View Full Version : General Discussion
Pages : 1 2 [3] 4 5 6 7 8 9 10 11
  1. No news about Audio library ?
  2. Minimal Config and Code Audio Board+Teensy 3.1+Microphone input for FFT
  3. simplified (Teensy 2.0 only) WinAVR for MinGW/Msys under Windows
  4. Q for a NOR flash expert
  5. Source for teensyduino utilitues "teensy_post_compile" and "teensy_reboot" ?
  6. SdFat on GitHub
  7. USB power gauge vs. USB cable types
  8. 256 microstepping example for stepper motors
  9. A (mostly) working demo of OctoWS2811 + audio adapter
  10. ChibiOS or Nuttx?
  11. Flummoxed
  12. Build/upload source code with PlatformIO
  13. ChibiOS/RT 2.6.5 RTOS for Teensy
  14. [Teensy3.1]:[Modbus] Communication Issue
  15. Another easy and fast way to connect Teensy 3x to the Internet.
  16. Question re ADC References
  17. Interrupt priority for attachInterrupt?
  18. smalll serial debugging snippet
  19. FreeRTOS 8.0.1 for Teensy 3.x, Due, and AVR boards.
  20. Teensy 2.0 to make a Sip-and-Puff work alike
  21. Help for disabled / grayed-out Next button
  22. Samsung S6D02A1 driver
  23. Bitband performance?
  24. Off topic- Linux question
  25. Why does SPI.beginTransaction have settings as an argument?
  26. How do you film LEDs????
  27. My Teensy 3.1s are awesome [random praise]
  28. 240x320 LCD Display
  29. Software SPI for use in SdFat and interrupts
  30. Teensy crashes while playing audio (3.1)
  31. My hackaday astronomy project
  32. Appallingly small LiPo charger add-on for Teensy 3.1
  33. How to learn Arduino / How to Learn C
  34. Forum slowness or not responding, Aug 21-??, 2014
  35. DmaSpi for teensyduino 1.20 RC2
  36. Why are display and drawing libraries not developed separately?
  37. Simple Karplus-Strong
  38. SdFat beta with SPI transactions and Software SPI for Teensy 3.x
  39. C++ question
  40. POV with OctoWS2811 not working
  41. Adventures in color type conversions (fun with templates, anyone?)
  42. sscanf produces unpredictable results
  43. ty, a command-line Teensy manager
  44. More hilarity re: creating a TXCO
  45. How to use FastLED to show texts and movies
  46. Sheer genious!
  47. Teensy project template for Eclipse 4
  48. C Forth for Teensy 3.1
  49. Renaming teensy 3.1 on usb serial port
  50. Teensy 2.0 burn bootloader
  51. Random thoughts on code bloat
  52. Theremin Teensy
  53. Frequency Locked Sine Wave Generator - Teensy 3.1
  54. Question about LED Voltage and the Teensy
  55. New Teensy 3.1 Projects To Share
  56. Objective C on the Teensy ?
  57. Teensy3.1 Got Heated and stopped working
  58. Zmodem transfer from Teensy to PC
  59. I woke my Mac from sleep with a teensy 3.0
  60. What is the max output frequency of analog ouput Teensy3.1?
  61. OctoWS2811 Teensy 3.1 Flickers madly, Teensy 3.0 doesn't.
  62. Free music files?
  63. help storing a large array of strings in the Teensy 2
  64. ESP8266 Wifi chip for $7 $USD
  65. So i'm trying to make a RGB matrix
  66. Bluetooth module and Teensy 3.1
  67. Nice article, Oct. issue Nuts 'n Volts - Craig Lindley - with kudos to Paul S.
  68. SSL / HTTPS - not on Arduino Yun....Teensy?
  69. Best External editor for teensy 3.1?
  70. Possibility of Remote software/firmware upgrade.
  71. Teensy 3.1 and HC-05 : bi-directional com with other device and AT commands?
  72. DIY USB MIDI controller MPC style - Compatible with Audio Adaptor Board
  73. Hardware Quadrature Code for Teensy 3.x
  74. Scoped SPI transactions
  75. Arduino to Teensy 3.1 conversion problem?
  76. Teensy 3.1 and java USB reader
  77. New kind of micro controller developer environment
  78. FFT256 needs 23 ms on Teensy 3.1 @72Mhz ?
  79. Teensy 3.1 + Audio Board: Who turns on the onboard LED?
  80. Overclock Teensy 3.x using Visual Micro and Visual Studio
  81. Happiness with PCB Fab House
