View Full Version : Suggestions & Bug Reports
Pages : 1 [2] 3 4 5
  1. Good work Paul
  2. Proposal for additions to Ethernet / EthernetUDP library
  3. Minor fix in 3.18
  4. SPI sharing between interrupts and main program
  5. OctoWS2811 flicker
  6. Teensy 3 startup code vector table mapped to 0 always
  7. Teensy 3.1 to Arduno Shield DIY Adaptor
  8. [ teensy_loader_cli for 3.1 ]
  9. Makefile suggestion
  10. Suggestion: wiki.prjc.com for User Contributed Documentation / Wisdom?
  11. SD & Ethernet examples may need editing
  12. Teensy 3.1 AnalogWrite problem with slow PWM frequency
  13. an FYI: on remapping the Teensy 3 LED and using SPI
  14. CoAP (Constrained Application Protocol)
  15. Improve Serial API for large TX
  16. audio library / mysterious crash
  17. Teensy 3.1 overclock to 168MHz
  18. Cat6 is wired opposite? OctoWs2811 wiring
  19. Could there be something like an ISR template function?
  20. 2.7 inch ePaper on Teensy - does not compile - Adafruit_GFX
  21. USB should be more flexable -- Please discuss your thoughts here.
  22. Arduino Library Interactions
  23. Bug: DMA macros only work for Teensy 3.0
  24. BUG/FYI: 16/32Bit access to adress 0x1FFF_FFFF cause hang (Teensy 3.x)
  25. Any chance for a real debugger interface in Teensy 3.1++?
  26. Audiophile DACs & other parts
  27. FreqMeasure.h not working
  28. 1.19 teensyduino installer with arduino 1.0.5 install fails on OSX mavericks 10.9.3
  29. Bug in DS1307 RTC Lib
  30. Compile error using Adafruit_GFX library
  31. Teensy 3.1 HID doesn't work with Mac OS X 10.10 beta, Yosemite
  32. MAC Address on Teensy++ 2
  33. Bug in Print::printFloat
  34. libaray DMA channel selection
  35. Arduino IDE 1.5.x
  36. Token expired
  37. Forum problem: posts disappearing. False spam positive issue?
  38. RTC Time running fast
  39. Suggestion: Teensyduino Linux ARM download package
  40. Time library fails to compile on Arduino 1.5.7
  41. pinout card == handy
  42. FreqMeasure teeny 3 errors with CORE_PINx_CONFIG
  43. TFTP Bootloader, update firmware over ethernet?
  44. Kepad [4x4] does not rspond after some time
  45. Transactional SPI
  46. Problem with Serial connection to PC.
  47. Pauls Forum inbox full..
  48. Highly optimized ILI9341 (320x240 TFT color display) library
  49. LowPower_Teensy3 delay function appears to hang
  50. USB: Raw HID send with multireports
  51. Forum Warning/Bug
  52. JTAG/SWD Debugging for the Teensy
  53. Software Debugger Stack
  54. How to debug Teensy3?
  55. Simple suggestion for easier debugging with Teensyduino
  56. Arduino Time Library compile error
  57. Why is there no link to the forums on the main web page?
  58. Suggestion : make send_raw method in usb_midi/usb_api public
  59. Possible bug introduced in v1.20-RC2 : CC3000 echoServer/chatServer not responding
  60. CC3000 echoServer/chatServer hangs after few transactions
  61. teensyduino linux installer - two issues
  62. DMABaseClass::source() bug
  63. I2C Slave Receiver on Teensy 3.1 Crashes
  64. Teensy3: Serial1, Serial2, Serial2 separate code?
  65. Suggestions/ wishlist for future functionality
  66. fdev_setup_stream compilation error with Teensy 3.1
  67. gcc with -fmudflaps for buffer overrun detection
  68. Encoder library - In Encoder_internal_state_t, why isn't position marked volatile?
  69. Some library not fauld after installing Teensyduino on 1.0.5
  70. TeensyLoader seems to choke on large .hex files II: Audio's SamplePlayer
  71. printFloat bug
  72. Teensy 3.1 serialevent
  73. adafruit ssd1306 compile error 128_64 OLED
  74. New Product Suggestion - a Synthesizer Adapter
  75. Android Sketch Loader App?
  76. any chance to get teensyduino on arduino 1.5.7?
