View Full Version : Technical Support & Questions
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30
  1. Setting up a PWM signal
  2. HID RAW debug on teensy3
  3. Improper hello.
  4. T3 Power and protection questions
  5. Conformal Coating on the Teensy 3
  6. Eagle Library.
  7. Teensy 3.0 & X-Plane
  8. Teensy 3.0: What doesn't work yet?
  9. output current capability of Teensy 3 pins?
  10. RS232 ports on the Teensy 3.0
  11. Rotary Encoder?
  12. Call function in parallel of loop
  13. Midi and Serial?
  14. new teensy 3 commands
  15. teensy 3 MAC address
  16. Serial Monitor not showing any updates
  17. GPS working!
  18. Current consumption
  19. Teensy as USB CD/DVD-ROM Emulator
  20. Teensy3 DAC - Anyone got I2C setup yet?
  21. Beta7 compile error
  22. GND vs. AGND
  23. Teensy++ 2.0
  24. T3 Hooks for ChibiOS RTOS?
  25. Serial port/monitor problem?
  26. t3 uart pins
  27. What the ^&%$*$ is Arduino IDE doing with my header files?
  28. (someArray, sizeof(someArray)) in constructor
  29. Somthing is clobbering two stack locations?
  30. PWM signal on teensy 2.0++ in C
  31. Accessing serial I/O from inside a library
  32. TRouble getting SPI to function with Teensyduino
  33. Compile error cannot find -lc
  34. Teensy 3.0 Newb: Can't see half kay boot loader
  35. Attach Interrupt question
  36. Teensy 3 Newbie questions
  37. bricked teensy3?
  38. Trouble getting Teensy Loader to recognize Teensy 3
  39. Teensy 3.0 'Keyboard' was not declared in this scope
  40. Teensy3 makes Arduino development environment hang
  41. how to jump the bootloader for teensy 3.0
  42. Teensy 3.0 Development Environments
  43. NPN Open Collector
  44. Teensy 3.0 ADC details
  45. teensy2++ gain using Arduino
  46. Teensy 2.0 ANALOG IN
  47. Detect Teensy 3.0
  48. Experimenting with USB-MIDI on Teensy 3.0
  49. Accessing virtual serial in Keyboard + Mouse + Joystick mode?
  50. ADC configuration
  51. 128x64 LCD vs nokia
  52. TTL Serial Cable
  53. Out of range pin numbers - do they do anything bad?
  54. Teensy 3.0 UART voltage tolerance; 5v?
  55. TwoWire::endTransmission always return 0
  56. Help debugging dead T3s
  57. Tool chain for teensy 3.0
  58. teensy 3 freeze
  59. "General" Typecast from int32 to int16?
  60. Trouble with Teensy 3 IDE
  61. 16x32 RGB Matrix Display (Adafruit) on a Teensy 3.0 ?
  62. Teensy 3.0 as logic analyzer, instruction timing
  63. RFM12 library
  64. i2s Help
  65. SD Card with Teensy 3.0
  66. 32.768 KHz crystal and battery for Teensy 3.0 RTC questions
  67. Embedding Teensy 3 in project - Reset and PGM pins
  68. Ultrasonic PWM
  69. lib compatibilities and functionalities
  70. T3 - Multiple SPI?
  71. Deploy sketch via BT
  72. USB Keyboard Example code?
  73. Eagle library with Teensy 3.0 footprint
  74. Connecting JTAG to Teensy 3
  75. ARM assember code
  76. Is this a Teensy 3 forum only or Teensy overall forum?
  77. Wire compatibility
  78. ChronoDot (Adafruit) use with Teensy 2++ ?
  79. Lego ultrasonic sensor with Teensy 3.0 and wire library
  80. Programming a Teensy via Win 7
  81. Teensy 3 SPI Basic Clock Questions
  82. teensy 3 adc voltage input max?