  82. Books specifically for Teensy IC?
  83. [Project] Teensy 3.1 + AudioBoard + Sequencer
  84. Audio Library and dynamic use of the SD card
  85. Teensy compatible touchscreens
  86. audio-adapter-board-as-eurorack-module (sort of)
  87. Open source wearable LED display
  88. WiFi - Lantronix xPico
  89. external programmer
  90. new FTDI driver deliberately bricking devices
  91. Another midi controller (CC messages)
  92. Teensy Tiny Blinky
  93. APA102 - a new WS2811/WS2812 style addressable LED suitable for POV installations
  94. Microcenter now sells Teensy 2.0, 2.0++, and 3.1
  95. Hello from Gig Harbor
  96. Reset sketch power on fail
  97. LED Video Panel from Maker Faire questions
  98. How to download animated GIFs onto a 16x16 WS2812B using Processing and Teensy 3.1
  99. Windows 10 Preview build 9860 is looking really good, at least for USB Serial
  100. Skeleton Rave Baby
  101. Teensy 3.1
  102. Serial.printf
  103. Hot air station recommendation
  104. Teensy at Jet Propulsion Laboratory
  105. what is teensy board
  106. Better Serial Monitor
  107. Teensy 3.1 max FFT frequency
  108. Teensy 3.1 Audio Adapter Board - what microphone?
  109. Teensy 3.1 audio board - calibration
  110. New 6DOF sensor with optical analog output
  111. Teensy 3.1 with CD74HC4067: I2C usage
  112. iPad and Teensy 3.1 - solving powering issue
  113. Teensy 3.x Ready-To-Go Makefile System
  114. Teensy 3.1 battery powered: correct pin used?
  115. cut out for the "USB Cable, Micro-B to Standard-B Panel Mount Adaptor"
  116. Teensy 3.1 with Glediator and Jinx over USB
  117. Numbers on the Green Silkscreen?
  118. Julia language and teensy?
  119. Laser-cut box enclosures for your Teensy projects (including 32x32 LED + SmartMatrix)
  120. Adventures with ARM CMSIS and the HAL
  121. Led Strips and teensy..
  122. FunkyNoise animation playground
  123. ARM processors' "Saturated arithmetic"
  124. Fun Teensy Eurorack Module
  125. interrupts, priority, attach detach
  126. UECIDE Support of Teensy 3
  127. Rouges Gallery - the award for messiest breadboard goes to...
  128. ISO7816 - existing software?
  129. 24 bit audio boards
  130. WS2811, Teensy3.1 and C prog example
  131. Visual identification of Teensy?
  132. New IDE for non-newbies and most popular ARM targets
  133. Dancing LEDs Bluetooth WS2811, WS2801, WS2812 controller based on Teensy 3.1
  134. Ws2812c
  135. teensyduino in Code::Blocks: how to set up ARM-NONE-EABI-GCC
  136. teensyduino in Code::Blocks: how to create a simple project
  137. teensyduino in Code::Blocks: Adding the teensy loader
  138. Another Teensy 3.1 Project to Share
  139. Teensy3.0 with Txtzyme/Arduinozyme to bypass PWM fan control on a broken motherboard
  140. Asynchronous I2C on Teensy3.1?
  141. Start address different from zero
  142. Teensy 3.1 and OS X usb pwn
  143. Q for C++ guru
  144. Introducing the Pi Watch - We're on Kickstarter!
  145. 2 channel DJ mixer for Traktor
  146. Teensy 3.1 Neopixel MIDI display - project code
  147. W25Q128FV Serial Flasher
  148. Speeding up u8glib with DMA SPI
  149. Floating point
  150. cheap little incomplete BEAM bot.
  151. New To Teensy 3.1: Additional Hardware Needed?
  152. Library to flash the teensy 3.x
  153. Quake on an oscilloscope!
  154. Play RAW from Serial Flash
  155. Adafruit Motor Shield V2 library edited for Teensy 3.1 and i2c_t3
  156. Bitlash Teensy (mini)Notebook [Onboard Interpreter]
  157. Chorus
  158. Building for the Teensy on the Raspberry Pi
  159. Multiple (8) DAC outputs - how fast?
  160. Appallingly small RTC
  161. interrupt/automode driven library for the RFM69
  162. Teensy and GPS ?
  163. DIY Smartwatch
  164. Short Report from CES
  165. how to connect mega arduino R3 2560 to adafruit cc3000 wifi shield?
