- Teensy versions badly named
- Cannot find binary 'arm-none-eabi-ranlib'
- Multiple ACM
- Suggest next Teensy with Cortex M7
- Issues with Teensiduino and Teensy 3.2
- map() function improvements
- Teensy freezes my computer when I try to upload code
- Request: update CMSIS-DSP (arm_math.h)
- 100microsecs hard delay on first transmit of USB character (Teensy 3.2, USBSERIAL)
- -Wextra
- Arduino Events
- Stratagies for code error detection and checking and recovery...
- -Wdouble-promotion
- Make teensyduino window easier to move.
- Thread notification confusion
- Fix for FlexCAN library provided with Teensyduino
- Bug: Audio board I2S input data randomly out of sync after program reload
- potential bug with wire.h, or just my ignorance
- Teensy3.1 / 3.2 + Octows2811 + 12V ws2811 strips RGB swapped
- Issues with tonesweep in audio library
- Audio tool doesn't export correctly when object names are changed
- Updates in MIDI Library, anyone?
- Alternate SPI pins on Teensyduino 1.37 not working
- Need to receive BMC encoded data frame 300kbps speed using Cortex M3 STM32F103C8
- minor typo in comment in WireKinetis.h (800 Mhz I2C bus freq)
- Serial Monitor does not open after Reset
- RawHID works after restart, not after programming/upload on macOS 10.12
- Memory leak in RawHID (hid_WINDOWS.c)
- Installer for udev rules in Linux
- DC offset removal noise/distortion in input_adc.cpp, input_adcs.cpp
- Additional fonts for ILI9341_t3 library
- Cannot program Teensy 2.0 with Arduino>=1.8.2 & Loader>=136
- usbMIDI library update
- Windows batch file needed
- PJRC Web Site
- Teensy 3.2 OTA update Slows down MCU -Flash_erase_upper()
- Bug in delayMicroseconds: 25% too short for const delay < 64us
- Force Rebuild button - or : Buggy cache system
- Minimal Blink fails with void yield()
- PS2Keyboard Library - Teensy 3.6 / LC
- forum private message quota increase?
- Reference Manual 3.6 newer Version REV 3
- Linux libudev versions
- Audio System Design Tool - Chorus
- Audio System Design Tool - Tonesweep - 4th argument in seconds, not milliseconds
- Possible bug with Wiz860io
- Bluetooth LE Teensy?
- Suggestion for the Envelope shaper
- "Error compiling for board Teensy LC"
- A argument for allowing counterfiets
- USB pen/stylus HID
- OctoWS2811 performance issues
- small bug in RHHardwareSP1I.cpp/h regarding Teensy LC
- Suggestion AudioPlaySerialflashRaw KEYWORD2 add to Audio library keywords.txt
- Debugging with Serial.print not working
- Insect in AudioSystemDesignTool when exporting objects with modified names.
- Insect in object AudioSynthWaveformSineModulated when no modulation input present.
- Insect in AudioSynthWaveform when WAVEFORM_PULSE selected -> wrong frequency.
- Proposition to change pulseWidth() behaviour in AudioSynthWaveform object.
- Teensy 3.5 I2C stops working after a while
- AudioSynthWaveform object, bug fix and improved phase behaviour
- Suggestion: Update Digital I/O page on webs site whet Teensy 3.x information.
- MIDI Controller I/O Shield
- Hosed Teensy 2.0 Bootloader (?)
- prop board will not callibrate properly
- Visual Audio tool suggestions: Comments and User Modules
- Teensy 3.6 Hardware Serial Issue
- More uniform APIs between MIDI, USB MIDI and USBHost_t36
- "while (!Serial);" USB Disconnect Issue
- Global config file inside project folder
- SerialFlash.begin always returns true, even when no SPI flash is connected
- Teensy Loader having problems on Mac OS High Sierra
- I want to give PJRC my money, not faceless corporations!
- Link to Teensy 3.6 glossy cheatsheet PDF from its page on the website
- TouchscreenUSB.release(finger), Touch freezes, bug with Linux??
- PJRC store corrections
- Bug in kinetis.h for Teensy 3.6?
- is 2 Mbaud supported on T_3.6 at 24 Mhz
- Serial options for setting and disabling timeouts
- New Bug in TeensyDuino 1.41
- Small issue with boards.txt
- Does the Teensy 3.5 have 256K of RAM?
