View Full Version : General Discussion
Pages : 1 2 3 4 5 6 7 8 9 [10] 11
  1. Solenoid Driver and EagleCAD Rendering Tutorial
  2. Wifi library on SPI2
  3. Hi there
  4. General purpose breakout for Teensy 3.6
  5. A.D.C Anti Alias Filter !!!
  6. 'NOT_A_PIN' was not declared in this scope
  7. generic Teensy "perfshield" ?
  8. Floating voltage (Wobbly axis)
  9. Lowering the power on the teensy3.2
  10. USBHost_t36 - Cable Matters HUB issues 2nd plug in.
  11. External RESET button - Teensy 3.2
  12. float or double for a teensy 3.2
  13. Hey, need help
  14. TCD1304 with teensy 3.2
  15. Double Insulator Pins 0.1 inch 2.54 mm spacing,
  16. TCD1304 with teensy 3.2
  17. How to disable the onboard LED w/audio board
  18. Need for help
  19. Need help to using USB serial communication...
  20. Microsoft is aquiring github!
  21. Using CMSIS Version 5.3 with the Teensy 3.6
  22. Perennial attachInterrupt in class / library problem.
  23. Stability of microsecond pulses
  24. MultiWS2811 - Simultaneously Control 128 WS2811/Neopixel LED strips
  25. Feedback Wanted: Teensy 3.2 "Stamp"
  26. Prop Shield Enclosure
  27. Problem with pjrc.com web pages
  28. Automotive grade Teensy
  29. need help?
  30. Easiest way to port teensy2.0 avr C code to teensyLC?
  31. Arduino 1.8.6 within the next 2 weeks
  32. SGTL5000 Audio board and Watchdog
  33. Multiple Ehternet Wiz820IO modules on Teensy 3.2 and 3.6
  34. Teensy 3.5, 16x2 LCD, and an HD44780 I2C backpack
  35. Teensy 3.6 data read from EEPROM at boot up
  36. unable to read serial data
  37. analogWrite to A10, A11
  38. change arduino editor text foreground color
  39. Wireless Communication between Teensy3.6 ad wireless sensor
  40. Access 16 bits of PORTD?
  41. New version of the I2C Encoder
  42. My recent absence
  43. Teensy 3.2 Timming inaccuracy
  44. I2S Input Quad BCK Query
  45. xBee for Teensy 3.6
  46. trying to run WS2812 with RGB and GRB ??
