View Full Version : Suggestions & Bug Reports
Pages : 1 2 [3] 4
  1. Complete implementation of UART hardware flow control
  2. FastLed not compiling
  3. Can't install Teensyduino on 4K modded version of Arduino IDE
  4. Audio Shield Wave Player with Teensy 3.1 and Fastled --> flickering
  5. Thanks for the mobile plugin!
  6. Encoder library suggestion
  7. Teensyduino installation bug ?
  8. Audio Library - Possible Error in analyze_fft1024.h - read(binFirst, binLast)
  9. Teensey 3.2 Teensey Loader 1.24 Issues
  10. Autocorrelation audio module?
  11. Teensy 3.2 + audio adapter combined in one board?
  12. Why is debugging so expensive?
  13. SD Library fails to connect
  14. Bug Report Per SD Card Test Instruction
  15. Combine program and reset modes in current program pushbutton
  16. USB-MIDI freezing with El Capitan
  17. any change of using sdfat with the audio library?
  18. Probably should update all your servers to use TLS 1.2
  19. bug - teensyarduino install not working for arduino 1.6.6
  20. Keypad and Keyboard library won't compile using teensyduino 1.26
  21. problem/bug with DMAchannel.h, transferCount()
  22. Silly question regarding now()
  23. iFFT API in audio library?
  24. How to hook up the DAC port to a mono speaker
  25. suggestion: teensy 3.x usb device with serial nor flash
  26. Spam is getting out of hand
  27. Teensyduino & Arduino 1.6.6 = library confusion
  28. Teensy Card Getting Started
  29. teensybase.github.io
  30. "Bug" report (cannot access pde.jar during teensyduino installation) SOLVED [report]
  31. GCC 5.0 ARM Embedded available
  32. Can't upload any sketch on Teensy 3.1 using Linux (Windows 7 is OK)
  33. You-do-it Teensy 3.2 retail sale
  34. USB HID Touchscreen support needed
  35. [Bug?] No sound from buzzer in IntervalTimer callback function
  36. Arduino 1.6.7 & teensyduino 1.2.7: Error snooze lib on Teensy LC
  37. DAC/ADC reference inconsistency
  38. Faster Memset
  39. [FIX] Portuguese Keyboard layout for teensy 3 is broken
  40. Teensy LC : tlc5940 and shiftpwm libs ?
  41. Conflict using SPI library in and out a timer interrupt
  42. Serial.print a NaN
  43. analogWriteResolution applied to DAC
  44. 3.2 RTC Not working??? I really don't understand what I did to this thing.
  45. More RAM?
  46. Invalid URL on store cart page
  47. analogWriteFrequency() causes glitches output
  48. problems with teensy3.1 + serial on OSX Yosemite (10.10.5)