- adc->setConversionSpeed(ADC_VERY_LOW_SPEED, ADC_1) isn't working for me anymore
- StartMillis not working when using touchread
- Including C++14 type_traits, algorithm, utility approx doubles compile time
- Help! Rgb led matrix display problems!
- Coding Style ... to encourage good practices
- encoder library: read without disabling interrupts
- Change in new Teensyduino version breaks existing code
- sizeof() bricks compiler somehow
- "Flight Sim Controls + Joystick" non-functional on Teensy 3.2 and 3.6
- Bug report - missing flexbus memory map definitions in kinetis.h
- Teensy_SerMon: Allow select and copy when offline
- Teensy 4.0 (hypothetical) pin assignments
- Suggestion: Optionally include custom USB Desc. header from user's project
- SPI speed on Teensy 3.5 is not correct
- Teensy 3.6 Expansion GPIO Board
- teensy 4 pad traces
- Suggestion for Ethernet Library improvement
- Teensy programmer time out
- 32 bit IOT Micros
- Compiler warnings for Snooze library
- My wish list teensy
- OneWire library does not work on analog pin, but OnWireHub library does
- AltSoftSerial Library in Linux
- SD library deemed harmful due to GPL license
- XPT2046_Touchscreen problems ...
- What if we could make a fully custom chip?
- Teensy 4 RTOS
- Suggestion - pinModeFast
- Teensy Loader high CPU usage
- Teensy USB Host Audio?
- How to create a third I2S tx rx channel
- Teensy 3.2 Plugin X-plane 10.51 Crash on Exit
- Audio play_qeue() documentation
- Teensy++ Upgrade?
- ADC library conflicts with Audio library dac output
- Drop support for very old Arduino
- compiler.cpp.extra_flags not working
- LTO fails (Arduino 1.8.5 & 1.8.7, Teensyduino 1.44) with certain libraries
- LoRa.h +Teensy3.5 = error
- Modification to udev rule
- Flash writes take time to stabilize
- Where do I post to get the website updated? - Recommend change to the Propshield page
- Teensy Loader is unable to read my compiled sketch (r)
- USB Host wireless mouse not working keyboard ok
- Problem with Teensy USB HID / Joystick implementation ?
- Add Xbox 360 wired USB controller to USBHost_t36
- Teensy 4? testing mbed NXP MXRT1050-EVKB (600 Mhz M7)
- Manage 256 LED pixels RGB by Teensy 3.2 suggestion
- Doc bug: Wire Library page
- Teensy 3.5 Not working
- Teensy Loader icon
- [Forum] Dark theme
- Keyboard timeout handling: bug?
- Suggestion. X-Plane Forum?
- BUG stale lock: Unable find Teensy Loader. Is the Teensy Loader application running?
- BUG: 1.8.8-teensyduino-1.45 compiler bug: insn does not satisfy its constraints
- Missing Auxiliary control register in kinetic.h
- Sharing Pins- Audio Adapter Shield- and Wi Fi Breakbreakout
- Teensy RAM Usage
- Teensy 3.5 real time clock problems
- Issues with Arduino connecting to Teensy Loader
- BUG - Serial 3 hardware flow control
- Possible errors in code
- FreqMeasureMulti and Snooze not working properly together
- I think Adafruit's "Adafruit_SSD1352" is out of sync with pjrc's Adafruit_SPITFT.
- Suggestion : Teensy OEM
- Garbage value on serial monitor using teensy 3.2
- SPI.begin() does not set Clock HIGH in SPI_MODE3
- Button, timeout and boot
- Teensy 3.2 and FASTLed
- FastLED not working on WS2812b LED strip (using teensy 3.6)
- "edit post" got a bug in android chrome
- suggestion for the pjrc documentation
- Compatibility with the flatpak version of the Arduino IDE
- 1.8V support for Teensy LC and 3.2
- External power and USB
- Pullup on serial RX lines
- Teensy 3.2/3.6 USB port unresponsive
- Intermittent loader issues
- Strange bug in AudioStream.h
- Serial Monitor missing data on some Macintosh computers
- AudioPlaySdWav DMA timing and buffer misalignment issues
- Serial1.end() crash in TD 1.46 but not in 1.42
- T3.6 crash when using Serial Port #6 for MIDI - after Teensy Damaged
- Looking for info on Serial MIDI Real-Time message support
- issues with recording
- ../tools/arm/bin/(build.command.linker) -- "file does not exist"
- Attention WINDOWS 10 Users
- Please add vid/pid for all boards or remove from teensy31 (boards.txt)
- TimeLib compilation-error ?
