View Full Version : General Discussion
Pages : 1 2 3 4 5 [6] 7 8 9 10 11
  1. Programming Help for Teensy 3.1/2 and LC
  2. Teensy LC and Teensy 3.2 with nRF24L01
  3. New USB Type, RAW HID Without Serial Emulation
  4. A Second USB_HID On Teensy 3.2
  5. Biopotential Signal Library
  6. USB MIDI mode without a USB host
  7. Control an unknown stepper motor
  8. LCD Library for Teensy 3.1/3.2
  9. Unexpected issue with ADC and 5v
  10. OctoWS2811 VideoDisplay + FastLED
  11. 3D printed case for Teensy 2
  12. Maker Faire in San Mateo
  13. Time based loop/repeating using APA102 & ws2812 question
  14. Possible Regulatory Issues
  15. Teensy 3.2 DIY Reference Board
  16. Overvoltage protection options for VIN
  17. Arduino Library Manager...
  18. Paul's taking a 5-day vacation
  19. How can I code a non-square pixel grid?
  20. DSP Instructions
  21. Teensy 3.1 is randomly freezing
  22. Teensy Express
  23. Pesky Products interview in maker.io
  24. Teensy-LC, artificial neural network, usb midi synthesizer.
  25. Breaking out the Reset Button
  26. Kinetis IDEs
  27. Arduino Create (online)
  28. STM32 F7 , 5v tol IO M7 Arm
  29. Teensy 3.x NuttX USB device controller driver
  30. 540 LED ball using Ternsy 3.2 and OctoWS2811
  31. 3.3v pins on 3.2 and eagle components
  32. HackPOD : A smartphone powered by the Teensy 3.1
  33. Teensy keyboard + Flightsim command
  34. Optimized SSD1351 library with buffering
  35. Arduino: 712 Issues, 126 Pull requests..
  36. Serial.attachCts() can this Pin be re-mapped?
  37. Plans for a Teensy++ 3.x?
  38. Serialx - Support for half duplex...
  39. Project Video: Wireless Wah-Wah and MIDI shoe
  40. Reading in Midi SysEx, only getting first message
  41. how can we play raw audio file in PC .
  42. Project: SSFBB-Surrounding sounds feedback box
  43. What is a UTFT display?
  44. Teensy Goes to Space!
  45. Windows Insider Preview slow USB throughput
  46. Real Time Linux
  47. Teensy on TV
  48. Three cheers for Daniel Gilbert's Teensy 3.2 Breakout board!
  49. Better Analog Signal Debounce
  50. Driving ax-12 servos
  51. Odd question #2: What programs do you use for schematic capture and board layout?
  52. Digital Logic Voltage Threshold (w/ FreqMeasure library)
  53. Perplexing behavior in function, delay(0) affects calculation
  54. SysEx end byte 0xF7 reading out from array as 0
  55. Talking Sword with Teensy + prop shield
  56. Realtime Beat Detection and Audio Analysis + DMX Master Demonstration
  57. Sometimes you just need to ask for help...
  58. Teensy ++2 and SD adaptor
  59. battery pins and burnt board?
  60. Floating point on new K66 teensy?
  61. Schematic building tips, tricks, and tools. How do you manage the chaos?
  62. MPU9250 power consumption
  63. Teensy with Bluetooth and NFC
  64. Header options... the struggle is real.
  65. SoftPot to Pitch Bend MIDI questions.
  66. cheap bluetooth module
  67. Teensy3.1 as a precision Frequency Standard
  68. Basic question about creating custom Teensy
  69. Is debounce no longer a valid OneWireKeypad member?
  70. Input vs Output Current Consumption
  71. Teensy USB-MIDI Controller Tutorial
  72. Adafruit now has Teensy -> Feather adapter
  73. Problems Plotting Filter Response
  74. Serial gibberish when using Teensy to talk to ESP8266
  75. Another Audio Library Question
  76. Plotting Filter Response Question Two
  77. Teensy 3.1... does it have a FTDI Chip?
  78. usbMIDI and MIDI 4.x?
