View Full Version : General Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15
  1. Gameduino HDMI board launched on crowdsupply
  2. FastLED with Teensy 4.1, fast parallel / DMA output on any pin
  3. Teensy 4.1 compatibility pin with teensy 3.6
  4. Teensy 4.1 Joystick Support
  5. Teensy 3.6 Maximum CAN Bitrate
  6. Clarification on open source license for the teensy librayr
  7. How to watch for out-of-memory errors?
  8. Linear Voltage Regulator for Teensy 4.0 Breakout Board
  9. circuitpython external psram and flash support
  10. Noob question about Eeprom "emulation"
  11. What is the difference between Teensy 4.1 from SparkFun, Adafruit and PJRC direct?
  12. Noob question: Measuring Teensy 4.1 CPU and RAM utilization
  13. Teensy Native Ethernet as DHCP Server
  14. Teensy Integration with the Arduino Pro IDE
  15. Teensy 4.0 : enable/disable Serial receiver
  16. SPI WiFI Module recommendations ?
  17. ICMP Ping on Teensy Ethernet Library
  18. Where to start with embedded programming
  19. New Programming Resource
  20. Narrower head for Ethernet ribbon cable
  21. Teensy 3.6 Self programming/in field update
  22. Can output pins be set to HIGH/LOW externally safely?
  23. Teensy 4.0 + 8 ADCs + GPIO extender = Voltage Level Translator/Shifters?
  24. ILI9341 simulator (worth about as much as you paid for it)
  25. Wiring for multiple piezo triggers
  26. Eagle Schematic/library for the Teensy 3.2
  27. SPI spi1 pins work around
  28. Encoder PaulStoffregen
  29. Problem with external powered Teensy 4.0
  30. PINOUT of the MK20DX256VLH7 on Teensy 3.2 and Eagle Library
  31. Challenges with wire.h and i2c_t3 after migrating to 1.8.13 Arduino
  32. malloc/free for EXTMEM and DTCM
  33. Teensy 4.0 and non DMA I2S transfer
  34. Teensy 4.0: Sending MIDI through USB
  35. Teensy 4 is really really fast ! :-)
  36. Mimxrt1062dvj6a
  37. What does this code do/mean.....
  38. Tweensy 3.2 + OctoWS2811 simply images
  39. ILI9341 seven segment font
  40. Bare-bones flight controller/stabilization package for tinkerers
  41. Teensy 4.1 based CNC machines.
  42. a float = 223.98 prints 223.9799957
  43. PIN_Dx definitions are causeng errors
  44. Sparkfun new QWiiC shields...
  45. Teensy 4.0 as a slave
  46. T4.0 IntervalTimer question
  47. ILI9341 font background
  48. compact 4cm x 6cm protoboard layout connecting lcd + audio shield w/ spdif & line i/o