  166. Any email sysadmins who know about SPF?
  167. Teensy 3 OctoWS2811 code for Boblight
  168. 1.5" LCDs for Smartwatch
  169. Silly question I'm sure?
  170. Teensy 3.1 and OpenLog
  171. Start-up products
  172. Speed of teensy software download.
  173. Where is the Teensy M0 hardware?
  174. Teensy 3.1, dual ADC, 2 x AudioInputAnalog?
  175. Pimoroni Skywriter HAT
  176. Future Teensy's and SWD
  177. Mixology. Volume device for gamers
  178. Boot process?
  179. Android tablet as serial terminal - works
  180. Teensy Humidifier
  181. Connecting multiple Teensy with spi?
  182. Teensy ADC conversion speed setting
  183. coin cell
  184. Freescale's KDS (Kinetis Development Studio) - anyone used it?
  185. Flip-dots gone mad. How could we build a smaller one, low cost?
  186. how to program the "snake game " on a teensy3.1/smartmatrix driven 32x32 LED panel
  187. raspberry pi model 2 (quad-core)
  188. Teensy 3.1 Music and Lights
  189. Memory board add-on requirements
  190. Best voltage source and circuit for AREF pin on Teensy 3.1 ?
  191. Gernal code development and reflashing
  192. Teensy 3.1 UART
  193. Arduino 1.6.0 - any plans to support it?
  194. Guitarsynthesizer build with Teensy 3.1!
  195. Teensy 3.1 symbol & footprint for gEDA gschem and pcb
  196. Somebody please go down to Starbucks and get Paul Stoffregen some caffine!
  197. AFX-01a Music Computer build with Teensy 3.1
  198. using FreqCount Library with Arduino Lilypad USB Board
  199. Teensy 3.1 FlightController Quadcopter Mavlink
  200. The thrill of victory, followed swiftly by the agony of defeat!
  201. adafruit atmega32u4 bb+ support?
  202. Free courses from edX: BerkeleyX electronic interfaces & UCAustinX embedded systems
  203. Tiny Scope
  204. Teensy Qt
  205. A Guide To Using ESP8266 With TEENSY 3
  206. Arduino.org
  207. Could you help us with testing of a new PlatformIO 1.0 and Teensy?
  208. Teenstrument64-LC
  209. Die Arm Architektur
  210. DmaSpi for teensyduino 1.21
  211. An update on my GSM/GPS project
  212. NXP nears deal for Freescale Semiconductor
  213. Teensy-OCD
  214. Wi-Fi Connected Location Logger
  215. Upverter
  216. NXP semi buying Freescale?
  217. Using Teensy 3.1 without Arduino
  218. NXP buys Freescale. Yikes
  219. Kinetis KV5x - 240 MHz, ARM® Cortex®-M7
  220. Hackster.io Teensy section
  221. Teensy as USB to UART converter
  222. What day in March does the Teensy-LC ARM stamp go on sale?
  223. Where to buy Teensy 2.0
  224. Teensy 3.1 and project problem
  225. Teensy-LC ARM Stamp pin 17 driving WS2812b/Neopixels
  226. github - any experts? How to clone a library twice?
  227. Non Blocking Ethernet/DHCP library (?)
  228. Transfer files
  229. Programming Teensy 3.1 from Intel Edison
  230. Teensy form factor in movie
  231. Ardiuno pro micro thinks it's a teensy
  232. What I did with my Teensy 3.1.... (oh no not another clock!)
  233. single pulse generation using elapsedMillis
  234. Synchronizing I2S of multiple Teensy 3.1
  235. Teensy 3.1 and timer concepts
  236. Teenys as programmer for teensy?
  237. Translating Lidar Lite I2C example to Teensy
  238. Netbios Name for teensy 3.1
  239. Problems with new Teensyduino and FastLED and my Necklace app
  240. OS statistic among Teensy users?
  241. SMD Piezo shock sensor - advice please
  242. Teensy LC Arduino "Unable to Reboot" and "Download Error"
  243. Pimoroni Skywriter HAT
  244. USB DFU for Teensy
  245. L6470 AutoDriver stepper driver and the Teensy 3.1
  246. Crystal pull range on 3.1?
  247. Using the DAC with DMA on Teensy 3.1
  248. WS2818 Source
  249. Display_ili9341
  250. Visual Studio with Visual Micro support for Teensy LC