- Please make usb_keymedia_send() "public"
- Request to simplify Hardware Serial Example
- Added Modifier key support to KeyboardController in USBHost_t36
- Teensy 3.6 & 3.5 - IntervalTimer sketch crashes after thousands of activations
- Possible race Condition on Teensy 3.2 Serial when using Transmit Enable pin
- Teensy 4.0 product page on the website.
- Teensy 4.0 not on Products page
- "Right" way to submit bug reports
- Arduino UNO WIFI Rev2 with DS18B20 and library OneWire
- Arduino Library Ethernet 2.0.0 - Not Work!
- Teensy 4.0: Ethernet Library causing SD Errors
- Just a quick heads-up on tech spec page
- Suggestion for minor 3.x upgrade, 3.x.1 ish
- ST7735_t3 Bug introduced between 1.46 & 1.47
- Teensy 3.x UART configured with the PORT_PCR_PFE may limit RX / UART Speed
- Teensy 3.6 on ubuntu, serial monitor is not available
- A little "bug" in the usb_desc.h, very easy to solve
- Library documentation (particularly for Teensy 4.0)
- Teensy 3.6 linking fails for stdc++ containers
- Audio Library Examples and Teensy 4.0
- VS1053b Library and Teensy 4.0
- Teensy4.0 does not receive data longer than 62 characters
- Teensy 4.0 SoftPWM example fails
- When I use over 50% ram of Teensy 4.0 ... not working and.... can't read usb...
- Teensy 4.0 USB serial lockup
- Typos in Teensy>USB_MIDI>TransmitEverything
- Teensy 4 FreqCount compile error
- Teensy 4 FreqMeas problem ?
- Pins to bring out on a hypothetical larger Teensy4
- Teensy 4.0 Locks up sending udp
- T4 , set_arm_clock and micros()?
- FreqCount caution
- Unexpected T4 UART1 initialisation
- Teensyduino 1.48 does not create HID devices
- Error compiling for board Teensy++ 2.0 DISK SDCARD + Keyboard
- USB MIDI, any date?
- After installing Teensyduino, Mac "Arduino" would like to receive keystrokes...
- issue to reporogram T4.0
- Dynamic AudioConnections
- fill_raw_noise8 from Fastled library returns strange values
- Teensy 4.0 Clock speed influences delay and SPI
- Teensy 4 probs with >1MB elfs
- Win 10 and Teensy 3.6
- Interested in forking ILI9341_t3 to improve (reduce) some of the SPI transactions
- TD 1.47_b4 problem compiling audio library
- Teensy Loader problem on Ubuntu 18.04
- Interval Timer on Teensy 4.0 not supported
- Audio shield VIN output
- ReadTest example in DS1307 library doesn't compile
- platform.local.txt and boards.local.txt
- [T35] MTP - Can't read/write files in SD card through Windows 10
- SD - Open more than one file?
- Serial Monitor Bug - Prints own sourcecode? ;)
- Bugreport: Timelib
- A lot of confusion with the touch pins on the Teensy boards
- MTP with Teensy 3.2 and a SPI-connected SD Card (and also using USB-MIDI)
- Teensyduino and macOS Catalina file permissions
- Custom USB build option for Teensy Arduino IDE
- Any plans for a teensy 3.6 with the IMXRT1062 processor?
- Please update the standard Arduino MIDI library to latest 4.3.1 including PR#124
- Teensy 4 and TouchScreenUSB
- T 4.1 Layout/pinout
- Problem with compiler optimisatioon and sprintf
- With Teensy-LC, each display.display() call scrolls static frame right 1 column
- Blocked IP (sorry if it should be in other forum branch)
- Teensyduino 1.51 errors on compile, 1.48 does not; ADC class implicated
- ST7735_t3 broken with Teensyduino 1.51 install
- In ST7735_t3 : tft.Print and tft.Println do not print spaces
- RawHID.recv() hangs after updating to Teensyduino 1.4.9 or higher for Teensy 4.0
- Frequent calls to Serial.flush() can gum things up
- Teensy 4.0 in a form factor with castellated edges
- Broken on Mac: both Teensyduino and Arduino + Teensy
- Capacitive Touch Tutorial links to unknown page
- Teensyduino 1.51 - no communication to X-Plane
- Suggestion: Archive with older Teensyduino versions
- Teensy4.0 | TimerOne Library issue
- Time for a new Audiolibrary
- PWM with inverted output not working at extremes