  79. Inverted 8E2 Serial Possible?? SERIAL_8E2_RXINV_TXINV
  80. Arduino 1.6.10
  81. Teensy 3.2 on Prop Shield
  82. Arduino / Teensyduino Moving Targets
  83. New to Teensy, lots of questions please help!
  84. Sometimes, it's the small things in life...
  85. How can I get a stable and accurate sample rate?
  86. Teensy ++2.0 Max7219 and 8x8 ledmatix.
  87. Completed project: God's Eye
  88. How does a 64K RAM control 320x240?
  89. Functional difference between timerone and timerthree
  90. Teensy Serial Read
  91. best/cheapest way to power teensy 2.0?
  92. How to read/write to i2c registers in C language using Teensy 2.0?
  93. Sparkfun header kit
  94. Teensy 3.2 flash organization
  95. Introduction and AMSYS AMS 5812 and AMS 5915 Libraries
  96. uBlox Library
  97. SBUS Library
  98. Solderless Breadboard Stray Capacitance
  99. Overlay Support for Library Archive(static library, .a file) on GNU-GCC
  100. FreqMeasure and FreqMeasureMulti
  101. 3.6 Kickstarter, I'm in!
  102. linux development without teensyduino - howto
  103. NXPK66 vs. STM32L4
  104. Teensy 3.5/3.6 Breakout board to test things with.
  105. Spammers....grrrrr
  106. morse converter
  107. CAN Bus Hardware Recommendations?
  108. [Project GPS] Teensy 3.2 High Speed GPS logger
  109. Tenssyduino RTS and CTS implementation: is it bitbanged or the processor handles it?
  110. Teensy 3.2 DIY Reference Board
  111. BNO055 example not functioning as expected because Teensy used instead of AVR8 board?
  112. Teensy 3.2 and Laser PM Sensor
  113. TI CC2541 no GATT communication
  114. Teensy 2.0++ pin voltage signal?
  115. A problem with the IntervalTimer library or a problem with my code..
  116. Dumb questions about Arduino/Teensyduino IDE
  117. Curious Audio Library Behavior
  118. Completed project: 4 Teensies and 96 meters of APA102
  119. Can we add a "Bare Metal" Forum?
  120. Teensy 3.2 digital output - protocol request?
  121. Very Simple Project Idea
  122. Memory Board to use big matrices of floats
  123. Why can't I do this:... with IntervalTimer
  124. Game-o-Tron 3000 (& 3050)
  125. K64 Beta Test :: Teensy 3.5
  126. Eclipse development without Arduino
  127. code compiles for Arduino Uno but multiple errors for Teensy 3.2
  128. (Almost) Finished Project: Daft Punk type Helmet
  129. teensy 3.2 upload problem
  130. startup time (400ms)
  131. Why Teensy 3.5 or 3.6
  132. datatypes bit depth
  133. Is the Arduino website down, or at least sick?
  134. Teensyduino 1.20 ??
  135. ILI9341 with fullscreen DMA Buffer for Teensy 3.5 / Teensy 3.6 only
  136. Teensy 3.6 plays video from SD-Card
  137. Teensy 3.2 Future
  138. Industrial Teensy
  139. Teensy 3.6 Beta project - Simpit for Kerbal Space Program
  140. Teensy CAN Bus IRQ
  141. Anyone have A better way to view *.h public functions?
  142. Understanding Parts of Teensy 3.2.
  143. Using teensy 3.2 in standalone application.
  144. Teensy 3.5/3.6 identification?
  145. Teensy 3.5/3.6 port/pin map?
  146. Microscope
  147. MyComm - Irdium Messaging Device
  148. i/o expander
  149. Teensy 2.0 Help Please!!
  150. Possible comparison of Teensy's and Apollo Moon Landing Computer??
  151. Funny? Teensy bricker with a degree ... ;-)
  152. Arduino 1.6.12 and Mac Sierra
  153. Two LEDs from a Single Pin
  154. Teensy 3 USB MIDI single byte transfers?
  155. MacOS 10.11 rawhid_send working with teensy2++, not with teensy2
  156. getting started with micropython
  157. USB MIDI Foot Controller Completed!
  158. Getting Started with Windows 10 Linux BASH cmd line interface
  159. uint8 over UART
  160. Thread safety, please...
  161. Zerynth (formerly Viper) vs MicroPython
  162. #include <ft2build> error in teensy AVR fontconvert.c
  163. E-paper and Teensy
  164. Teensy 3.6 programming a Teensy, like arduino boards can? :-Silly sidetrack
  165. Teensy 3.5 (maybe 3.1) CPU, BUS and SPI speed experiments
  166. Beginner's luck and madness?
  167. Library for teensy 3.x quadrature decoders
  168. Source code from TeensyLC to Teensy 3.2
  169. Working: Semi-accurate "RTC" for Teensy LC from internal clock
  170. Teensy 3.0 close-out sale
  171. NY Maker Faire This Weekend
  172. uncannyEyes and Teensy 3.1/3.6
  173. CoffeeCat - programming language & source-source compiler
  174. Prop Shield 9dof sensor fusion with XBee wireless for r/c or model rockets
  175. 3.6 with audio board?