  49. Teensy with a STM32F405?
  50. MIDI Serial2 and pullups issue
  51. Any chance of a Teensy with USB pinout? (or without USB connector)
  52. porting advancetouchsensing to teensy3.1
  53. TFilter link is broken. (Audio design tool Description for FIR filter)
  54. Java error w/ Arduino 1.6.7 Serial Monitor, Raw HID, OSX 10.9.5, Teensy 1.27
  55. Optimized Interrupts for Encoder library not working after update
  56. Can write an INPUT HIGH but not LOW ?
  57. SPI clarification recent updates. Need for SPIslave library.
  58. Not able to create a file in W25Q64FV through Teensy LC.
  59. Teensy 3.2 bug with pointer/address comparements
  60. Please merge Adafruit_Neopixel to top
  61. compiling
  62. Improvement to Stream.h
  63. Gcc 5, flto
  64. problem with buttons and audio
  65. SPI problem
  66. Override core files on a per-project basis
  67. Bug in pins_teensy.c
  68. Missing declaration for Teensy3 boards
  69. Teensyduino installer support for Arduino 1.6.8
  70. Arduino 1.6.8, OSX 10.9.5 -> Build options changed, rebuilding all
  71. [Suggestion] Add Dvorak support
  72. XPT2046 touchscreen position jitter and lack of edge sensitivity
  73. Escaped Carriage Return in ILI9431 Libray "\n" doesn't advance cursor
  74. use structs for hw-registers
  75. Teensy Transfer Tool :: HID access to SerialFlash
  76. Big bug in Teensy_Reboot
  77. Idea/Suggestion: Teensy LC with 2 5V buffers (for APA102)
  78. Teensy 3.2 Extended Board
  79. EEPROM usage table
  80. Wish the code command (#) was on on the Quick Reply toolbar
  81. Who can type a script?
  82. Audio System Design Tool: Synth_ToneSweep time
  83. ICMPping library broken by latest release of teensyduino
  84. Missing serial data bytes
  85. Audio System Design Tool: Renaming nodes bug
  86. Possible Bug: PWM analogWriteFrequency function compile error
  87. USB Type Combinations for Teensyduino 1.29
  88. Problem with teensy3 Makefile using mingw/msys make under Windows - solved
  89. Ethernet Library Variable Chip Select/Reset
  90. Teensy 3.2 Reboot Hang when USB disconnected
  91. Memory usage inconsistency
  92. Fixes for compiler warnings in LedDisplay library
  93. Flightsim USB Stack, Teensy freezing
  94. Teensy 2 - Hardware Serial: Serial1.write() not as fast as Arduino code base...
  95. cores\teensy3\kenetis.h current one has lots removed?
  96. Bug in Serial.print?
  97. Error message installing Teenyduino on windows 10
  98. Missing #include in usb_serial.h
  99. Can't find OctoWS2811 examples in Arduino Software with Teensyduino
  100. How to request new USB configs?
  101. Teensy Wireless
  102. TimerOne -- setPeriod not working inside ISR function [Teensy 3.2]
  103. Suggestions for Prop Shield V2
  104. Switching between analog and digital input
  105. OTA Update Teensy by Radio (RFM69 / 95)
  106. Multiple Teensy Programming issue
  107. painful start: WinAVR, Teensy_loader_cli
  108. Mains noise problem and reduced sensitivity
  109. SpeedTest Encoder does'nt compile in Arduino 1.6.8
  110. Millis rolling over
  111. SUGGESTION: Making the Teensy Surface-mountable
  112. Build issue on Teensy 3.2 with U8G2 library
  113. Lost pixel on ILI9341 display
  114. How to submit a pull request for Teensy library DS1307RTC
  115. Something wrong with Adding a String to itself!
  116. Teensy version of Adafruit_ST7735 needs updating
  117. Add Image of RJ45 to OctoWS2811 Board
  118. A more correct bitWrite() macro in wiring.h?
  119. yield atomic?
  120. [Regression] Cannot use .S files (Arduino 1.6.9, Teensyduino 1.29)
