More Axis in windows
- teensy 2 timer 4 at 64mhz
- Random coding question thread
- Power Draw from Teensy 3.1
- Teensy 3.1 MIDI issues
- Reading an N64 controller, getting no data
- Teensy 2 outputs random data to Teensyduino Serial Monitor when "Hello World" is sent
- Teensy not working after uploading WM8731 code
- digital filtering 40khz ultrasonic burst with audio library
- Basic PWM using Flex Timer
- PWM, I think I torched an output....
- Teensy 2.0 Running 3v3 @12Mhz Out of Spec?
- Teensy 3.1 not booting
- Teensy powers off when Odroid boots
- USB Serial Interrupt Teensy 3.1
- Teensy 3.1 crashes when using AudioInputAnalog
- Teensy3.1 audio shield Volume
- EthernetUDP Multiple Sockets
- Library for using LPD 6803 chip
- Teensy3.1 completely dead / not booting - how to do factory reset
- how to use input capture with comparator
- PJRC store 320x240 LCD specs?
- No support for sending the ESC keycode from the Arduino keyboard library
- hid_listen not working on Linux (waiting for device)
- Brute Force With Teensy 2
- could not open device /dev/ttyACM0: failure(13): Permission denied
- Teensy 2.0 has only 2 C pins and 6 F pins
- Cannot communicate between Teensy 3.1 and Arduino nano using EasyTransfer
- Teensy 3.1 interface to 5V logic
- (HELP) Still not sure if i'm going to Kill my Teensy 3.1 with 5 V
- Audio: How to start SD files from a particular point, not the start
- (Awesome) Audio Library: FFT & analogReference
- Error in the bill of materials/schematics?
- Encoder library bouncing
- connecting nRF8001 to Teensy 3.1
- Teensy Switch?
- Simple IRremote question
- TIME_T for CPP files
- Possible to communicate between Teensy 3.1 and Arduino?
- Teensy 3.1 works from external power, but no power from USB
- IRremote trouble: 'IRsend' does not name a type
- Teensy 3.1 USB connection on a project PCB with USB-B connector
- How to reduce noise from analog pins?
- Changing SPI pins on Teensy 3.1
- Teensy 3.1 Connected 5v to 3.3v pin -> dead
- Teensy 3.1 loader doesn't detect the board
- Teensy + Audio Library + Smart Matrix Library = not working
- Teensy 3.1 and ENC28J60 (again?)
- teensyduino 1.19 on ubuntu 14.04
- INPUT, pinMode not declared Compiler Error with #ifdef and Classes
- PWM amplitude
- minor fixup to touchRead() function in teensy core lib
- Adafruit_Neopixel library help
- Can I use teensyduino on my design?
- Bricked Teensy with custom linker script
- Connecting Teensy 3.1, OctoWS2811 and Wiz820SD
- looking for more info on paul's new SPI library adaptions
- Teensy 3.1 SPI, U8Glib and SDfat
- Teensy 3.1 footprint for Eagle (brd)?
- Local functions to augment library functions
- teensy 3.1 wire, failed to get a signal on I2C pins 18 19
- Teensy 3.1 USB: issue sending intr reponse greater than 64 bytes
- Teensy 3.1 as USB Host
- Teensy 3.1 and DmxSimple issues
- 2nd teensy -> smoked. Everything was double checked. Serious issue here.
- ESP8266 with Teensy
- Library for MCP23S17 - plus rotary encoders
- 3 questions regarding TEENSY 3.1 and OCTOWS2811
- Help please: logic level & SN74LVC245AN
- Serial Teensy 3.1 to Arduino
- Adafruit_LEDBackpack and Teensy 3.1 library compatible?
- question about serial ports
- Again Question 2 regarding executable file
- A couple super-simple questions
- wav2sketch problems
- Problem with Audio Peak-Object
- ADS1248 24bit ADC Read/write Registers vis SPI.transfer
- Embedded Teensy 3.1 / schematics correct?
- Teensy Loader lost connection with new Teensy 3.1
- Problem with Teensy Audio library without the audio shield
- Trouble reading joystick buttons with SPI
- A brief question on TimerOne Library. Understanding why attachInterrupt requires void
- Teensy/OLED based car clock
- FreqMeasure and harware interrupt
- Random hex errors Teensy2.0++ PS3 NOR
- Amplitude
- LCD HD44780 and Teensy 3.1
- Servo now working when using AudioOutputAnalog
- Teensy 3.1 bricked by pin toggle sketch
- Teensy 3.1 and CSI (?)
- Questions on Teensy 3.1 components
- I need to import Teensy3.0.lbr into designspark...
- Midi clock signals
- Please look over my schematic. Smoked a teensy 3.1 over here...