  77. Loading Teensy 2.0 USB serial driver
  78. _restart_Teensyduino() for T3.x
  79. 'HID Keyboard Device' not working for me using T3 from Teensyduino 1.19 onwards
  80. Odd behavior when wrapping Encoder inside another class
  81. Teensy CLI loader with Teensy 3.1
  82. Tone library, the Audio library and DAC/A14
  83. Audio GUI comments and file organization
  84. Teensyduino 1.21 Features
  85. SD library can not access the filesystem
  86. analogWrite() Max Value in Question
  87. Tutorial3 PushbuttonPullup typo
  88. Teensy 3.1 is not recognized under Mac OS X - Yosemite (10.10)
  89. Teensy 3.1 shows as unknown device after use with windows 8?
  90. Combining teensies with the Arduino Yun
  91. teensy 3.1 serial.read
  92. Documentation error on Pulsed Output: PWM & Tone
  93. Analog pin interference T3.0
  94. Serbian Keyboard Layout
  95. Stream.cpp bug?
  96. OctoWS2811 Adaptor Revision
  97. LowPower_Teensy3 and external power
  98. Fix for 9-bit serial receive bug
  99. Suggestion for Interrupt (Audiolib) / NVIC_SET_PENDING
  100. Updates to new yield.cpp code
  101. OctoWS2811.h #include guards
  102. Toolchain update, 4.7.2 to 4.8.4
  103. Allocation of software triggered interrupts
  104. Teensy 3.1 Audio Library - Envelope limited to 1000 ms?
  105. Forum search underwhelming on occasion
  106. Arduino compilier bug involving serial library and communication.
  107. Teensyduino started crashing at start (Mac OS-X Yosemite)
  108. Teensy USB Serial under Win8.1 fails to install
  109. Serial or Serial1?
  110. Internal RTC reliability?
  111. Audio library compile problem
  112. trouble with teensy loader on ubuntu 14.04
  113. Adafruit dotstars
  114. SamplePlayer example!
  115. .wav files / headers
  116. Teensy 3.1 back side pins
  117. Teensy documentation to a wiki format
  118. SPI Flash Allocation Table
  119. Suggestion to make Teensy next gen PLUS
  120. Compressed AudioStreaming
  121. 2 problems
  122. Serial write lag at high frequencys
  123. boards.txt disable USB on teensy 3.x
  124. Very minor mistake in Audio/synth_sine.cpp
  125. Undocumented Feature ? Digital Filters
  126. Bug - AudioSynthToneSweep - Up good, down ignored
  127. processor lock-up
  128. snprintf_P wrongly defined in pgmspace.h ?
  129. USB Device Charger Detection (USBDCD)
  130. Can't upload to teensy 3.1 on Xubuntu all of a sudden
  131. Teensy-LC Beta Testing
  132. latest SPI from PaulStoffregen/SPI gets compile error
  133. increase bufsize for play-sd-wav
  134. Bug - DS1307RTC - example:SetTime - weekday not set correctly
  135. Time.h + Teensy 3.1 + DS1307 RTC = errors
  136. Teensyduino for Arduino 1.6?
  137. AudioSynthToneSweep never ends
  138. teensy 3 memcpy has gotten slower
  139. Android ADK support and USB host
  140. WIRE library I2C lockups on Teensy 3.1
  141. Clicking envelope with Audio Library?
  142. SMT Teensy 3.1?
  143. Audio Adaptor Board connections
  144. TimerOne.h does not compile
  145. ILI9341_t3 readRect() / writeRect() bug
  146. octows2811.h to include #ifndef ?
  147. spam reporting broken
  148. DMA Library?
  149. possible bug in spi & spififo
  150. Performance drop going from 1.0.6/TD121b8 to 1.61/TD121b10
  151. Mtp
  152. Teensy LC + SdFat library
  153. Teensyduino 1.22 Features
  154. Updated Website Information for Teeny 3.[01]??
  155. How does teensyduino identify a Teensy?
  156. possible new bootloader features
  157. Teensy 2.0 String() bug?
  158. Teensyduino 1.21 + Arduino 1.6.1 Libraries Location?
  159. Bug in Teensy AVR Print class
  160. No difficulties to download on Windows
  161. RTC Issue
  162. Why is SPI1 an extra class?
  163. Teensy LC SPI::transfer16
  164. Teensy Loader 1.21 does not remember my choice...
  165. Mouse.moveTo and multiscreen system
  166. Teensy LED_BUILTIN is different type than in Team Arduino variants
  167. High Speed Serial comms between 2 Teensy 3.1
  168. 2.0 not rebooting, and IDE crashing. Hard.
