View Full Version : General Discussion
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13]
14
15
- Teensy 4.0 librarys
- pinMode()
- COVID-19: A thread to share some thoughts and events
- Pigweed? Is this useful?
- BNO080 Observations
- How to setup TTL UART Serial
- 4.0 Restore Program Question
- Teensy 3.2 Snooze issues
- Linux/NetBSD on Teensy 4.0
- I want to save files to USB via teensy3.6 board.
- Soldering custom PCBs with 4.0
- Teensy 4.0 Recovery program in QSPI Flash
- WiFiNINA_Generic Library for WiFiNINA modules to support Teensy and more boards
- WiFiManager_NINA_Lite (Light Weight Credentials / WiFi Manager for WiFiNINA modules)
- Teensy 4.0 Boot loaders (USB-MSD, SREC, Kboot-HID, SD card) with AES256 encryption
- Teensy 3.6 and a Memory stick
- Error in Teensy 4.0 circuit diagram (?)
- How to access one SD card through 2 USB port on Teeny 3.6?
- How can I determine which Teensyduino I am using ?
- CORE_TEENSY define
- Code for Timing 2 Peripherals
- Ornament and Crime Audio Library support?
- UsbMidi not being received after start up
- LED Matrix driver for T4.0 using FlexIO parallel out, FlexPWM, DMA, & SmartLED shield
- Eagle library with Teensy 4.0 (test)
- Need help getting code to run on a mac
- Library for EBYTE transceivers
- X-Keys
- How to connect > 1 client to a serverusing an Adafruit WINC1500?
- Teensy 3.6 and usb can analyser
- USBHOST_t36 direct write
- Anyone ever use Teensy to update a Esp8266 via serial?
- Is Mikroe Rotary B Click compatible with latest Teensy?
- DoubleResetDetector_Generic library v1.0.0 used to reconfigure Credentials
- Teensy 3.2
- USBHost_t36 and sendPacket problem.
- Do I need pinMode for Analog functions?
- Encoder Library debounced
- Does Teensy4 have less program memory than Teens3.6?
- Teensy 4.1 Beta Test
- Ported a driver for a 7.84" 1280x400 bar-style IPS display
- Teensy 4 memory usage
- Programming Teensy from CLion with PlatformIO
- Teensy 4.x meets OpenGL (pseudo OpenGL anyway)
- Adrift in a sea of #ifdefs
- Teensy 3.6 with dual can bus adapter
- Teensy/Arduino Configuration Management Tool
- Any plans on releasing a variation of Teensy 4.0?
- Serialize large objects for storage on SD card?
- Teensy 3.6 vs 4.0: measured power draw at various MHz
- Coding Tricks - Reducing SRAM & CPU cycles
- Hat switches?
- Teensy 3.2 soldering jig
- Using DMA SPI Memory for Audio Library Objects
- What is Teensy 3.5 Default Clock?
- issue about teensy 3.2?
- Camera with Teensy4.0
- is it possible that we have an off-topic discussion area here?
- Future Teensies!
- Teensy 3.6 Setup/Teensy two problems before use
- T4.1 Ethernet board
- T4.1 Ethernet Library
- UGFX on Teensy using PlatformIO
- Malloc implementations for psram
- Teensy 4.1 USB MIDI Host device information
- Teensy 4.0 Snaffu
- Teensy 4.1: SdFat Beta only option?
- SPI PSRAM (4.1) availability in Europe
- Pin Out Cards?
- Teensy 4.1 - how many USB ports w/o hub?
- Alternative IDE Options
- Teensy 4.1 seconds interrupt
- Code speed secrets / optimisers
- Teensy continues flashing when PC is shutdown
- Teensy 4.0, MIDI, LEDs
- Teensy Production Volumes for Covid Ventilator
- clarification on Teensy 4.x qtimer
- Teensy 4.0 Schmatic wrong?
- Linux on Teensy 4.x ??
- Are there other stores that sell the psram chips?
- Acquiring/Sending JPG Snapshot from IP camera using Teensy 4.1
- array of Teensy solutions (e.g. for rackmount)?
