- SD.begin() fails if executed a second time
- teensyduino 1.51 on OSX causes arduino ide to crash after reboot
- sin, sinf, cos, cosf - strange timing results on teensy 4
- Bug report: Teensy 4.0 and AudioPlayQueue
- compile/optimize error?
- Serial.printf, sprintf, std::ostringstream not implemnte for floats on Teensy4.
- [SUGGESTION] Modulation/tuning input to string generator
- Teensyduino 1.51 crashes when installed on Nvidia Jetson Nano
- Suggestion: "Serial + Mouse" usb type option
- "Extreme" Joystick hat bug
- Missing "break"
- Clean-up suggestions
- Audio System Design Tool for Teensy Audio Library GUI [BUG]
- Web site could use a few updates :)
- [Suggestion] ATmega4809 teensy 2.5?
- "Blind spots" when sampling analog signal with Teensy 4.0
- Teensyduino crashes constantly on Catalina.
- Teensy 3.6 Encoder Pin sensitivity issue.
- IDE 1.8.12 and Teensyloader 1.52 with V4 and 3.2
- A punchlist for Teensyduino's included libraries would be very useful!
- Warnings to use Timelib.h instead of Time.h
- Teensy 4.0/4.1, USB Type option "No USB" not present?
- digitalReadFast sometimes takes ~1 sec to complete on Teensy 4.1
- TD 1.52 ATOD compile error for TLC
- Teensy 4.1 Ethernet connector + stacking headers question
- Bootloader
- teensy loader gobbling CPU
- Arduino compiler crashes on startup
- Teeny 3: USB Issues
- AudioStream.cpp & AudioStream.h - BUGFIX
- Teensyduino 1.52 breaks AudioOutputPT8211
- Serial.println cause an extra CR+LF line when Monitor contents copied to a texteditor
- Single Directional SPI DMA transmission built into the Arduino-Teensy API for Teensy4
- code generation bug? multiply affects later shift? (Teensy 4.0) can loop?
- Image upload not working on forum.pjrc.com
- Genericize FFT? Also window functions representation
- Forum posting date format is incorrect for locale.
- Wishlist: Card updates for T4 and T4.1
- AudioSynthToneSweep improvement
- Remove compiler warnings from libraries we ship
- Teensy 4.0 analogwrite minor bug?
- Adafruit_gfx, Teensyduino 1.53, Teensy 3.2
- Roland USB MIDI devices and T3.6 USB Host port
- Teensyloader 1.52 onwards breaks ChibiOS on Teensy 4
- More sophisticated envelope behaviour
- AudioStream source inhibit mechanism?
- SPI transfer16 bug
- phase modulation broken
- Teensy 3.2 UDEV rule on Ubuntu 19.10 does not work
- T4.x DMAMEM and RA8876 and SPI - (Paul?) - Large image does not display correct...
- GPS sensor (GY-NEO 6MV2) with teensy 3.2
- Add missing standard library to PlatformIO core for teensy31
- teensy 3.2 serialEvent3 read have bug
- new teensy suggestion
- Bug in usb_serial tx_benchmark.c file
- Usbhost_t36 is broken for bluetooth xbox one controllers
- Teensy serial Tool seems to crash iMac
- Serial.print interferes with Serial2.available on Teensy 4.0
- ADC broken in 1.53?
- IntervalTimer::update and begin documentation improvement
- Upload sketch to Teensy 3.6 crashes 2020 Macbook
- pinMode & initializer lists
- Teensy 3.6 not detecting MCP9808 sensor
- OctoWS2811 library version
- map() returns different values on arduino vs. teensy
- C++ template based AudioMixer
- CRC32 error with buffer size>= 64k
- Teensyduino 1.53 Compile error on Win7
- Teensy 4.1 ~ Frequency measurement and SD issues
- teensy_serialmon crashed my Mac (Catalina)
- PulsePosition not working
- usb host on teensy 3.6 midi devices serial Numbers inconsistent.
- Class String bug: c_str() method return a null pointer
- Support
- Logging to Serial
- Problem with Serial1 port on Teensy 3.6. I haven't had it with Arduino Due.
- midi poly pressure usb host issue
- teensyduino installer leads to CapacitiveSensor naming conflict on catalina
- "watchdog: BUG: soft lockup - CPU#3 stuck for 22s! [kworker ...]"
- Why does this code work different on Arduino IDE vs PlatformIO?
- Problem with Snooze Library?
- Error when shutting Windows 10
- Error detecting library fnet_serial.c
- Interrrupt typo on website
- Suggestion for improved interrupt management for teensy 4.0/4.1
- Recommend a new Teensy product based on new AVR series, AVR128DA/DB or AVR4809 line
- Maybe a UX change to "USB type" is needed?
- analogInputToDigitalPin() on Teensy 4.1
- Radiohead RH_RF69 hangs with SPI transaction missmatch
- Language Support: JavaScript, my thoughts
- DallasTemperature lib (DS18B20 1wire) fails when interact with UDP stack
- Teensy 4.1 and TouchScreenUSB as HID
- Teensy 3.2 not working with RA8875 display
- Teensy 4.1 SPI1 BUG at > 150MHZ
- Please make something wireless.
- Shipping with a Bootloader for SD-Card ??
- Problem with INPUT_PULLUP on pins 3 and 9
- PJRC / Teensy Logo ???
- teesny 3.2 serial and PWM problem not work
- OctoWS2811 with Teensy 4.1 Pinlist only supports 8 strips when using GRBW
- audio system design tool bug with DAC and PWM
- SNOOZE Kills EEPROM ACCESS
- teensy LC MIDI usb to serial and serial to usb... freeze.
- Several customers having problems with Teensy loader
- Is there a simple test for flash memory being soldered on the 4.1 correctly?
- "Smallest Code" optimization breaks EEPROM writes
- Can't Install Teensyduino Linux Mint
- Teensy 4.0 library issues
- Midi library V5 API
- Teensy 4.1 skimpy power supply
- Serial Flash file.erase() not working?
- Moderator Appreciation
