View Full Version : General Discussion
Pages : 1 2 3 [4] 5 6 7 8 9 10 11
  1. Battery + micro SD shield for Teensy 3.x
  2. I2C Device using teensy as the driver
  3. where to install audio library
  4. Switch statements slow?
  5. Most wall clocks are old fashion until now. This is the coolest wall clock!
  6. Teensy 3.x NATIVE USB HOST PREVIEW AVAILABLE
  7. Faster (than) Serial.write()?
  8. Interleaved PWM signals
  9. Teensy 3.1 3D Model for prototyping
  10. Freeverb for teensy
  11. Duplicate __cxa_guard_
  12. Teensy LC Supported in the uTasker Project (including USB-MSD and UART loaders)
  13. What do I need to get started?
  14. Arduino 1.6.2 support
  15. Esp8266
  16. Teensy 3.1 + Audio board - What pins do I actually need?
  17. Teensy as a secure storage for private keys
  18. Just dreaming ... one day Teensy Arduino commands built on a RTOS?
  19. Arduino 1.6.2 support?
  20. how to play raw audio file in PC .
  21. Sparkfun no longer carrying 2.0?
  22. regards the time of write audio file to sd card "5802 us."
  23. Program two independent Arduino sketches into Teensy 3.1
  24. Basic comparison of some wireless options with Teensy: HC-05, XBee, and nrf24l01+ ?
  25. 1-wire PWM
  26. Update files on SD Card through Teensy without removing card or reprogramming Teensy
  27. WizFi250?
  28. Apple II watch
  29. Ethernet TCP/IP and Teensy C
  30. Teensy 3.1 Breakout updated -- 25% discount for PJRC forum members
  31. Lesson learned - I physical damaged the Teensy 3.1 MINI54 chip
  32. Freescale name change
  33. Teensy 3.1 with 5" TFT (RA8875), uGFX, dynamic widgets, force-directed graph
  34. Teensy-LC FFT Library
  35. External crystal design
  36. Teensy-LC schematic posted
  37. Pixelmapped Euphoria Festival main Archway!
  38. Extracting firmware
  39. PWM using hardware timers Teensy LC
  40. Split Band Scrambler Audio Library
  41. Spectrum Analyzer
  42. awesome USB features for 2015?
  43. Teensy HID Data Extraction
  44. Tutorial for Connecting NeuroSky's MindWave Mobile
  45. Improving the Re:load active load using Teensy3.1
  46. Has anyone used the Teensy LC/3.1 with Kinetis Development Studio
  47. Using Teensy for industrial control application
  48. dll for Teensy
  49. big teensy project
  50. simple working VGA output with Teensy3.1
  51. Teensy 3.1 midi rotary encoder to DAW
  52. Quick Guide: Using printf() on Teensy ARM
  53. i need help today! thanks!
  54. Teensy frequency counting and the Arduino Yun
  55. Arduino Board Manager
  56. teensy 3.1 intterupts, 'error: 'TCCR1A' was not declared in this scope'
  57. Any SDIO experts out there to query?
  58. teensy audio WAVEFORM_ARBITRARY example?
