View Full Version : General Discussion
Pages : 1 2 3 4 [5] 6 7 8 9 10 11
  1. OSH Park T3.2 Purple Edition
  2. Teensy 3.2 with Gameduino 2
  3. SPI Digipot, Speed of Teensy vs Arduino Uno
  4. rising prices for 23LC1024
  5. RA8875 library
  6. My Teensy Aircraft Instrument Interface
  7. Digital Saxophone/Clarinet based on Teensy
  8. Windows Serial Installer distribution
  9. cojson – a JSON parser for constrained platforms
  10. interrupts -> member function in C++ class? (or some type of data)
  11. teensy 3.2 interupts
  12. Sailboat autopilot with Teensy
  13. Teensy 3.2 USB
  14. SPI slave phase not correct
  15. Atmel acquired by UK firm
  16. Halloween is upon us
  17. nRF51 add-on for Teensy
  18. Arduino 1.6.6
  19. effect of differnent teensy 3.2 speeds.
  20. teesny3 general coverage DSP superhet radio
  21. Something fishy? ESP8266-12E $1.94 @1ea free (slow) shippng?
  22. Difference between analogRead() and PDB driven ADC, introduced by Audio library
  23. SPI Flash: Radom errors during repeated read back
  24. Can't get Teensyduino software to load against Arduino 1.6.6 as of 11/9/2015
  25. plot latency when transmitting data from teensy to python
  26. Any suggestions for 64mb i2c flash/eeporm?
  27. ESP8266 sensor server
  28. My recent absense... and Hackaday Supercon
  29. Teensy 3.1/3.2 printed cards, CS-Pins ?
  30. Teensy3 Kicad libs
  31. POV Staff (video)
  32. MK20DX256V packages
  33. ASCII art Teensy 3.2 pinout
  34. measure your teensy 3.x cpu and ram usage!
  35. Thumb operated joystick question
  36. Difference between blluetooth data rate and UART baud rate
  37. Robust remote firmware update - unattended and without mass memory
  38. Passing regular MIDI from host to host
  39. Cheap Video with Teensy 3.1 and $5 OV7670 camera chip
  40. using uGFX in arduino, with Teensy 3.1 example
  41. Suggestions for decoding serial data that is encoded using pulse widths
  42. Any Black Friday sale this year?
  43. will this be a milestone change in embedded tinkering?
  44. High Reliability Serial Firmware - Library and Template
  45. Pictiva 288x48 OLED library
  46. Teensy with a USB Type A plug (male)
  47. custom Teensy build
  48. Atmel Qtouch and Qmatrix
  49. DMA Scatter/gather and DMA mux
  50. Teensy based 6502 Logic Analyser
  51. Multichannel AnalogRead at fixed sampling rate 256Hz
  52. My teensy 3d printed case
  53. Introduction
  54. C language, old dog new trick - struct by value (RVO)
  55. Resart communication ard.Teensy and x-plane.
  56. new multi-font derivate from Adafruit_GFX
  57. DIY-Thermocam: A self-assemble low-cost thermal imager based on the Teensy !
  58. Teensy 3.2 with Adafruit 4-Coin Counter
  59. ILI9341_t3 draw centered text string
  60. serial ports clarification needed for Teensy 3.2
  61. USB Hub question
  62. BitlashTeensy [Micro]Computer
  63. ESP8266 Teensy add-on
  64. Looking to buy a reflow oven
  65. DDS Sine Wave on Teensy 2.0
  66. T3PO Shield -- need some feed back.
  67. Data dropouts in serial transfer over USB
  68. uGUI + Teensy?