  83. Basic question on Teensy++ 2.0 interrupts
  84. ElpasedMillis doesn't seem to work
  85. Teensy3 alternative for dtostrf() ?
  86. Teensy 3.0 Memory Map
  87. PinChangeInt.h Teensy2
  88. Timer-based interrupts?
  89. Dallas 18B20
  90. Cannot get Teensy Loader to work with Teensy 3.0
  91. Recommend a Proto/expansion brd for Teensy 2.0++
  92. teensy 2 joystick stopped working
  93. Timer interrupt, or other way to read SPI consistently on Teensy3.0?
  94. Teensy 2 Use On-board pushbutton
  95. Teensy 3.0 UART (Serial Ports)
  96. Problem with 'multiple definition of Serial' on Windows Vista
  97. Getting started with raw C: GPIO initialization?
  98. Teensy 2.0 Real Time clock
  99. Problem with HMC5883L magnetometer
  100. Anyone using Eclipse for development?
  101. teensy 2.0 and teensy 3.0 question
  102. Compile GCC for teensy 3?
  103. Freescale Header Files
  104. i2c communication library
  105. Dual USB Go Button
  106. MI0283QT-Adapter with teensy++ 2.0 and arduino
  107. Read SD card on computer through Teensy 3.0
  108. Controlling a pump with teensy3
  109. win7 x64 will not auto-reset
  110. 6x8 keypad on Teensy 2.0
  111. Teensy 3.0 and the 595!
  112. Teensy 2.0, Attach interrupt question
  113. voltage levels Teensy 3.0
  114. Multiple power supplies
  115. teensy 2.0 self-powered usb serial port problem
  116. Teensy 2.0 and low power mode: CPU Speed?
  117. Trying to program Teensy 3.0 using Ubuntu 12.04 (64 bit)
  118. Teensy as a Dongle
  119. how can I know what interrupt (edge) I get in teensy 3.0
  120. Problem with Teensy3 beta9 IDE compilation
  121. 'undocumented bit' 0x40 in USB0_TRC0 0x40
  122. Stupid question in relation to voltages
  123. Teensy 3.0 Timers
  124. Installing on Ubuntu 12.04
  125. Teensy as a controller for digital volume attenuator
  126. Teensy3 stopped responding
  127. Teensy 3.0 resistors and DC current per I/O pin
  128. Any time frame for a Teensy 3.0 option with Keyboard and Serial ?
  129. Teensy 3.0 RTC
  130. Teensy3 and SdFat.h
  131. Error compiling (Teenst 3.0, Win7 or XP)
  132. Two instances of Teensy 2.0 in HID query Java using hidapi-1.1.jar
  133. Alternative USB string instead of "VOTI Teensyduino Serial"
  134. Teensy 3.0 - EEPROM writes not persisting through reboot - wierd
  135. Using Teensy 2.0 as a HID - Set a serial number or Product?
  136. Communication over USB
  137. Internal pull up and pull down resistors on teensy 3
  138. USB to digital I/O delay ?
  139. Best practice for programming a Teensy 3.0 and its 32 bit ARM
  140. Teensy2.0++ flash blank chip?
  141. Accessing the SdCard with SdFat.h and teensy 3.0
  142. Teensy 3.0 C++ STL?
  143. Teensy 3.0 Pin Out Diagram
  144. Compile C++ program for the Teensy 3.0 (Lat/Long to MGRS coordinate conversion)
  145. Can Teensy3 be powered from 3.3V if USB is not used?
  146. Teensy 2++ won't start user code after it gets reset input on power up
  147. Can't See Menu Items on Ubuntu 12.04
  148. Can anyuone recommend a Bluetooth module for use with the Teensy
  149. 3.0 cli
  150. AnalogRead(0) With 50K Potentiometer
  151. CRC algorithm
  152. Raspberry Pi and Teensy 2.0 USB Serial communication
  153. Teensy-3 Clock Settings
  154. BURNED my Teensy 3.0
  155. Teensy 3 Wire Lib Error
  156. Bad Board?
  157. Will the Teensy 2 drive 40mA directly or do I need a transistor/driver?
  158. Teensy 3 3.3 current
  159. Help porting library
  160. Bounce still not behaving
  161. SoftPWM on Teensy 3?
  162. Teensy 3 Noob question about analog read
  163. Teensy 3.0 capactive touch
  164. Strange readings on serial1 with teensy3
  165. brand new
  166. Serial Monitor Issue
  167. raw hid on linux
  168. DualVirtualSerial for teensyduino?
  169. switch help for racing simulator
  170. Serial Port Emulation via USB
  171. interfacing sd card and 2x16 lcd to teensy 2.0
  172. soldering my own pins.