  59. Some basic help needed to get started with teensy LC board
  60. a cost-effective high-performance TFT HMI
  61. Happiness is...
  62. Problems with Teensy++ 2.0 and LUFA
  63. Noise on GND from SPI (SCK)... what is normal?
  64. Mac Book Air using as download device to Teensy 2.0+ ?
  65. Teensy in an MRI
  66. Teensy 3.x and Array of Objects
  67. Micro Center experiences?
  68. Teensy powered multi-channel motion control
  69. $9 computer on kicstarter
  70. pin control of resistance
  71. PCB-production
  72. Nextbook
  73. Maker Faire 2015 at San Mateo
  74. My vintage-styled USB-MIDI controllers for software synth plugins (sound-force.nl)
  75. USB Battery Bank Prevent Shut Down
  76. EDA for tough times
  77. Development
  78. Problem with TeensyLC board
  79. Visual Micro *(free) version update supporting Teensy. Works with FREE Visual Studio
  80. Multiple audio signal processing
  81. parallel 32 bit manipulation with Teensy 3.1
  82. Extract Image Data from GoPro
  83. Export restriction?
  84. Serial1.transmitterEnable(pin) and stop-bit
  85. Teensy 3.1 (Multiple USB Device) Functionality?
  86. USB Serial Mode Driver installation
  87. Purple OSH version
  88. My i2c sniffer
  89. Teensy positioning w.r.t. Windows 10 Internet Of Things
  90. The wondrous ways of the T 3.1
  91. Teensy @ Freescale Roadshow
  92. ILI9225 Optimized Library
  93. Programming teensy from Ipad
  94. Is there a market for a Teensy 3.1 48 pin ARM stamp?
  95. Teensy 3.1 with ESP8266 Web Server
  96. Two SPI modules on Teensy 3.1: NOT
  97. for use in a usb-powered device
  98. La ?
  99. Improving range between two nrf24l01+?
  100. Audio System Design Tool can modify ?
  101. Teensy STEM BLE Project
  102. A model web site to consider for Teensy's upgrade
  103. Attracts: A smartwatch to prevents hand Carpal Tunnel Syndrome
  104. Teensy 3.1 helps save lives in Nepal
  105. Thanks
  106. Powering IoT devices wirelessly with WiFi (PoWiFi)
  107. Teensy LC
  108. Teensy 3.1 obsolescence
  109. Star Trek Captains Chair made by Adam Savage has a Teensy 3.1 and Audio adapter
  110. Noob question: "Teensy Mini Pro"
  111. Can Not Read Proper Voltage?
  112. Sparkfun has a new Teensy 3.1 shield to Arduino form factor
  113. nRF52 Cortex M4F with BLE!
  114. ST7735, ILI9163C, a new approach.
  115. Efficient CHANGE interupts
  116. x737 Datarefs and the Teensy 2++
  117. Project Cyborg Ears - wearable 'DSP hearing experience' platform
  118. Arduino Timer1 question
  119. is pin change interrupt flag cleared when interrupt handler is called?
  120. Teensy 3.1 - Use those extra "Dupont" wires and access Serial2
  121. New Teensy / ESP8266 Developement board
  122. Audio board + screw terminals
  123. WS2811 / WS2812S / WS2812B, "Neopixel" and Teensy
  124. Teensy LC plus neopixels... (noob alert).
  125. C# Library for Uploading Firmware from User Applications
  126. Thank you for Teensy 3.1
  127. Sub Micro Second Pulses
  128. Bought a Teensy 3.1, how do I learn to use it?
  129. Two blown Teensy 3.1's
  130. Teensy, ESP8266, RTC UTC Clock
  131. Multiple Stereo Inputs on Teensy 3.1 with Audio Shield
  132. MACBOOK PRO EFI TEENSY 3.1 Help
  133. BBC micro computing
  134. A social robot with the Anouk edition
  135. Latest Visual Micro fixes Intellisense in VS 2013
  136. no examples I find on the net COMPILE
  137. Emw3165
  138. 737-200 Sim update with 10 Teensy's
  139. Project Advice: Teensy 3.1, Audio, ILI9341
  140. The underwhelming 4 button Midi controller
  141. Visual Micro with Teensy 3 support, new release
  142. Midi Wind Controller
  143. Newsfeedreader in a matchbox based on Teensy3.1 and Esp8266 wifi-module
  144. Analog modeling monophonic synthesizer on Teensy 3.1
  145. Category 'Sensor' in library DallasTemperature is not valid
  146. Rate Reduction effect for audio.h - code and questions
  147. RawHid C# example
  148. Fast connections between RPi and Teensy 3.1?
  149. Github documentation
  150. Si7021 Humidity and Temperature Sensor - Library
  151. ArduinoSoftSpi - Use an SdCard and drive lots of APA102 Leds!
  152. Dual channel 16bit dac PT8211
  153. Flash new RC plane ESC firmware via teensy
  154. teensy 3.1 with adafruit ultimate gps sending info via udp packet
  155. what are the pads under teensy 3.1 board?
  156. SD logging via GP
  157. Adafruit GPS logging via leo_locus_start
  158. Teensy on front page of Fox News
  159. VController
  160. DAta logger gps info
  161. teensy 3 and hacker's rolljam
  162. How to wire reset switch
  163. teensy 3.1 basic adafruit gps sd logger
  164. Teensy 3 on front page of Gizmodo
  165. Roadtrip - Teensy needed - Villnius -> Tallin
  166. Sleeping with Teensy ;-)
  167. ok to use CR1225 for Teensy 3.1 RTC VBAT?