- Trying to get play_queue to work
- digitalRead value when floating
- Teensy 3.1 and ADC
- Remote reboot / user code update
- RTC Teensy 3.1
- ID pin required on micro USB for Teensy 3.1?
- using ethernet and sd card with teensy 3.1 octows2811 adapter and WIZ820 sd adpater
- Fast random number?
- USB Audio 2.0 Spec (MIDI related, OSX Mavericks)
- 3.3 voltage regulator question
- 9 Bit Serial on Teensy 3.1
- Multiple Teensy's Message Specific One
- Teensy 3, MIDI, USB, and Windows 8
- Teensy 3.1 COM Ports on Windows 7
- Trouble connecting Bluetooth to Teensy 3.1
- Code size/alignment failures resulting in board crashing and/or no USB serial.
- Teensy 3.1 serial port already in use on windows
- pyserial or Pyusb and Teensy 3.1
- How to enable teensy 2.0 as disk(SD Card) only sometimes
- how to debug with pauls_ugly_debug.h?
- Serial2 with Pins 26,31
- Atmega 32u4 Breakout plus microsd doen not work as Disk SD
- Octows2811 adapter and Newer Neopixels + teensy 3.1 = no lights
- Custom Teensy 3.1 powered board not working
- One of my Teensy 2.0's only seems to work reliably when powered over USB...
- loop station issue with teensy 3.1 and audioshield
- WS2811 problems
- usbMIDI not declared error
- buffersize when using AltSoftSerial
- compatability of nrf8001 BLE with teensy 3.1
- Is there source code for teensy_gateway available?
- Custom board: USB debug connection stops MK20
- Teensy 2.0 + USB host shield + sd as SD disk + keyboard = program too big
- Teensy 3.1, MPU6050 and I2C
- Storing sensor reading to flash memory on teensy 3.0
- Teensy 3.1 PID and VID to emulate a Touchscreem
- mk20dx128.c for (n=0; n<10; n++) ;
- Newhaven Touch TFTs and Teensy?
- Noobe coding question 'not declared in this scope'
- Teensy 3.1 Running a Program off a SD card
- Serial.flush?
- Teensy extra RAM options?
- Fast color display >= 128 by 128 pixel compatible with Teensy 3.1 software
- Teensy 3.1 USB data missing bytes
- LED limits on Teensy 3.1
- Ubuntu 12.04: Arduino 1.0.6 + Teensyduino
- Forum: how to change my name?
- Teensyduino compatability for PVision.h? (Pixart wiimote IR camera library)
- Windows not detecting Teensy 3.1
- DMA to DAC problem
- Audio Adapter Board Current Draw?
- Teensy 3.x nanosecond delay function?
- blown cap(?)
- how do you make FreqMeasure.end command work.
- Teensy 3.1 serial 'lag'?
- Audiolib questions.
- Trouble with TeensyDuino install
- Faster ADC?
- Calling multiple sine wave instances
- DIY Teensy woes
- i2c_t3 Arduino Compile Error
- Teensy 3.1 no moor recognizing whit Win after all its working fine
- Teensy 3.1 and 5V Analog input
- Glitch with I2C comms
- Teensy 3.1 - USB to DMX with FreeStyler
- Issue with NewPing EventTimer example
- Discarding the data in the USB transmit buffer, Teensy3.1
- Windows 8.1 - Teensy PID_0487 (Serial/Keyboard/Mouse/Joystick) no longer recognised
- Capacitors on VOUT33
- Teensy 3.1 and audio shield and wav formats - cant play some wavs
- Teensy 3.1 & Neopixel Strip not working
- Low profile headers/receptacles used on WIZ820io & Micro SD Card Adaptor
- Q wrt Rainbow.ino and pin utilisation
- Teensy 3.1 analog pin declarations
- I2C on teensy 3.1
- Audio Library: question on fft1024
- Teensy 2.0++ Running at 3.3 volts
- teensy 3.1 pin mapping (A10-14)
- LiPo Battery Monitoring Circuit & Code
- New to Teensy... Having troubles with built-in RTC clock
- Teensy 3.1 Quadrature Encoder Speed with Multiple Encoders
- Hardware serial is still serial1 in no serial configurations?
- Recorder example and Audio Board
- Wiz820io/Teensy3.1/PJRC Ethernet-SD shield basics
- Understanding USB initialisation of Teensy
- Simple OLED SSD1306 question
- teensy 3.1 resistor near the usb socket
- Adafruit_nrf8001 and SDFat problem on teensy 3.1
- input_pullup not listening
- Pushbutton is crashing Teensy2.0++
- Wiring Power for long data transmissions via OCTOWS2811 adapter board
- Audio Shield: LineIN glitches when capturing audio (audio block data has spikes)
- OS X can't see the Teensy any more
- migrating code from teensy 2.0 to 3,1 help!
- Some observations on USB nost shield and teensy3.1
