View Full Version : General Discussion
Pages :
1
2
3
4
5
6
7
8
9
10
11
12]
13
14
- Hints on getting a Teensy 4.0 set up as USB Host controller
- TeensyLC Midi optical Pedals
- VMware to try stuff on Windows 10?
- Description of compile options
- Teensy 4.0 and SPI - problems with number of transactions in an interrupt routine
- Soft reboot on Teensy4.0
- T4 with 480x320 displays?
- SD card speed on Teensy 4.0 vs. Audio Board
- T4 DMA Buffer of data to a pin as serial data.
- Future Teensy features & pinout
- ChibiOS/RT RTOS for Teensy 4.0.
- Serial Data Transfer Library Finished!
- T3.6 and T4 Compatibility problem with XPT2046 and Audio Shield
- T4 ADC Library V0
- Serial0 vs Serial1 slow speed on Teensy4
- Teensyduino Bug(?): "Bricking" of T4 on program upload
- Does Teensy 4.0 have an analog ground pin?
- Teensy 4.0 Low Power
- Teensy 4.0 with Audio Board and ILI9341 screen wiring
- TeensyLoadcell Direct Loadcell Readout with T3.2
- Is there a third Teensy 4.0 breakout board?
- Buzzing noise with audio line input from cap sensors
- ili9341_t3 TFT library use
- Teensy 3.6 Wire3 Alternative Pins
- Did anybody use CAP1188?
- SD Card caused system failure
- Possible new shields
- Teensy 4.0 audio shield roll out
- Tennsy 3.2/ 4.0 programming with USB to Serial adapter
- Connect 5v signals to the GPIO of a Teensy 3.6
- T4 TimerOne vs TimerThree
- Will T4 support midi, HID etc
- Got a MIDI keyboard working with Teensy 4.0
- Bluetooth for sound streaming and data transfer
- Teensy 4.0 results in small enclosure
- MacOS 10.15 Catalina
- Why does the audio shield's headphone jack use a virtual ground?
- LittleFS port to Teensy/SPIFlash
- MIDI DIN in: Why is the PC900 optocoupler not recommend for Teensy 3.x anymore?
- Need to hire coding expert
- Flexcan - what does this line do?
- Teensy 4.0 CAN Development
- I2S for input and output
- Teensy 4.0 USB Host Mode
- MMAP an external SPI device on the T4.0
- questions for Paul
- Alpha: Arduino Pro IDE...
- Teensy 4 ordering of instructions
- Two bytes to floating point number
- How do you install FlexCAN_t4 library?
- New CD77 Halloween Fun 2019
- Teensy Serial Communication with Jetson Nano
- Teensy 3.6 COM Port Conflicts with Other Device
- Teensy to HDMI output
- Micro SD Card Adaptor HELP
- Fastest possible speed on IntervalTimer
- T4 FlexIO - Looking back at my T4 beta testing library FlexIO_t4
- Castellated PCB Pads
- Another Counting question
- Hi there from a n00b with unanswered questions for the past year
- PC Engine emulator, PSRAM experiment
- Multiple Teensy 3.6 and 4.0 USB Host
- Powering USB accessory
- Lots of buttons for x-plane
- T4.0 bytewide i/o ort
- Variable name stopping Switch from working - weird!!!
- Problem with battery charger for Teensy 4.0
- Chameleon Modular Synthesizer
- Announcing BMC, a MIDI Controller library with companion Desktop Editor!
- ILI9341 connections to Audio Board
- Don't assume random parts from your parts bin will work
- Display Panel Source
- Bigger LCD : is it possible ?
- Will there be a Teensy 4.0 on the 3.6 form factor?
- Teensy pinout card tip-of-the-day
- Teensy 4.0 DAC Pins? 34 35 38 39?!
- Can I "re-bake" Teensy 4 to surface-mount it on my PCB?
- Teensy 3.2 killed by failed upload
- Adafruit has discontinued selling the PJRC prop shields
- teensey4.0 question usb cable question.
- Teensy 4.0 USB Keyboard and HID mode support
- A microSD puzzle
- Multiple library found ?