- Teensy dev-platform 4.9 for PlatformIO is out! 🚀 Full support for Teensy 4.1
- Teensy 4.0 command line loader
- ICM-20948 Motion Sensor Library for Teensy (the newer+better MPU-9250)
- C++ Course/Tutorial
- Updating Design Tool for Teensy 4.0 & 4.1
- Teensy 4.1 not accessing a1-a17
- Amiga emulation on Teensy 4.1
- Teensy Register File Locations
- Teensy 4.0 and Wire2
- MTP Responder for SPIFFS
- How Does One Choose a Library?
- Need recommendation for a Beagle USB Protocol Analyzer to use w/ Teensy USB HID/Raw
- Teensy 4.1 Random Number Generator
- Program Teensy 4.0 With Java?
- How to use ethernet in Teensy 4.1
- T4.0 CAN-BUS Flashing
- WebSockets_Generic Library.
- SinricPro_Generic Library
- Please recommend soldering iron / equipment
- 3D Model for Teensy 4.1
- Hi all and question.
- LC: any way to get slower clocks as in T3.2?
- What is the R used for in a const char definition?
- Arduino Pro IDE and other IDE options
- Teensy DRV8825 Rotary Scan Table
- ILI9341 Speedup
- Combining FastLED and Other Functionality Simulataneously; Animatronics
- teensy_loader_cli issues with Teensy 4.0
- Utility to convert PowerPoint slides to ILI9341_t3 code
- Any way to access HTTPS secure web sites with a Teensy?
- Keyboard.press problems with Serial+Keyboard+Mouse+Joystick profile
- Teensy 4.1 WiFi (Howto)
- Having to reconfigure joystick often.
- Teensy 4.1, Ethernet Interface and SMB Server
- Using TFT Library with Teensy 4.0: How do I update only changed pixels?
- Teensy 3.x/4.0 CoreMark, Temperature and Power Benchmark
- AnalogIn + voltage divider (Teensy 3.2)
- Teesny 4.0 FPU
- Using GDB with Teensy without hardware debugger, first Beta
- Sig Gen Si5351 - 4 KHz to 100 MHz
- Arduino 1.8.13
- Teensy 4.0 power button and brown-out detection?
- analogRead
- Teensy 3.2 - WIZ850io Ethernet module - not working
- Run teensy3.2 with labview using command line.
- Teensy 4.1 USB Pads Tested
- Teensy 4.0 emulation of a Z80 computer running ZCPR3.3/ZSDOS with GSX colour graphics
- Redesign Teensy PCB on my own PCB
- Where to find i2c_driver.h ?
- Do you do copper fill on your PCB?
- Teensy 4.1 Ethernet and bandwidth delay product
- USB Class Definition for MIDI Devices v2.0
- Poll: Binary floating point txfr from t3.5, 4.x to host?
- NAND flash support in 1.54
- Teensy 4.1 NTP server
- New Teensy 4.0 DOA No 3.3V
- 2 questions about teensy 4.0/4.1
- T3.2 Hardware Serial RX buffer size change
- T4.1 Mechanical drawing, or Eagle lib
- Teensy 4.1 Based CNC Controller
- Lisp interpreter for the Teensy 4.0/4.1
- Audio System Design Tool update + AudioMixerX<n>
- Teensy dev-platform 4.10 for PlatformIO is out! 🚀
- High speed accelerometer data
- Over voltage protection for analog input on Teensy 4.1
- Teensy in a hacksmith video.
- UDP Ethernet Hangs randomly at Udp.parsePacket()
- (another) Animated GIF player
- Synth Panels Designer, FREE UI design software for synths, audio and more
- ST7735_t3/ST7789_t3 - LC Support Speedups?
- Teensy 4.1 - don't have +5V on USB host
- Teensy 4.0 4Mhz Clock Output
- Compact form Teensy?
- Delivery timeframes? (Yes I know - Covid!)
- Program Change Solution for 2 separate midi device
- Polarity Inversion for Teensy 4.0 FlexPwm
- "PrintScreen" and "DrawBMP" for ILI9341_t3 displays
- Cartesian graphing for ILI3941_t3 projects
- Ventialtor for Covid-19 with the Teensy 4.1
- USB panel jack
- Banned from the forums for more that a year now? Seems like whole Belgium is blocked?