  69. Possible bug about using const array in functions?
  70. low-current DC power meter
  71. VideoDisplay
  72. Teensy 3.2 on Breakout Board
  73. eBook: Teensy Development Workshop
  74. Touch screen flicker w/ PWM Laser Line Module
  75. Changing 'IntervalTimer' interval on the fly
  76. Last of my public apologies, pretty sure.
  77. Response boxes
  78. My Teensy Logic Analyzer
  79. Phillip Schuste's Little Helper has hit Hackaday
  80. Teensy3.1 and timers for RTTY
  81. ESP8266 Add-On for Teensy 3.2
  82. C++ framework for modestly complicated to really complicated sketches
  83. HiFi Audio CODEC Module - AK4558 evaluation board in a square inch PCB
  84. I need help in my GPS in Arduino Codes.
  85. Hi Guys I need Help for my Project. Having some trouble here.
  86. Teensy Dodge Radio CAN (Controller Area Network) Emulator with Android Interface App
  87. TimerOne Library in Visual Studio 2015
  88. Greetings Everyone, Happy New Year!!!
  89. virtmem: easily extend your memory
  90. Newbie questions about clocks.
  91. Can you have more than two Pots on the AREF pin?
  92. Completed Project: Front of House LED lighting
  93. Another low cost WiFi open source board
  94. Zebra byte for the Adafruit Metro Mini vs. Teensy
  95. Mac OS CMake workflow for Teensy
  96. Teensy Book?
  97. Teensy not blinking - how to proceed?
  98. Memory Status and Monitoring
  99. Single pulse’s width with PulsePosition Library?
  100. Syncronizing HW timers with SW subroutines
  101. Arduino 101 user comment
  102. Freescale <<= NXP
  103. Teensy 3.2 MAX VIN
  104. Added position offset to playSDraw
  105. MIDI to USB adapter with Teensy LC
  106. Strange behaviour with TinyGPS++ library
  107. 15 Teensy's and counting.
  108. seeed rephone modular kit now being sold
  109. noobie question on Pots and Analog
  110. Teensy 3.2 with nrf24 and lpd8806 strip
  111. Teensy 2 users and the disconcerting sale of Atmel
  112. Teensy 2.0 - Uploading shellcode to Arduino from SET
  113. Anyone been succcessful with Teensy + Adafruit's 3.5" Touchscreen HXD8357D
  114. Converting Teensy 2.0 Mini-B to Micro-B
  115. A newcomer to pjrc.com
  116. Subforums
  117. Soft Latch single momentary power switch circuit w/ GPIO option for auto power down
  118. Which MCU + BT/BLE for heart rate and ECG monitoring (from TI ADS1293)
  119. MCU for optical fibers
  120. USB Keyboard on Windows
  121. Raspberry Pi Zero for video?
  122. Teensy 3.2 open source code/hardware?
  123. Important question for data recovery
  124. Teensy to Arduino via I2C
  125. Eagle 30% Off Through Today
  126. SPI.disable not working correctly with setMOSI/setMISO/setSCK
  127. Stackable 14 pin Female Headers for Teensy?
  128. Teensy creating high output during programming
  129. Cross Platform development environment - USBMIDI and Teensy hex command line upload?
  130. OpenLog keeps creating new files when powered with Teensy by battery
  131. VFDs and DS18B20 Temp Sensors
  132. Open sourcing Teensy loader?
  133. Chips which supports multiple 2bit gray code encoders w/ i2c interface (& LED PWM?)
  134. Truncated algebra optimisation
  135. Surface mounting the Teensy 3.2
  136. Teensy 3.X soft start in software
  137. Teensyloader configuration file ?
  138. Line Wobbler: Teensy 3.2 + Accelerometer + Audio + 5m LED strip = 1D Dungeon Crawler
  139. Teensy Flight Controller
  140. Paid Freelance Software Dev on Teensy LC / 3.2
  141. Project Update: 960 (30 x 32) APA102 LED Spectrum Analyser
  142. Gladiator with OctoWS2811 - working example
  143. SPI Chip Selects (Teensy 3.1 vs 3.2)
  144. USB Descriptor
  145. Adafruit demo: Supernova Poi using Teensy 3.2
  146. Digikey selling Teensy (via Sparkfun)
  147. Fast GPIO credit card computer
  148. Teensy 3.1 PWM register update
  149. IntervalTimer tuning
  150. Teensy 3.2 i2c LCD
  151. Need help with FTM settings
  152. Flybrix Lego Octocopter Kit
  153. NeoPixel POV project help
  154. Electric Vehicle Controller
  155. Zephyr (?)
  156. Beginner Hitachi LCD Question
  157. Custom digitalReadFast()
  158. Teensy++2.0 Joystick help. 8 axis, many buttons.
  159. Memory problem?
  160. very embarrassing But...still
  161. Installing Teensyduino 1.27
  162. Threshold Cross Time Detection
  163. Challenge... can anyone help me "ripple" a Union Flag bitmap on 960 RGB LED's?
  164. Teedncy 3.1 and 20x4 LCD with Hitachi HD44780 driver
  165. Anti-spam check during registration
  166. Teensy LC Breakout Board
  167. Teensy development environment that supports subfolders?
  168. Posting my Teensy Joystick codes, so other people can use it.
  169. embedXcode how does your .gitignore file look?