  169. @Paul Update for Library LedControl
  170. Possible bug in Serial.print(uint32_t,HEX)
  171. Arduino 1.6.3, Teensyduino 1.22 - Word wrap verbose output
  172. Forum search help
  173. Advanced Search of forum broken?
  174. Hardware Bug?: Teensy 3.1 Power Up / Boot Problem - Touch Pin 33 !!!
  175. Compare DMAChannel with DMASetting?
  176. Found a possible bug in TeensyLC
  177. Teensydunio 1.22 boards.txt F_CPU typo
  178. Teensy 3.1 not reconize by Arduino IDE1.0.6
  179. Teensy USB driver for Windows Embedded 7 (WES7) ?
  180. Suggestion - how to make teensy much simpler
  181. LC Com Port issue - Unknown Device (Code 43)
  182. Blink sketch LED pin
  183. Teensyduino doesn't install libraries
  184. Wiznet W5500 support
  185. analogWriteFrequency bug
  186. Teensy Loader won't open 256k Hex File
  187. Misspelling of "TRANSMIT" in usb_desc.h caused a compile error.
  188. Small Bug in FreqMeasure_capture.h
  189. Problem with 1.6.4/1.23
  190. [Teensy 3.1] spi4teensy3 : Send and Receive at the same time
  191. Potential Error in LC Schematic?
  192. PJRC and Teensy(s) need a Wiki
  193. Suggestion: End-user friendly Teensy updates
  194. broader capacitive sensing
  195. Request: Castellated Edges on Teensy 3.1 PCB
  196. Forum search needs improvement
  197. Possible bug in usb_seremu_flush_output()
  198. Wiki Coming - Please link worthy posts
  199. Wiki Editors and Policies
  200. OS X 10.11 (El Capitan)
  201. IDE Serial Monitor button direct way to pick USB port
  202. Not Compiled for this board
  203. LC is 10.9 times slower than T3.1?
  204. USB type Serial + Keyboard + Mouse + Joystick -> Serial not working
  205. Arduino 1.6.3 & Teensduino 1.2.3 = too many files generated during compilation
  206. arduino compatibility, writing to serial monitor from setup does not work?
  207. Invalid Firmata library?
  208. Cxxmark Compiler Performance LC /3.1
  209. Audio Adaptor REV B - missing documentation
  210. Audio Adaptor - misleading schematic
  211. Arduino 1.65 & Teensydunio 1.24 beta3 Serial Monitor bug
  212. TLS library (for secure https)
  213. "Digital Input/Output" webpage needs a refresh?
  214. [Audio library] control_SGTL5000.cpp documentation / improvements
  215. USB Transmission speed
  216. reproducible "USB device not recognized" issue?
  217. Arduino 1.0.6/Teensyduino 1.24 compatibility with btmcmhan's t3spi library
  218. Teensy HID support in linux 3.x kernel needs CONFIG_USB_EHCI_TT_NEWSCHED
  219. ArduinoISP on Teensy 3.1
  220. Bug in teensy installer for arduino 1.6.5-r2
  221. ld returned 1 exit status
  222. Teensy LC and Arduino Libraries
  223. pwm synchronize with external event
  224. Arduino 1.65 "Export compiled Binary"
  225. Bookmarks menu
  226. OctoWS2811 with SD-Card on Teensy 3.1
  227. Windows 7 Driver Issues
  228. Teensy with built in Wifi Capability
  229. Teensy Hardware Flow Control RTS/CTS
  230. round bug
  231. PJRC website improvements
  232. DAC analogWrite Limitation
  233. Arduino version 1.6.5r4 not recognized by installer
  234. Why is this AVR-only code in the Teensy documentation?
  235. Teensyduino 1.25-beta 2 = compile error 'SerialFlash.h: No such file or directory'
  236. CopyFromSD should use a different CS with Audio Board (shield)
  237. teensyduino uploading to the wrong teensy if more than 1 teensy is connected
  238. serial_write_buffer_free return value calculation?
  239. Audio Library and SD Card Remove during Play
  240. Serial.available on Linux
  241. Teensyduino installer issue Arduino IDE 1.6.5 on Mac OS X Yosemite
  242. Divide Problem
  243. Teensy Pins only version?
  244. Suggestion: Teensy-LC SRAM size
  245. Arduino DUE Capsense -1
  246. SD Adapter schematics question
  247. Teensy LC 8 & 16 MHz Options
  248. Teensyduino 1.25 & Snooze library errors
  249. Kinetisk inconsistency?
  250. Weird behavior of TLC