- Is there a chip that combines both a single channel MOSI tri-state & CS pull-up?
- Teensy 3.6
- Teensy 3.6/4.0 and 2" TFT ST7789
- ArduinoGL (wireframe pieces using OpenGL) ported to Teensy 4
- A crazy idea for Teensy firmware updating
- Teensy 4.x H/W Quadrature Encoder Library
- New Adafruit stacking headers that will work with Teensy 3.2/4.0
- Teensy 4.0 and ILI9341_t3 libs
- teensy 4.0
- Bounce, responsiveRead and velocity for touchRead()
- examples: FASTRUN, PROGMEM, F(), DMAMEM ?
- Moving project to Teensy 3.6 or Teensy 4.0
- T962 reflow oven test
- Teensy 4 and LidarLite V3 3d Scanning.
- T3.x/T4 - Half Duplex support...
- Updated TeensyDMX library for Teensy 4
- RA8876LiteTeensy For Teensy T36 and T40
- sending data over CAN from teensy
- SlowSoftSerial library for slow baud rates
- Win10 & T4 Serial Communication Tests
- T36/T4 USBHost_t36 driver for Logitech F310 Gamepad
- MLX90614 isuue with Teensy
- Teensy 4.0 (3.x) using esp32 wifi
- Tutorial with Teensy LC
- Starting a simple midi controller advice
- compile options affects snprintf()--and in a bad way
- Interfacing Teensy 3.x to MPU6050/DMP using Jeff Roberg's I2CDev
- which Teensy?
- Teensy 4.0 and wireless programming?
- Qt for MCUs
- Audio board for Teensy4
- Teensy 4.0 fingerprint for eagle cad?
- Can't get the RA8875 BuyDisplay Resistive touchscreen to work with Teensy3.2
- Teensy 4.0 "5V in" not the same as "USB 5V in"? (no MQS Audio output)
- Sketch and code for guitar multi effects unit using Teensy 4.0 and Audio shield
- Super Easy Christmas Eve Challenge (strcpy)
- C++20 and MSVC 2019 support
- I2C Sniffer transition parsing problem
- Teensy 4.0 Eagle Library
- Teensy 3.2 Serial Initialization problem again
- Teensy 4.0 and TMC2130 StallGuard Sensorless Homing
- .NET Micro framework
- teensy 3.2 analog stick
- Using the I2S with Teensy4.0
- MP3 playing with prev/next 20,60 sec. skip.
- stuck writing a class that uses templates
- FastLED CMAS = FastLED complex multiple animations sketch
- SDIO Power drain
- Teensy 3.2 Continued
- Replacing Micro USB with USB Type C on Teensy
- Performance measurements with a logic analyzer
- CircuitPython port to RT1062
- Is there any Teensy 4.0 work that is in progress that I should mention?
- Teensy 3.6 SD card
- Teensy 4.0 vs PORTENTA H7
- USB Host on T4 - D+/D- pins work same as T3.6?
- FrequencyTimer2 Library and Teensy 4
- Experimenting with inlined bit-band access functions
- Teensy 4.0 Quadrature Decoder
- Funny comment heard on Adafruit's Ask an Engineer tonight
- CAN bus sporadic failure
- MP4 video decoding
- Teensy 4.0 : enable/disable Serial receiver
- Who has ESP8266 (WiFi) working with Teensy 4.0?
- Need help - Teensy 3.6 sine wave out SPI at a set frequency
- Teensy 4 Circuit Phython.
- CircuitPython on Teensy 4!
- HELP - I have two Teensy's with same COM Port Number
- Need help with battery charger
- Teensy 4.0 Compatibility with 1.71V to 1.95V
- Fun with ESP32 board.
- Teensy 3.6 are all UART ports the same?
- BOM Teensy 4.0
- Should some of our system libraries generate archive files (.a)?
- TeensyTimerTool
- What happens when AudioRecordQueue queue gets filled with blocks?
- Is there a hook to know when the on/off pin on the Teensy 4.0 has been grounded?
- error ordering
- Teensy I2C Sniffer for MPU6050
- Teensy 3.6 Watchdog Timer.
- Recovery after Download error
- Where are Teensy boards made?