  49. 3.5'' TFT 480x320 ILI9341 Display with Teensy 4.0
  50. Tri-state buffer, on all MISO lines?
  51. Teensy 4.0 external power supply
  52. Teensy MicroMod
  53. TFT MISO issues continue
  54. What type of cable to use
  55. Dynamic allocation of audio objects
  56. std::chrono compliant, teensy_clock based on the cycle counter
  57. Reproducing Teensy 3.6
  58. Pretty cool that the Stuff Made Here guy made a Teensy plug in his robot hair cutter
  59. Teensy 4.1 32 pinout led driver board
  60. Newbee question about Set time example TimeTeensy3
  61. A new Teensy with built-in audio..?
  62. Waveform phase problem
  63. Connecting a USB active HUB to the Teensy 4.1
  64. File abstraction and SdFat integration
  65. If (Serial.avaialble() ) never becomes true
  66. Thinking of getting VisualMicro...
  67. Keeping a TFT display refreshed while doing other things asynchronously...
  68. Using ILI9341 TFT display with MOSI1/MISO1/etc...
  69. Beware! T4x RTC power consumption
  70. Simple/cheap PCB creation on Linux
  71. Frame buffer for Adafruit_GFX based displays
  72. Which Teensy board is best for multi-channel high-frequency measurements?
  73. Customer site Firmware Download
  74. Oled i2c
  75. Interrupts and Priority, missing function calls
  76. Instructions for installing CMSIS (ver 5.7.0) for Teensy 4 (and 3)
  77. RA8875 Layers
  78. T3.x/LC - SerialX - Adding support for addMemoryForRead/Write ...
  79. Max File Size Readable by Teensy 4.1 Built-In SD
  80. Teensy 4.1: unable to flash / not switching to program mode
  81. mimic guitar strings strumming: piezo or capacitive
  82. Making Teensy-4 and an ST7789 240x240 display work.
  83. canbus problem flexcan teensy 3.2 multiple id streams
  84. Teensy 4.1 Based CNC Controller on Hackaday.
  85. IP range banned/blocked?
  86. Read ADXL1005 and show g values
  87. Using Teensy 4.1 without Arduino
  88. Adding an optional global config.h file per sketch
  89. BGA Decoupling Capacitors
  90. Transmitting voice massages from any device to portable cam
  91. Flight Sim Controls and VS 2017. Microsoft FS 2020
  92. Ring LEDs + Teensy 3.2 + FFT Fun
  93. New Supplier for Teensy - ProtoSupplies.com
  94. Teensy 4.1/4.0 with external ADC using SPI
  95. Stuck figuring out how to pass an array of char to a library
  96. Teensy 4.1 Adafruit TinyUSB Support
  97. multiple mdns services
  98. Roadmap - Clipping Detecton & Reporting
  99. Snooze Wake-up Recovery Times
  100. Apple's new M1 (ARM based) Macintosh
  101. Yet another highly optimzed ILI9341 library: for T4/4.1 with diff updates and vsync !
  102. FreqMeasure - minimum Pulse width
  103. Teensy 4.1 + WS2812Serial + FastLED + Serial8 = CRASH
  104. Sdfat-beta now ported to USB Mass Storage devices two ways
  105. This is really bad!
  106. Cannot readPixel with 3.5" TFT display, even with added tri-state buffer
  107. ARM Cross assembler for FASM?
  108. TeensyThreads, threads.addThread() , how to send multiple args to the function ?
  109. MIDI Control Surface - Guitar Pedal Board
  110. Teensy Logging to Serial
  111. Is the Mandalorian's Razor Crest flying on a Teensy?
  112. T4 Pixel Pipeline Library
  113. What's happened to the list of Distributors
  114. GC9A01 round spi display
  115. Notifications for new releases of Teensyduino?
  116. Controlling ligh..ts with teensy 2.0 and USB
  117. Videos of Teensy 4.1 running LVGL GUI demos
  118. Play video using Teensy 4.1, internal SD card and ST7789 LCD TFT
  119. manual Tutorial that show steps to get circuit-python installed on a teensy 4.0
  120. Writing to EEPROM together with downloading the Sketch
  121. teensy 3.2/3.1 Problem...
  122. Teensy 3.x Global Pin Control (Low~High) Register; PORTx_GPCLR ~ PORTx_GPCHR How-to
  123. best place for step-by-step tutorial w.screenshots how to install circuitpython
  124. MIDI + HID Keyboard at the same time?
  125. Infrared temperature sensor
  126. [Teensy 2.0] Basic question to include a buttonmatrix in the standard joytemplate