  176. Adding to MicroPython for Teensy
  177. how warm the teensy 3.6 gets
  178. Teensy 3.6 USB Host support
  179. Teensy 3.6 EEPROM write
  180. Arduino.cc IDE Serial Plotter update
  181. Project Video:"The Groove Modulator" Stomp Box with Teensy, Audio Adaptor and ESP8266
  182. Stacking the audio adapter and the teensy
  183. Teensy 3.6 & 3.5 already on sale?
  184. MIDI Problems
  185. Speed of Teensy 3.5 and Teensy 3.6
  186. Advantages and disadvantages of RawHid interface
  187. math libraries
  188. Teensy Quadcopter
  189. MPU-9250 Teensy Library
  190. The Untold History of Arduino
  191. Stupid questions for Teensy 3.6
  192. keyboard firmware help
  193. Questions about teensy 3.6 from a kickstarter backer
  194. USB, two devices in one (HID Mouse + Xinput gamepad)
  195. Who has already got his / her kickstarter teensies? (international shipping)
  196. Bootloader for 3.6
  197. What does the HalfKay bootloader do?
  198. Teensy 3.6 Eagle Library
  199. I seem to have bricked my pre-production Teensy 3.6
  200. AVG warning of threat in teensy_post_compile.exe
  201. millisecond precision from Teensy 3* RTC
  202. Really Simple Newb Question about USB Host Shields.
  203. Preview of 3.5 & 3.6 Breakout boards -- Feedback welcome!
  204. Teensy 3.5 VGA Driver
  205. rtc
  206. Why does serial monitor freeze after hitting external reset button on T3.5 ?
  207. IntervalTimer/ISR question
  208. uSDFS for Teensy
  209. MickMake Teensy 3.5/3.6 Review Spotted
  210. MIDI-to-DMX for Keyboard and Electronic Drums
  211. Github down?
  212. Audiolib-MP3
  213. Driving touchscreen LED with IO pins
  214. Can't make MIDI in work with Teensy 3.2
  215. Teensy 3.5 & 3.6 Schematic Posted
  216. OctoWS2811 with Teensy 3.6
  217. MIDI and the Teensy 3.6
  218. Propshiled - polyphonic audio
  219. Teensyduino 1.31 and Arduino 1.6.7
  220. Access IBM Watson using this new Shield -> T3DUO
  221. Linear velocity from FXOS8700CQ - Prop Shield
  222. Encoder
  223. Hacking Library Adafruit Trellis Brightnes Control 1 LED
  224. Program button and PROG pin
  225. LED light strip question: has any one tried a linear lens?
  226. Playing around with yet another version of ILI9341_t3 library (ILI9341_t3n)
  227. LedControl Library for Teensy 3.2
  228. 3.6 not showing a port
  229. Teensy 3.5 and APA102
  230. Teensy 3.6 Serial Buffer
  231. How to make bulb horn or squeaky toy sound with audio library?
  232. Plenty of Teensy boards at Microcenter Atlanta
  233. Using PGA (Programmable Gain Amp) to improve range of ADC
  234. Teensy 3.3 ?
  235. Microseconds per second
  236. Teensy 3.6
  237. ILI8341ouch keypad code?
  238. E-paper Shield Kit
  239. Confusion on Power requirements?
  240. Convert RAW to WAV
  241. 18 servo control on Teensy 3.2 with interrupts
  242. New library and example: Read-TSL1402R-Optical-Sensor-using-Teensy-3.x
  243. Analog Supply Voltage
  244. Arduino Windows Store App
  245. Has anyone had any experience with Isweek.com
  246. Teensy 3.1 or Teensy 3.2?
  247. [ASK] Teensy & emmc???
  248. Teensy 3.6 ultra high-res high quality photos
  249. 3.1 Breakout Board and Extra Pins
  250. Teensy 3.5/3.6 overclocking