- Splitting 5V Current between Teensy 3.6 and other components
- Schematic Capture and PCB Design
- Thank you.
- Teensy 4.0 + 4.3" Display
- Multiple Teensy and MIDI serial Tx Rx
- Arduino 1.8.11
- T4 w/ Encoder library differential signal question.
- To Infinity and Beyond Teensy
- usbMIDI.send_now() sometimes causes double send on Teensy 3.6
- Damaged my Teensy 4.0 :-(
- Muca Multitouch breakout
- Need a pjrc market executive to contact me please.
- Teensy 3.2 and VL53L0X
- Largest 320x240 TFT display
- Clang
- Low Temperature Operation
- Teensy 4.0 breakout with Feather Adapter
- How to use Teensy as USB HID proximity sensor
- MIDI Guitar Foot Pedal - Sanity check needed (possible issue freezing up DAW)
- Type of connector
- Spammers sending private messages
- TFT 3.5" display (320x480) ILI9488 or HXD8357D?
- 5V power out
- Question about Teensy 4 second USB port.
- Preview
- Platform IO / Teensyduino - No serial port listed
- Teensy USB drivers and Teensyduino
- 3D Rendering on Teensy
- use python to contro a display
- Power reduction with sync() when logging to SD
- Multithreading on Teensy 3.2?
- Arduino 1.8.12
- New ESP8266_AT_WebServer library supporting Teensy boards running ESP8266 AT shields
- Could use some help with networking, OSC and teensy!
- Lost Serial port
- MCU trends
- EthernetWebServer for Teensy, Mega boards using Ethernet shields
- digitalReadFast() why does it need __builtin_constant_p
- Blynk Support for Teensy boards running Ethernet shields
- New reference Manual Rev 2 for i.MX RT1060 : 11 Feb 2020
- audio library class
- Blynk Support for Teensy and Mega boards running ESP8266 AT-command WiFi shields
- Teensy 4 power management
- Wanted: best code fo detecting available devices in I2C
- Dynamic clock change issues on T3.6
- Hide Teensy from IDE Ports list
- 4.0 Flexcan with Interrupts Library
- Im a new guy that wants to buy a Teensy for THIS reason!
- Pre-processor math question
- teensy_loader_cli compile error using MinGW
- DS3231 - Extremely Accurate 32,768 Hz
- A newbie question teensy 3.1 and EFI lock
- Starting 1.52 Beta Soon
- Teensy 4 ADC hole of 7bits every 256 bit
- Teensy 4XWide/5.0 Dream
- Teensy Book?
- Spam in private messages
- RTC Teensy LC Low Power
- T 3.6 Audio library does not work with USBHost library
- Teensy 4.0 and CMSIS + SDK
- Cnc Grbl 1.1f for T4 imxrt1062
- Windows Communication to Teensy (LC Specifically) via USB Serial...
- Arduino-Teensy4 Teensy4 Expansion board
- connect the STONE display to the arduino
- Happy (belated) Birthday Paul Stoffregen!!!
- Teensy dev-platform 4.8.0 for PlatformIO is out! 🚀
- Teensy 4.0 Schematic Question
- Teensy 4.0 Fritzing part?
- New MCP23S17 Library
- New member questions
- attachInterruptVector(IRQ_CMP1,isr), how to write isr?
- Credentials/WiFiManager for Teensy, SAM DUE, SAMD, STM32 running ESP8266 AT shield
- Press Brake Controller
- Light Weight Credentials/WiFiManager for Teensy, SAM DUE, SAMD, STM32 & ESP8266 AT
- Teensy WIKI
- Teensy 4 and ILI9341 - Touchscreen is not working
- simulation for proteus Teency
- Looking for someone to do some Teensy 4.0 programming
- General Environment Questions
- Windows 10 app vs downloaded Arduino app.
- Wireless gaming mouse
- Teensy 4.0 Serial Number
- MSX2 emulation and mini-computer station with casing for the T4
- Backup Power for Teensy 3.2 for Power Failure and Brownout
- "Teensy 4.0 DUE+" breakout with 3.3v and 5v I/O