- Use this FlickerFree library to get smooth text printing to displays
- BMC, MIDI Controller Library with Companion App Beta now Available!
- Midi Controller help needed, "On" and "Off" preset
- Teensy 4.1 Suggestions?
- Teensy 4.1 CSI Example
- Teensy 4.1 JTAG
- Fibonacci spiral LED sousaphone bell
- Single click build with Visual Studio Code and Visual Teensy?
- ECU running on Teensy 4.1 (and 3.5)
- Anyone using GitHub Actions for CI and PlatformIO?
- Backup Strategy?
- Teensy 3.2 programming reboot failed
- Schematic Review: Modified Teensy 3.5 Circuit
- A development/prototype board option
- Teensy I/O Processor for a Vintage Sharp
- What size pin / headers on this TEENSY 3.2
- Software to debug teensy hardware
- Winbond 25N01GVEIG memory chip wires to T4.0 Standard SPI
- Counting two interupt pulses at once.
- VGA library for Teensy 4.0 and 4.1(finally!)
- Small li-po batteries
- Parsing Video on the Teensy
- Newbie question
- ms timestamp since 2020.
- Which Teensy model or method supporting to upload program except USB?
- Processors not on a board
- Can you write unit tests for Arduino stuff?
- Tensy 3.2 hardware design for EasyEDA
- Teensy 3.2 Panel Mount
- Tensy 3.2 symbol and footprint for EasyEDA
- Need help to MIDI control ADSR envelope
- USB audio on Teensy 4.1
- Substitute Teensy 3.2 chip
- knobby is your midi buddy
- Teensy 4.1 RC transmitter - TBS crossfire
- audio teensy4_1 pt8211
- IDE colors and font size. How to change?
- Teensy 4.x max DMA throughput
- Shield around Teensy3.2
- 16 bit data bus
- DAC Output
- MySQL_MariaDB_Generic Library supports Teensy, nRF52, SAMD, etc. & W5x00/ENC/LAN8742A
- Teensy 4.0 Serial Working Differently on Different Devices
- Teensy 4.0 octo ws2812 sd card glediator/jinx
- Questions: TinyGPS on Teensy 4.0
- Please delete my account
- FINSHED Animatronics Project
- T4.0 debouncing interrupts?
- Teensy 4.1 - single wire half duplex UART
- Teensy 4.0 stepper motor library
- delay of nanosecond Teensy ?
- configuring and using video PLL on T4.1
- Teensyduino silent install
- How do microcontrollers not burn when directly wired to a potentiometer?
- Using Special Function Pins for GPIO on 3.2 with Audio Adaptor
- Ethernet native and timer
- Teensy 4.1 and ST7789 TFT display - which library?
- Utilizing a Teensy 4.1 for an in vehicle CAN data logger
- Teensy 3.2 DAC accuracy? Alternatives?
- 1Gb flash chip
- SPI on Sparkfun SerLCD
- Teensy 4.1 PWM frequency range and GPIO output current
- Arghhh, I need to get more organized
- Utilizing OEM’s GPS for embedded Navigation tasks with the Teensy 4.1
- New tool to test usbMIDI
- Teensy 4 Strange behavior unless global variables declared static
- New Teensys' mechanical sizes ?
- Nintendo Switch gamepad
- Simple multi-channel PWM
- i.MXRT1060's built-in graphics engine
- XInput (XBox 360) controller pass through
- 2820 LED Audio Visualizer Project Done
- T35 Low power difficulties / Snooze library example does not compile and unexplained
- Teensy 4.0/4.1 HOTAS Joystick
- Best way to reboot Teensy 4.x?
- Add Half Duplex support for HardwareSerial (T3.x, T4.x, TLC)
- MAX11300 ADC DAC and Teensy
- Teensyduino Favorite board config?
- LED light on pin 13
- Teensy 4 SD card and WIZ820io not playing well together
- PM2.5 air quality monitor - Oregon fires
- IntervalTimerEx - Callbacks with state
- Teensy 4.1 Stereo + Analog in possible?
- Continuum - Slow Motion LED Art Display
- LCD/TFT Graphic controller
- Which ILI9341 library to use for T4.x?
- teensy_loader_cli executable for windows?
