View Full Version : Suggestions & Bug Reports
Pages : [1] 2 3 4
  1. general Teensy 3.0 discussion
  2. Teensy 3.0 and EEPROM usage
  3. make generic "Forum" more specific to PJRC ?
  4. analogWrite(pin,255) outputs a lower voltage than digitalWrite(pin,HIGH)
  5. digitalWrite doesn't work after analogWrite on the same pin
  6. Adafruit PCD8544 LCD library
  7. OSX: Must launch Teensy app from within Arduino package
  8. BSOD when opening Arduino serial monitor, after USB re-plug and reboot
  9. Teensy 3.0 and interrupts
  10. SD issues on Teensy 3
  11. Porting Digole LCD library to Teensy 3
  12. Error compiling with Adafruit GFX library
  13. Teensy 3.0 Specs
  14. Serial data not being transferred?
  15. Forum SSL
  16. Help with ADC speed
  17. New forum Teensy 3 "Library subgroup" suggestion.
  18. Teensy 3.0 IDE: Two Suggestions
  19. analogReadRes function replacement
  20. Teensy 3.0 pinout PDF in easy to find place?
  21. Time examples have .pde extension
  22. Is library "Firmata" working on the Teensy 3?
  23. UART for development?
  24. avr/pgmspace.h: No such file or directory
  25. Serious bug corrupts heap in T3 beta7
  26. OSCuino library and SlipOSC support for Teensy3
  27. Forum search
  28. Link to arduino-1.0.2-teensy3-beta7-linux32.tar.gz is erronous (pointing to linux64)
  29. Teensy 3 fault handler demonstration
  30. Bug - Teensy 3.0 linker script causes .bss to overlap heap
  31. Teensy 3 halting debug enabled by default?!
  32. Problems compiling when using Servo.h, Teensy 3.0/beta7 Mac
  33. OneWire library for Teensy 3 (DS18B20)
  34. Encoder library not working?
  35. wiki?
  36. Bug - malloc()?
  37. Teensy 3.0 doesn't restart on serial monitor
  38. Windows 7 users - how long does reprogramming take?
  39. TimerOne library does not function
  40. T3 beta 8 regression?
  41. Teensy 3.0 serial monitor not working?
  42. Teensy3 usb_keyboard.c: keyboard_report_data[0] should be keyboard_modifier_keys
  43. Support for ATOMIC_BLOCK?
  44. Strange SPI error on Teensy3
  45. Pound sterling (currency) missing from Teensyduino British (UK) keyboard
  46. gentoo arduino 1.0.2 and teensyduino glitch
  47. memcpy_P missing from pgmspace.h for Teensy 3
  48. Observations on Teensy USB keyboard support
  49. Bug in usb_dev.c
  50. [PATCH] usb_serial.c fix for gcc const PROGMEM requirement
  51. Teensy 3.0 and USB MIDI (problem and fix)
  52. T3 SD USB support?
  53. suggest programming options
  54. Bug with SPI
  55. Teensy 3 "Cannot run program arm-none-eabi-g++"
  56. Problem with DEMCR in mk20dx128.h
  57. sscanf() problems on Teensy 3.0 & Windows
  58. Teensy AVR malloc does not work with schedulers and RTOSes
  59. Teensy 3.0 Serial.flush() does not appear to work
  60. Errors during code load Ubuntu 12.10 x64
  61. Compile-Error when wanting to use Adadruits SSD1331 with Teensy 3.0
  62. ability to define USB Vendor ID, Product ID, Product name from arduino sketch
  63. Teensy 3.0 brand new and loader program
  64. Suggestion: Subforum category for Teensy 3.0 working examples and projects
  65. Teensy 2 + Adafruit WS2801 Led Strip bullet + FastSPI example = LED OFF
  66. Teensy 3.0 i2c endTransmission() bug
  67. Compile upload possible problem
  68. Wire.() works on beta10, but not beta12
  69. Bug in Serial.println() ?
  70. FreqCount on Teensy 3.0
  71. Teensy 3.0 LowPower examples don't work!
  72. Wire/I2C doesn't allow more than 32 bytes written at one time (24LC1026 problem)
  73. Would be nice to have an RSS feed for the forum
  74. compile error on teensy 3 Ethernet example
  75. Alternate pin functions affecting other pins on the same port?
  76. AVR-like ISR()
  77. x-plane 10.20 64 bits
  78. Delay(0) - Teensyduino 1.12 - BUG?
  79. One function adds 21,736 bytes to total flash count?
  80. Serial.write(0x00) problem on teensy 3.0
  81. Unable to install Teensyduino 1.12
  82. I have a Teensy 2.0, and an idea for what I want to do in MIDI.
  83. Turkish Language Support
  84. Open Sound Control
  85. Suggestion for IDE folder structure
  86. Bugfix: Compilation fails using Keyboard.press(...)
  87. Have the IDE scan for teensy udev entries at startup
  88. Require new registrations to post sensibly before being umoderated?
  89. 3.0 Board Joystick Example Not Working?