  47. Can I use modules bought from Adafruit and control with Teensy 3.6?
  48. How to program US Digital optical encoder kit with Teensy 3.5?
  49. Speed comparisons for Arduino Uno/Nano, Due and Teensy 3.5
  50. Teensy V3.2 - Boost PWM Output from 3V to 9V
  51. Propshield Orientation Rotation Backwards
  52. Teensy 3.5 Rover with Mavlink and APM Planner 2.0
  53. Teensy 3.6 "Pro" Feedback
  54. Cant compile teensy 3.2 on Win7 machine
  55. How do boot loaders work?
  56. Windows 10 RawHID Warning!
  57. Teensy 3.2 output range
  58. reference of the quartz on teensy3.2
  59. Teensy 3.1 issues
  60. 16-bit resolution using UART
  61. USB Host library current status, keyboard especially?
  62. Compliance issue
  63. Postal Priority shipping -- tracking?
  64. Microsecond Level Synced Clock
  65. Does CmdMessenger Run on Teensy?
  66. Great!
  67. Library for user settable values / settings
  68. UAVcan for Teensy 3.x Proof of Concept
  69. Teensy 3.6 DAC0 spike on startup
  70. Adafruit 1.54" Tri-Color eInk with Teensy
  71. PlatformIO small build for Teensy LC
  72. France: Giving away a T3.2 with pins but with torn off USB connector
  73. Seeed can bus shield 2.0
  74. Repairing a WS2812
  75. Teensy 3.6 UAS Flight Software, RAPTRS
  76. Teensy 3.5 working happily with RS485 transceivers at a baud of 9M
  77. USBHost midi questions
  78. Arduino CLI Alpha Release - Teensy Support?
  79. Can pins A4 and A5 for an alternate serial port?
  80. Teensy 3.5, overclock and SPI
  81. USB Device Not Recognized
  82. USB printer driver for Teensy 3.6 USB host port
  83. WS2812 + Octo + capacitor?
  84. Compiling Teensy Sketches with VisualCode (Win10)
  85. 5.8GHz transmitter only transmit when logic analyzer probes are connect
  86. Just have to say thanks! Thanks to PJRC & Paul for making Teensy product line!
  87. Yet Another Custom Teensy - Success - Round One
  88. Uploading "Teensyduino" hex file to a raw Kinetis microcontroller
  89. Teensy3.2 library
  90. new Teensy 3.2 blinks fine but no success uploading with HalfKay on Windows 7 or Mac
  91. Audio and MP3 player library questions
  92. [TIP] Three unique values from a single hard-coded input line
  93. Teensy Backpacks
  94. Thank admin!
  95. Reship from Europe?
  96. MusicWithoutDelay Library Supports Teensy 2.0 and Teensy 3rd generation
  97. OSC controller for Reaper digital audio workstation (DAW)
  98. return policy
  99. 440 lcd teensy 3.6
  100. Rootin Tootin Fast Pulse Shootin
  101. Question on a unblocking version of SPI transfer function
  102. Teensy 3.6 vs Teensy 3.2
  103. Teensy 3.2 with MK20Dx512?
  104. CMSIS-NN (Neural Network) Library Now Working on Teensy 3.6
  105. Github and pull requests
  106. Using Teensy 3.2 on I2c Wire1 (pins 2930) with SSD1306 Library
  107. Modbus TCP Example
  108. Teensy and Visual Studio
  109. Teensyduino Library complications
  110. Teensy 3.6 Power Problems
  111. Fastest usb uart bridge
  112. ADF4350 SDR Code Issues
  113. Teensyduino alternate ?
  114. Making a Cuckoo-Clock with Teensy
  115. I'm looking for a voltmeter & ammeter that measures the max amps
  116. Interrupt ISR bounces on IR sensor
  117. Modified-BMI160 (Accel/Gyro) ---BMM150 (Mag) -Teensy/AVR Libraries
  118. Connect two Teensy´s and Audio Shield via I2C
  119. teency 3.2 AREF pin
  120. Thanks to everyone who helped - Cosplay project was a big success!
  121. FCC Certification
  122. Pre-noob question, for USB host - Best Teensy to get?
  123. Great assistance!
  124. Teensy Beats Shield
  125. Teensy 3.2 Stepper motor with push buttons
  126. teensy 3.6 midi sysex and clock prob
  127. [?] Cross compiling bypassing completely Arduino IDE
  128. OctoWS2811 with CAN and RS485
  129. Teensy LC assembler - useful hints
  130. Fire (effect) on an APA102 matrix.
  131. dynamic backlight for picture frames "giraffe"
  132. Diagnosing cause of short circuit in defective custom Teensy 3.2
  133. micro_monitor - A Command-line Serial Monitor Project
  134. SerialLink
  135. Gameboy Audio Engine
  136. Simple SdFat write benchmark for T3.5/3.6
  137. NST3.2 (Not So Teensy 3.2)
  138. T3.6 + Arducam Mini2MP = recording 320x240 14 FPS on microSD :)
  139. arduino delay vs teency 3.2
  140. Floats... don't use 'em!
  141. Teensy 3.6 + level shifter + 2812B LED
  142. ublox library
  143. my teensy 2 does not work with teensy loader 1.4? why? and who has earlier version?