  121. Nit pick on 3.6 kick starter maybe?
  122. Teensy 3.3
  123. Teensy 3.2 joystick with rotary encoders
  124. Teensy 3.5/3.6 Ethernet Wish List (PoE)
  125. Memory leak in Windows rawhid sample code
  126. New version (phone home) check
  127. ReadBytesUntil() Bug ?
  128. Bug in Accelstepper Library with using runSpeed and setCurrentPosition
  129. Teensy 3.5 / 3.6 Ethernet / mbed
  130. Teensyduino installer does not show Mapped Drives
  131. Teensyduino Installer
  132. Audio designer SGTL5000 autoVolumeControl function: error in code- Solution found
  133. rawhid_send on MacOS 10.11 working on teensy2++, not on teensy2
  134. USB "All of the Above" not working (Win 10)
  135. Teensy 1.30 uses discrete GPU in OSX Sierra
  136. dtostrf hangs with nan
  137. TimerOne library bug?
  138. teensy_gateway going crazy
  139. setPeriod does not reset TCNT1 for avr devices
  140. Teensy 3.5 help - where to look?
  141. Audio Designer Flange effect not working- solved
  142. Audio Designer won't allow you to IMPORT when using Win10& EDGE browser
  143. Teensy LC serial issue
  144. Teensy bootloader chip
  145. Spam postings within threads
  146. Crash requiring reprogramming
  147. Suggestion for announcements thread
  148. Thread safe and fast pin interrupt dispatching (attachInterrupt)
  149. Strange glitch when using PusePosition library to read Micro FrSky receiver
  150. Suggestion: Maybe add a few moderators...
  151. Perfboard for Teensy 3.6 and classic 3.2 shields
  152. usb sparking/shorting 3.6
  153. Teensy LC + Audio board DMAChannel error
  154. SPI library broken
  155. HOWTO: Store Projects settings (like F_CPU, USB, Keyboard-layout)
  156. Forum bug: PNG has the wrong extension for a JPEG...
  157. Suggestion: Serial Buffers
  158. Suggestion: Audiolibrary dependencies on sd.h, wire.h
  159. A tale of two Teensy's (Version 3.2)
  160. Video-Tags are disabled for "Project Guidance"
  161. Well duh, the Teensy 3.6 is NOT 5v tolerant
  162. Boards.txt lacks architecture def
  163. I2S custom speed
  164. Polymorphic Destructor issue in ILI9341_t3 class
  165. Matlab/Simulink Target
  166. Announcement thread for Teensydunio 1.31 seems to be missing
  167. Cayenne Dashboard for Arduino avalable - support for teensy is missing
  168. If it is possible to get a different color teensy audio adapter board?
  169. Suggestion: AudioMemory(x)
  170. All sketches lock up on Teensy 3.6 for me
  171. Teensy 3.2 Vusb voltage drop
  172. Blue Screen in connection with Teensy 3.1 and KORG SQ-1
  173. Suggestion for audio GUI with mockup
  174. BUG: PlaySdRaw on Teensy 3.6 -- crashes
  175. Suggestion: Not so teensy
  176. Gold flash on Teensy 3.2 holes
  177. Kali linux teensy issue
  178. Bug in Timelib timesyncing?
  179. Default hex file on SD Card to boot at start up
  180. teendy 3.6 addon board?
  181. Teensy with audio card does not play simultaneously 2 tracks when AudioInputI2S used
  182. RA8875 textWrite Problem :)
  183. Error reading teensy loader (LED EYE adafruit Projecte)
  184. Seek() within a wavefile ???
  185. [Linux 64bit][Arduino 1.6.13] Issues starting Teensy Loader and libusb-0.1.so.4 error
  186. Audio Adapter Line In level needs initialization
  187. Peak read nit-pick
  188. Update Teensy product page
  189. Bug in Teensy version of UTFT library & Teensy 3.5
  190. Serial monitor problems arduino 1.6.13/ teenly lc
  191. PS2Keyboard.cpp using millis() function
  192. Teensy Loader GUI doesn't work, but the CLI version does.
  193. KinetisSDHC.c clock setting error
  194. Teensy 3.6, after Reset SD Card does not always initialize.
  195. Snooze hibernate/deepsleep/sleep not working on Teensy 3.5
  196. Strange looking limit checks in Teensy3 Version of Stream.cpp
  197. Teensy Audio: AudioOutputUSB only working when combined with different AudioOutput
  198. Touchscreen library with different ADC resolutions
  199. Switch for 44100Hz
  200. Serial binary write byte order scrambled?
  201. Reset-Button in teensy loader
  202. Minor TimeLib bug... dayStr() returns "Jan"?
  203. Question re: Teensy LC Flash emulation
  204. Probable race condition in Radiohead library
  205. USB serial port teensy 3.5 device recognition
  206. Advanced Search warning messages
  207. Question to GCC experts
  208. My one great desire...
  209. Teensyduino 1.3.5 Installation Problem on MacOS 10.12.3
  210. Audio System Design Tool bugs
  211. Teensy 3.6 Not Responding
  212. Easy printing of 8-bit characters on ILI9341 display
  213. Teensy 3.2 USB Serial "non-blocking" write isn't really non-blocking
  214. Is there a "report thread as spam" feature?
  215. Arduino 1.8.1 Teensydunio 1.35 unable to modify core
  216. HalfKay cannot be entered from software consistently
  217. OctoWS2811 signal too low
  218. HardwareSerial* should pull in Print::write
  219. UDP Multicast issues
  220. Teensy 4.0 = Teensy 3.6 + wifi?
  221. Teensy 3.1 still working but stop loading sketches
  222. systick_isr() does not work fully
  223. Teensy Uploader Applet only works when visible
  224. Pen/stylus digitizer HID descriptor feature needed
  225. usbMidi Realtime messages without a callback function
  226. Teensy 3.1 PWM output jitters
  227. Flexcan bugs and limitations
  228. Why no substantial speed inscrease when switching from 24MHz to 72MHz
  229. exit status 1 Erreur de compilation pour la carte NodeMCU 1.0 (ESP-12E Module)
  230. How about a 3.5 inch 480x320 tochscreen display?
  231. MTP Responder Contribution
  232. Teensy driving led strip crashes when adding audio
  233. Basic Audio Compressor compiling error in Teensy 3.5
  234. Suggestions for the Audio System Design Tool
  235. audio lib generates more cpu overhead over time
  236. New Wire library is not supporting all of the valid SCL/SDA pins
  237. Specs for the 3.5 missing in the store
  238. References versus Pointers: with class objects...
  239. Teensy 3.5 at 2MHz / VLPR
  240. uncommented comment in usb.c
  241. TeensyLC / Teensy3.2: wrong SPI reads
  242. Teensy 3.2 with pin numbers printed on the board
  243. Bug in digitalReadFast()
  244. SMC_VLLSCTRL register is not found in K66 (Teensy 3.6)
  245. Request Teensy LC with More Memory
  246. serial_install.exe password stealer?
  247. DMAChannel is broken on Teensy LC
  248. delay() breaks within SPI.beginTransaction()
  249. Xplane Teensy 3.5 Issue
  250. analogReadAveraging works only for ADC0