  127. Wow to write to the status window
  128. Is anyone aware of neopixels (SK6812 or similar RGB Leds) PC GUI to edit/control?
  129. Teensy 3.6 and FSEC security register
  130. USB-C for Teensy
  131. USB Audio for Teensy
  132. Ethernet Library & Wiz850io - How to reconnect after cable pull WITHOUT power cycle
  133. PSRAM for teensy 4.1
  134. Teensy boards in VisualStudio code - possible??
  135. Teensy Board Technical Information and Schematic pages : New Info
  136. Teensy CV input and output for eurorack modular synths.
  137. Serial.addMemoryForWrite
  138. Experimental MicroMod "T3.2" board
  139. Question about digital(Read/write)fast
  140. T4.x Cores debug printf...
  141. Tutorial on DAC DMA with PDB for Teensy 3.6
  142. 4.1 Flash memory location address and Memcpy issues with 4.1
  143. SDFAT read/write example
  144. teensy audio library with micropython and esp32
  145. Teensy 4.1 Pins used by Ethernet
  146. Rawhid & SPI problem
  147. grblHAL on a Teensy 4.1
  148. Do I need to create my own libraries?
  149. Teensy SSB with EER
  150. Library Error and Status
  151. what pin is onboard led on on 4.0
  152. T3.6/T4.x USB Host Serial and maybe Serial Emulation...
  153. Teensy 4.1 to obtain 'serial server' - how to proceed ?
  154. Best way to learn Teensy
  155. EncoderTool Problems
  156. Proper ways to program ILI9341
  157. Spam increase (December 2020) & anti-spam efforts
  158. Low power operation
  159. JPEG Compression for OV7670 images
  160. const vs constexpr vs #define and inline functions
  161. How to: FastLED with TeensyDMX
  162. Audio Adapter Board for Teensy 4.0
  163. Happy Holidays!
  164. Teensy 3.6 Fast pinMode alternative?
  165. Does anywhere sell Teensy with pre-soldered USB host pins/other ways to avoid solder?
  166. Teensy 4.1 + Circuitpython + Ethernet
  167. PoE board solution for Teensy 4
  168. T4.1 External USB C Connector
  169. Fishing for Teensy > nRF24L01 > iphone + MATLAB signal path
  170. USB-C Adapter
  171. How to print 64bit float in teensyduino for teensy 4.1
  172. Teensy Loader Win10 binary and VS2019 Project
  173. Happy New Year
  174. Teensy LC on external 3.3V supply?
  175. T4.1 castellated memory extension and memory plug in..
  176. 240x320 TFT display working fine now solid white permanently
  177. T4.1 and free memory
  178. Audio System Design Tool++ update
  179. MCL65+ 6502 Accelerator Board
  180. teensy amount of quality
  181. Teensy 3.2 PWM pins and IntervalTimer Issues
  182. Can I use a 10 bit data type for ADC storage?
  183. Is WS2812 the same as WS2811 or PL9823 ?
  184. Help getting BCR2000 working in USBHost_t3.6
  185. Teensu 3.2 I2C issues
  186. USB host num lock differences between keyboards/numpads.
  187. Arduino IDE extensions/plugins
  188. Is Teensy USB MIDI slow?
  189. My latest Teensy 4.0 MIDI project is done!
  190. Teensy 4.1 usbMIDI connected to Teenst 3.6 Host Port not working.
  191. Interest in motherboard with power/CAN/RS485/IMU/Analog IN/Encoder/...
  192. SdFat DMA over-clocked 3 Msps ADC logger
  193. TimeStamping images
  194. ILI9341 Ethnocentric Font
  195. program teensy 4.1 though pins?
  196. ILI9341 Color Values / grayscale..
  197. Teensy 4.1 USB Host port with no 5V on VIN?
  198. Biped Robot, Teensy 4.1, 6 Odrive's 12 Brushless motors 56v
  199. Simple sine wave generator with two DMA channels on T3.5/3.6
  200. Video test
  201. Raspberry Pi Pico
  202. Linux on Teensy 3/4?
  203. Teensy4.1 intall does not work
  204. Enable Continuous Integration with arduino-cli for 3. party libraries
  205. MIDI controlled analog synthesizer
  206. T41 SD card port as periferal interface?
  207. Ili9341_t3n, speed tests and crappy cables.
  208. TeensyStep RotateControl with 0 as parameter
  209. Macros for memory location (T4/4.1) ?
  210. DCC++ for Model Train Control with Teensy 3.x and Teensy 4.x
  211. EAR FOR T4.1 at Mouser
  212. Teensy 4.1 Threading w/SD logging
  213. tgx: a 2D/3D graphics library for Teensy.
  214. SPI bus management
  215. 100 Watt custom rotary laser etcher, Teensy Driven!
  216. Teensy 4.x interrupts
  217. Teensy 4x + bluetooth SD card
  218. Serial plotter and monitor don't work while using sbus
  219. Update teensy cores on Teensyduino
  220. Serial problem while using SD card
  221. Best method to stream data from USB HS?
  222. T4.0 ISR Rising Edge Voltage Trigger Level?
  223. Using multiple USB Types
  224. Teensy 4.1 flash memory support (LittleFS)
  225. Teensy 4.1 Debug Mod Project
  226. suggestions on a Linux distro for older computers?
  227. Bootloader soldering with a DIY hotplate
  228. Updated SoundFontDecoder
  229. 5V Teesny 4.1
  230. Slide Show now sends to PC
  231. Teensy 4.1 pinout
  232. How much RAM? Teensy 4.1
  233. Where can I buy a 24Pin female pin header for use with the teensy 4.1.
  234. Teensy 4.0 Breakout boards
  235. SD card adapter for JTAG on Teensy 4.1
  236. SBUS.h usage best practices?
  237. Teensy PC fan/RGB controller
  238. Teensy 4.1 vs 3.6 -- Thermal Performance Data
  239. Micropython
  240. Unable to use T4.1 with external power
  241. Simple oscilloscope routine added to modified WAVEFORMMODULATED example
  242. FPGA DIMM board?
  243. Teensy Freeze?
  244. Many TLAs: MTP MSC FS SD SDFat LittleFS UsbMSCFat to work with each other 8)
  245. MIDI Feedback Loop Detection
  246. Getting product support?
  247. Wire.setSCL failure with Teensy 3.5
  248. USB Host - shielding - connect to GND or not?
  249. Re-enable bootloader interrupts after a hard fault [Teensy 4.1]
  250. Charlieplexing: Issue, do all pins have pull-up resister?