  90. analogWriteFrequency and analogWrite rounding
  91. Encoder version 1.1 library with Arduino Micro(Leonardo)
  92. Teensy3 freezes (1) sending >8 bytes (2) with interrupts active (3) on Serial1
  93. "PS2Keyboard Library" - Problem with LCD Output for german special Characters
  94. Teensyloader in the background from the Arduino-IDE
  95. 84 by 48 LCD support (aka Nokia 5110)
  96. micros() bug?
  97. Teensyduino USB Joystick no-data driver problem/workaround
  98. Support for openSDA or CMSIS-DAP possible ???
  99. Teensyduino Joystick minor corrections to usb.c
  100. Additions to official documentation for the Teensy 3
  101. Off by one in delay() on Teensy 3.0?
  102. Code 43 problems on Windows
  103. USB Serial Receive Speed Improvement
  104. Pluggable 2.54 mm screw terminals
  105. Need help from code 43 problem
  106. Possible IntervalTimer bug
  107. Many axis joystick
  108. PS2 keyboard library and web page for Teensy3
  109. Possible bug with windows and a German keyboard layout
  110. Add additional AnalogWrite() PWM Pins
  111. Teensy 3 bug on 1.14rc2
  112. Teensy 3 issue with arduino compatible code
  113. bug fix for core function for Teensy 2.0++ in Teensyduino 1.14rc3
  114. Native support for Teensy 3.0 with Arduino 1.5 ??
  115. Compiler warning in usb_serial.c on teensy3
  116. Assertions don't work on Teensy 3.0
  117. remote programming with openwrt
  118. IDEA:portable binaries could be very usefull
  119. No Wake From LAN when teensy 2.0 (usb midi mode) is plugged in
  120. How do I load an example from the outside of Arduino example code library?
  121. Sabernetics I2C OLED display / Adafruit SSD1306 library problem
  122. Teensy 3 clock code change
  123. Teensy Loader gets slower over time.
  124. SPI register refs changed?
  125. Wish List: Forum support for user-contributed code/projects/examples
  126. "Error reading Teensy Loader status! (tr)This error should never happen."
  127. highlight sram overflow
  128. Arduino IDE mod
  129. USB MIDI missing feature: setHandlePolyPressure, *usb_midi_handlePolyPressure
  130. Request: add Keyboard.releaseAll() for Teensy 3.0
  131. Serial.write() on USB not doing transmit buffering of multiple writes correctly
  132. CMSIS-DSP library supports
  133. Teensy3 PROGMEM compatibilty issues
  134. Getting a way to detect data output completion
  135. windows dll for rawhid
  136. Serial Monitor Java Error
  137. I don't think critical sections work (interrupt locking)
  138. Many Thanks, keep on going!
  139. Teensy3 AVR port/pin compability macro defnition confusion.
  140. Unwanted messages
  141. Tutorial Request -Makefile , Non-Arduino Library/IDE programming...
  142. Request for Teensy 3 analog comparator library functions
  143. Teensy RawHID dll and feature request
  144. ADC problems in BSP analog.c I think.
  145. "char" implementation different on Teensy and Arduino
  146. analogRead() is not interrupt safe ?
  147. Suggestion - new sub forum section dedicated to IDEs
  148. teensy 3 missing implementation for set_media
  149. Bug in teensy3 HardwareSerial peek helper functions
  150. verbose errors during compiling (not an issue)