  168. How to use an Adafruit LiPoly/LiIon Backpack Charger with a Teensy
  169. open-source license issues when using teensy products
  170. USB serial to Teensy flash to I2C EEPROM?
  171. Running Audio Library @ 8000 Samples per Second
  172. W2DEN's APRS Tracker
  173. Teensy3.1 and Flextimer(s?)
  174. What's the resolution of micros() on Teensy 3.1 ?
  175. LabVIEW Support for Teensy 3.1
  176. USBEvent?
  177. Teensy in an another article!
  178. A simple class for sub microsecond timing
  179. How to delete the Teensy USB Serial driver from Windows 10
  180. multitasking/threads on teensy
  181. Using External Power and USB Hack
  182. Example GPS Data Logger Code for Teensy
  183. need help to get oled to work
  184. Newbie needs help with teensy toolchain in Linux
  185. Gentoo and Teensy LC how I got it working...
  186. New appallingly small utilities for Teensy
  187. Modi - DIY MIDI Controllers
  188. Burning Teensy :-)
  189. PteroDAQ data acquisition system now supports Teensy 3.1 and Teensy LC
  190. Superb video by Applied science featuring the Teensy LC
  191. Teensy 3.1 analog input safe voltage limit ?
  192. request help whit improve script .
  193. Is there a better Servo Library for Teensy
  194. Quantity pricing for Teensy LC?
  195. Expanding Touch Sensors on Teensy 3.1?
  196. Over the air updates
  197. Ganssle's free newsletter, SMT tips
  198. USB Power Meter
  199. Teensy 3.1 - Serial - Half Duplex
  200. Teensy 3.1 - 9O2 Support
  201. Serial receive buffer overrun - is there a way to stop receiving if buffer is full?
  202. autoranging ADC input
  203. cannot get Teensy 3.3 to install in Ubuntu 14 04
  204. Nerding out with the Irrigation System
  205. Problem running Visual Sudio 2015 and Visual Micro
  206. My Teensy Based Robot Controller
  207. Best way to automate firmware with a variable that changes each compile?
  208. BlueSMiRF and Teensy 3.1 -- ensuring connection happens on first try?
  209. Product using the Teesny 3 : The Delaydelus sampling effect device
  210. can default pin 13 not be used as SCK on SD card?
  211. SSD1331 "Teensy 3.x optimized" SPIFIFO library
  212. ps4 joystick?
  213. Talking to teensy USB direct without using serial comport
  214. Audio Shield with OctoWS2811, I2S Clock Signal Pins
  215. What is the most current K20 (Teensy 3.1 CPU) reference manual?
  216. ADC setAveraging(8) and setAveraging(16) have opposite effect
  217. OTA Programming using ESP8266
  218. Oscillator performance on Teensy 3.1
  219. Another test
  220. puzzle, little brain teaser
  221. Spam Update
  222. [QUESTION] Launching Files
  223. Another step forward on low cost sophisticated WiFi MCU boards?
  224. International Mobile Subscriber Identity IMSI in SIM
  225. Template for planning Teensy projects
  226. Teensy3.1 and Flextimer Output Compare - Generate two 1 MHz sq waves in quadrature
  227. error usb not respons
  228. Special closeout sale on Teensy 3.1
  229. Teensy 3.1 pin pitch: 2.5mm or 2.54mm?
  230. Teensy 3.1 and STM32F7-discovery
  231. Newbie Questions
  232. Can Teensy handle a camera?
  233. Overclocking to 96Mhz Question
  234. Teensy "Boot" time?
  235. FreqCount library for Arduino DUE board
  236. Configure FreeRTOS on Visual Studio + Visual Micro to program Teensy 3.1
  237. Teensy 3.x documentation and resources for fully understanding the Teensy 3.x
  238. 32-bit arduino on breadboard
  239. Teensy-sized with wifi-Electric Imp
  240. Automaton: multitasking state machine framework
  241. Dipsy - a tiny FPGA board
  242. Teensy 3.1, 3.2, LC - Increase DAC resolution from 12 bits to 16 bits
  243. 0.5mm Pitch LGA Soldering
  244. I2S0_(T/R)DR1 on MK66/MK20?
  245. Security question
  246. Teensy 3.1 and Flextimer(s) - Counting external pulses accurately
  247. Hackaday Superconference Audio Workshop
  248. Where to start with Teensy LC, Linux, not Arduino
  249. Strip Chart Recorder
  250. Eagle Package Audioboard