  144. Serial port opening more successful in IDE's serial monitor than in Max
  145. Use a pre-compile program on Tennsy 3.6
  146. Teensy Audio USB Volume
  147. Error compiling for board Teensy 3.6. Previously compiled program won't compile.
  148. ILI9341_t3 font editor
  149. BMI088 Library
  150. New Teensy 3.5 & 3.6 User Just Saying Hi
  151. Choose the right Open Source License
  152. Control input voltage to Teensy
  153. My Teensy 3.2 POV Clock Project
  154. Dimensions of board
  155. Function generator using teensy
  156. Half matrix display
  157. DemoCycle and Teensy 3.2 only works with 64 leds
  158. Led Art project using Bitmap and teensy 3.5
  159. Teensy 3.2 Artnet with 8 Strings of a 100, works great except 8th string is slow
  160. FastLED not working correctly w/ DemoReel100 over 64 LEDs w/ Teensy 3.2
  161. Cyber Monday Teensy Sale
  162. Analog read that won't slow down the main loop, is this possible?
  163. Bitmap with Teensy3.5
  164. Teensy (ATmega32U4) on-chip temperature sensor
  165. How do I prevent EEPROM from being overwritten bij Teensy Loader?
  166. New TeensyDMX 3.0.0-alpha release
  167. Arduino Serial Plotter 2.0 (update)
  168. Is there any need for a Remote Teensy API or a "Teensy on a wire" project :-)
  169. ADC0 teensy 3.2
  170. MIDI functionality on windows is MUCH worse than on OSX
  171. Arduino 1.8.8
  172. Can't install Teensydiono
  173. Electronics question. Why this blow up. No teensys involved
  174. Asynchronous (poll based) touch sensing
  175. Tiny bit confused about VUSB in the Teensy LC schematic
  176. OctoWS2811, Teensy 3.2, FastLED, and a button?
  177. USB Host Hardware for data logger use
  178. Teensy 3.6 Overclocked to 256 MHz
  179. RSS feed for blog
  180. USBHost_t36 working with PS4 gamepad in Teensy 3.6?
  181. ADC with external sync source
  182. TFT displays and interrupts
  183. Teensy Libraries
  184. Pushing firmware to Teensy 3
  185. about teensy board with an atmega32u4 upload problem
  186. Marlin / Teensy 3.5(3.6)
  187. C3 Protocol Generator
  188. Reading voltage from current shunt
  189. Teensy 4.0 First Beta Test
  190. Teensy 6 packs?
  191. Teensyduino IDE replacement
  192. Teensy++ 2.0 update via rs485
  193. General questions about Teensy 3.6 from a newbie
  194. TFT PWM Backlight
  195. 4MHz VLPR (Very Low Power Mode) should be possible on Teensy 3.6, not just 2MHz
  196. Arduino Music Player
  197. Teensy with Atmel Studio 7 + Visual Micro
  198. Teensy 4.0 Price & Specs
  199. Help writing a library (passing in an unknown structure for serial writing)
  200. Volume Discounts?
  201. Successfully created a jumbotron running glediator with ws2812b RGB strips, question
  202. Teensy Audio 24bit 48kHz qustions and more..
  203. lost setting 'Tools/USB Type' from Arduino Menu
  204. MaxMSP Gen & Teensy
  205. Teensy 3.2 with pins on the wrong side??
  206. Forth on Teensy 3.2
  207. 23lc1024
  208. Fast Digital IO on Teensy 3.6: Ports or Bits?
  209. ST7920 spi library
  210. Gurus for Hire? Need *really* fast Teensy 3.6 I/O and will share work product freely.
  211. Caltex SD Adapter and 23LC1024
  212. fake dupont/molex pins troubles
  213. How can I connect the audio shield with a d1 mini?
  214. 6 MKL04 Bootloader Chips for sale
  215. Chordboard Demo (my labour of love project)
  216. ADC performance, achieving 16 bits (or very close to it)
  217. Simblee Help.
  218. sm16703 led strips NEWBIE
  219. MIDI power stopping teensy starting
  220. Zeus Commander SPS-16, MIDI step & pattern sequencer
  221. Setting SPI clock for reading sd card
  222. Using DMA WITH DAC
  223. Limits of Fast, Precise Timing for Teensy 3.6 External ADC Data Acquisition
  224. Enclosures for Teensy plus DB9 connector?
  225. Teensy mouse library (re: absolute position, Teensy 2.0, etc) and system HID reports
  226. Where do i find the digitalwritefast library
  227. Teensy 2.0 as Fader MIDI Controller in iPad Pro 2017 (10.5")
  228. Teensy LC and I2C not working with another LC (works with Arduino UNO)
  229. More joystick axis
  230. How can I convert a string of "KEY_A" to the Keyboard.h KEY_A define value?
  231. New Scope
  232. Teensy 2.0 change MIDI name
  233. Teensy LC and using their 2 SPI connections.
  234. Teensy 3.6 power-up issues
  235. Connect Xbox 360 Wireless Receiver
  236. Watchdog question
  237. Whats the latest with ESP8266 + Teensy 3.2?
  238. Measuring ADC differential linearity
  239. New (possibly yet another) SLIP framing library, a Stream decorator
  240. Teensy usb powered + External power at same time?
  241. LIDAR Lite address move
  242. Midi 2.0
  243. I guess I must be getting better at soldering (or maybe not)
  244. GNU mini-gmp Library ported to arduino. Now I am able to genarate rsa Key(512) bits
  245. Teensy 3.2/3.6 using arm_neon.h
  246. dupont
  247. Teensy 3.5 vs Teensy 3.6 digital pins
  248. Encoder library help
  249. Joystick library question
  250. Binary Serial Data logjam