  151. Bounce library included with TeensyDuino - wprogram.h
  152. Ambiguity in MK20DX128 reference manual regarding second PDB channel
  153. Teensy and SerialUI library
  154. Unable to change my profil (avatar)
  155. Teensy 3.0: USB interface dead?
  156. PyMite (Python subset interpreter/VM) for Teensy3
  157. Improved Analog Input API (reqest for comments)
  158. Microduino style packing
  159. Teensy 3.0 serialEvent
  160. Fix for using math library without Arduino (compiling from Makefile)
  161. Z Axis broken in Teensyduino Joystick?
  162. How to add new Keyboard Layout to Arduino IDE
  163. Missing SPI_RSER flag definitions in mk20dx128.h
  164. warnings on other AVRs are errors on Teensy/Teensy++
  165. C++ constructors for static objects in functions don't seem to be called.
  166. Forum suggestion
  167. Czech keyboard
  168. Teensyduino 1.16 Makefile options typo?
  169. CAN Bus Library for Teensy 3.1
  170. New Teensy 2.0++ hangs
  171. OS X Teensyduino 1.16 installer missing button labels, text content
  172. printf() support in Print class
  173. Moving Code Libraries to Github
  174. Another library fails to compile… any ideas why?
  175. Serial_install.exe and windows drivers
  176. K20 Suggestion: Add peripheral base addresses to linker script
  177. Tiny Teensie
  178. Should SIM_SCGC7_DMA be changed to 0x00000002?
  179. Any Chance of a Teensy ++ 3.1?
  180. teensy 3.1 and Wire.h
  181. Teensy 3.* - Text rendering issue with RA8875 TFT display
  182. Teensy 3.1 does not see the TWBR emulation
  183. teensy 3.1 bug and vref
  184. Teensy 3.x Compiler?
  185. Cannot compile the one wire library with Teensy3.1
  186. "Please press the RESET BUTTON on your Teensy to upload your sketch." is all get
  187. Do VB tags work here?
  188. Teensy 3.0 Serial.available() bug?
  189. Bad batch of Teensy 3.0?
  190. Timer library
  191. TimeAlarms library
  192. Teensy Blink on Teensy 1.0
  193. Teensy 2.0 as USB keyboard wakeup device
  194. Teensy 3.x USB serial is fast, but I want FASTER!
  195. teensy 3 - Support for any consumer key
  196. Teensy 3.1 - 2mm edition
  197. IntervalTimer suggestions
  198. Serial + Keyboard broken in Windows 8.1 x64 (?)
  199. USB Serial format
  200. Encoder Library bug?
  201. Please consider adding a library page for touchRead
  202. Forum suggestion, new section on IDEs
  203. Hardware bug(?) feedback
  204. analogWrite() microseconds
  205. binary.h interferes with eigen
  206. Possible Priority Inversion with Serial1
  207. C# rawhid USB
  208. RF22 library support on Teensy 3.0 and Teensy 3.1
  209. possible bug - Teensyduino renaming Arduino version number
  210. Update links and provide navigation improvements
  211. Teensy 3.1: number of PGAs is actually 2?
  212. Teensy 3.1 microcontroller replacement
  213. Futuba s.bus library port
  214. teensy ++ 2 Ethernet DHCP compile error
  215. UDP doesn't send packet
  216. Teensy 3.0 /3.1 + W5100 ethernet shield.
  217. Teensy 3.1 Pin Assignments pdf
  218. movie2serial update for processing 2.1
  219. TeensyDuino 1.18RC
  220. Extra '}' in USBMIDI example on website
  221. RTC alarm demo
  222. PDB0CH1 register definitions
  223. EEPROM Library website documentation regarding teensy 3 not up to date?
  224. Problem with OLED 128x32 I2C
  225. Dead Teensy 3.1
  226. Uart confusion & a typo on pjrc.com
  227. Teensy 3.1 Underside Pad Problems
  228. Mac Serial and Upload problem
  229. not able to upload sketches anymore to teensy 3.0
  230. Dead Link
  231. Teensyduino1.18 won't install into Arduino 1.0.5-r2
  232. Request for carrier board
  233. Differences between Serial1 and Serial2 on teensy 3.x
  234. Teensy.exe force error pop-up window to top of windows
  235. Unexpected extra I2C cycle on Teensy 3.1
  236. static local variables aren't static
  237. CAN and CANopen
  238. Teensy 3.1 does not show up in Windows Device Manager
  239. Watchdog initialization problem
  240. Teensy 3.1 mouse resets to center of screen.
  241. NeoPixel version not up to date
  242. SetArduinoClock Win32 native Client
  243. nRF24L01+ / RF24 Library on Teensy 3.X - Doesn't link
  244. WinXP: Teensy 3.1 serial device goes missing after reset while Serial Monitor is open
  245. Teensy 3.0/3.1 Watchdog Timer Issue
  246. Serial1.flush() Problems
  247. Audio Library - Envelope Generator & Low-Frequency Oscilator
  248. Problems with HardwareSerial Pointer and write
  249. USB connector popped off.
  250. Arduino Smoothing example failing to compile.