  173. Teensyduino Version #define?
  174. Externally Powered Teensy 2.0++ with 4 AA-Bateries.
  175. T3: linking libarm_cortexM3l_math.a
  176. T3: TimeOne.h
  177. Help getting teensy working on XIM 3&Edge
  178. Interupt pin sensitivity
  179. Bootloader and Watchdog Timer
  180. Teensy 2.0 LCD Smartie Serial Problem
  181. IRremote lib on Teensy 3.0
  182. Please Post Code & Details In Your Question!
  183. How low is low enough?
  184. Dead Teensy 2.0 & 2.0++
  185. ARM Library
  186. Strange phenomena
  187. Analog Input not working
  188. Makefile on Windows 7
  189. Installation of Teensyduino on OS-X
  190. Interesting observation on the ADC of Teensy 3.0
  191. ethernet issues with teensy 2.0 & arduino >1.0.1
  192. Teensy LED Test Problem
  193. "Device node not found" on a Linux machine
  194. Use of IRRemote Lib and AltSerial with Teensy 2.0
  195. Help with PWM & Interrupts on Teensy 3.0
  196. usbMIDI timing question
  197. Does anybody get Teensy 3 working with NRF24L01+?
  198. AMOLED support?
  199. Teensy 3.0 Connect with BlueSMiRF
  200. Teensy 3.0 Keyboard compile troubles
  201. mktinyfat
  202. Baseline PWM frequency on Teensy 3?
  203. T3: generating special symbols with USB keyboard
  204. Need help with analogWrite and digitalWrite on same pin
  205. Is my Teensy 3.0 broken?
  206. Parallel 3.3V out
  207. EtherCard library - pinout question
  208. I2C lcd display with teensy3
  209. sending USB HID page 0xC key codes above 0xFF
  210. VLPR Mode for T3
  211. ADC values on Teensy 2.0
  212. T3: Can't get serialEvent3 to work
  213. Temperature on analogRead(38)
  214. Teensy 3 RTC incorrect time question
  215. RF24 (maniacbug) and Nrf24L01 with Teensy 3.0
  216. T3: compile error flash library
  217. how to change com port number during windows driver install (where is stored ini ?)
  218. MCP 3421 Confusion...
  219. How to upload programs to the Teensy
  220. I2C barometer BMP085
  221. What exactly does analogReadAveraging does?
  222. USB Mouse Absolute Coordinates
  223. Cannot compile ST7565 LCD test program, Teensy 3.0 Beta10 Software, win7
  224. Teensy 2.0 USB Keyboard - Integer Value or Serial.print?
  225. AnalogRead extension procedures and THE MISSING MANUAL!?
  226. Specifying Teensy 3.0 Alternate Pin Functions
  227. my Teensy 3 is having trouble taking any new code
  228. What is ADC calibration and how can I activate it in Teensyduino?
  229. Easiest way to verify the validity of a Clock Signal?
  230. Differenciating in udev rules a Teensy 2 from a Teensy 3?
  231. SoftwareSerial doesn't compile for Teensy 3 it seems
  232. How to set priority for systick?
  233. Problems with Teensy 3 and bottloader
  234. millis() on teensy 3
  235. Adafruit_ST7735 + Adafruit_GFX Teensy 3
  236. teensy 3 crystal freq check with NTP and GPS
  237. EEPROM erased after sketch upload
  238. PITimer: PIT (Periodic Interrupt Timer) library for Teensy 3.0
  239. stupid problem with Serial.printxx in setup loop (teensy3 b10)
  240. teensy 3 I2C speed test vs other MCUs
  241. Help me please!!!!!
  242. A little keyboard help?
  243. max speed over usb serial (from PC to teensy2)
  244. Teensy 3.0 UART0 MSBF/LSBF Not switchable
  245. teensy 3 unconnected SPI speed and SD speed
  246. Bluetooth keyfob
  247. IRremote
  248. Make / Brand of PGM Button on Teensy 3.0?
  249. WIZ820io Ethernet and 2nd power supply with teensy 3.0
  250. Best way to send pulses to a stepper motor driver- Geckodrive from Teensy 2++