  170. Interfacing multiple RGB Switches
  171. SWCAN bus hack allows backup camera display
  172. Which I2C Chips Have You Used? (and what address did they have?)
  173. TeensyLC + H-Bridge + real HSI = holy cow!
  174. Teensy 3.2 and Nextion Display
  175. ILI9341 (320x240 TFT color display) issue?
  176. More than 2 x I2C... what is the right approach?
  177. Tiniest Teensy?
  178. Is there a way to use "functions" as parameters of other functions?
  179. Room Temperature solder packets?
  180. Is there a good SIMPLE task library?
  181. Thrustmaster T.Flight Hotas X Teensy MCU mod (USB Flight Joystick/Throttle)
  182. Comparator speed
  183. PlatformIO IDE: The next generation IDE for IoT development
  184. Libraries vs. Global vars
  185. What packaging does the Teensy 2.0 and other Teensies come in?
  186. Ili9341 &
  187. Using the ESP8266 with a Teensy
  188. Boy am I slow...
  189. Teensy datalogger... now how to parse/graph results
  190. Project Video: FLXS1 Eurorack Sequencer
  191. Anyone recommend a good/free Installer for Win (maybe Mac too)?
  192. Should I write a GUI library for Teensy?
  193. Temperature rating?
  194. Teensy LC analogRead -- seems to be limited to 10-bits?
  195. Teensy 3.2 with More Breakout Pins Available?
  196. GeoPix LED Pixel Mapper software - officially supports the teensy 3.1 !
  197. Probability of dying Teensy?
  198. Can the audio library handle a second input with adc2 ?
  199. Completed MKS-50 MIDI controller/programmer
  200. How to dynamically get the CPU speed
  201. Test Points
  202. T3 example using LTC2400 (24-bit ADC)
  203. Vult - a DSP Transcompiler (suitable for Teensy etc.)
  204. Noob Question: Teensy 2.0 with USB Host Shield for Arduino Pro Mini on Breadboard?
  205. What are the advantages of the Teensy LC/3.x optimized speeds?
  206. RadioHead / Airspayce issue
  207. Prop Shield NXPSensorFusion observations
  208. Changing I2S TX and RX pins
  209. A question for Paul and "the team"...what if i want buy a large number on Teensy 3.2?
  210. Castellated boards
  211. MIT Smartphone Laser Scanner with Teensy
  212. Teensy 3.2 on battery (without usb port connected)
  213. Panorama Controller
  214. Why does the SHT21 / I2C crash...
  215. V-Controller version 2
  216. Keyboard Media Keys, now (hopefully) Windows compatible
  217. Dynamixel Support (bioloid libraries) on Teensy processors...
  218. Idea for a not as Teensy Teensy
  219. Board design - MicroSD pins
  220. Teensy 3.2 + ESP8266-12Q+ High Speed ADC + Websocket
  221. Any opinions of Apache mynewt OS?
  222. Translating Serial Midi to usbMIDI
  223. XPLane Commands with Teensy?
  224. Are "newbies"unwelcome here?
  225. Parallel SPI Flash
  226. Windows XP allow me to upload a sketch one time only
  227. SNMP for Teensy 3.1-2
  228. Teensy 3.2 digitalReadFast() Speed Test
  229. Teensy MK20DX256 - in circuit debugger or programmer
  230. What are dma channels, and what do I do with them.
  231. Synchronizing LED's with Musical Instruments
  232. [Q] Teensy 3.2 - USB Joystick - Change device name?
  233. Reading two sensors at different frequencies... multiple Timer3?
  234. ornaments+crimes extended / polymorphic 16bit CV genererator
  235. Multiple SPI Slaves Conflict: ADXL-362 and SD Fat
  236. Teensy 3.2 playing piano on iPad
  237. Studio DAC
  238. DIY electronic RFID Door Lock with Battery Backup
  239. HELP: Best GSM / Cellular Module?
  240. Several questions about Teensy v1.0, schematics, open source...
  241. Updating Arduini IDE and Teensyduino
  242. Teensy Encoder Lib strange read in example sketches
  243. 1 GHz and multiple cores?
  244. Arduino 1.6.9
  245. Gesesis & NES controller support for YeOldeJoystick.
  246. Data Logging using prop shield
  247. Simple testing code for teensy 3.2 doesn't work
  248. Teensy LC Hardware Encoder Support?
  249. saw in local news yesterday
  250. TMP102 I2C temperature sensor library available
