View Full Version : General Discussion
Pages : 1 2 3 4 5 6 [7] 8 9 10 11
  1. Teensy 3.1 died
  2. what happened to pcbs.io ?
  3. pogo-pins
  4. Teensy 3.5 3.6 S.D. Card
  5. My first useful teensy project.
  6. Teensy 3.6 double precision
  7. New library and example: Read-TSL1410R-Optical-Sensor-using-Teensy-3.x
  8. Include Statement & Libraries????
  9. Command line loader updated
  10. Teensy 3.5/3.6 upload limit due to flash erase/write cycles
  11. USB ESD & EMI protection
  12. Cutting Teensy 3.6 down to size?
  13. Can Teensy use the Audio and Firmata library at the same time?
  14. Forum software update
  15. Barometer using Teensy2.0, BMP085 and LCD
  16. Serial Monitor..
  17. Teensy 3.2 & GY85
  18. Recent spam attack
  19. ILI9341 font builder
  20. Zilch cooperative multi-tasking for Teensy 3.x/LC
  21. Teensy EEM
  22. ArduCam OV5642 and T36
  23. OctoWS2811 Color initialization BRG
  24. Teensy PID ovencontroler hack
  25. Teensy 3.6 Bootloader
  26. TnyGPS backpack for Teensy (all 3.x versions)
  27. SerialFlash Print interface
  28. Add external NAND Flash
  29. Another fork of FlexCAN
  30. Layering shields
  31. Best practice int32_t or just int?
  32. ILI9341_t3 Touch Screen Trouble
  33. Rust Language on Teensy
  34. Porting from AVR to Teensy 3.2
  35. My goof your gain one pair purple of purple test boards for TFT
  36. Gray pins
  37. FTM Channel compare interrupts (Teensy 3.5)
  38. QP Frameworks working with teensy?
  39. Writing data to SD card (using board slot ) in Teensy 3.5
  40. Arduino 1.6.13
  41. Wondering: SPI Should we make using MISO optional?
  42. Candle-lamp made with Teensy LC
  43. compiler warning comparison between signed and unsigned
  44. Looking for a very large TFT Touchscreen
  45. Possible workaround for FastLED w/Audio shield issue
  46. TeensyCNC
  47. Cannot Upload Sketches
  48. Rotary Encoder on Teensy 3.5 Board
  49. MPU9250 Add-On for Teensy 3.6
  50. My dream Teensy battery charger-breaking out CHRG & POWER_ON lines on STBC08 charger
  51. Teensy & PureData: Difficulties reading Teensy 3.2 Pins in PureData
  52. How to control a stepper motor?
  53. Teensy USB Interrupts
  54. rosserial_arduino for Teensy?
  55. Saw Teensy 3.2 being tested for a a Swedish instrument to go to the Moon
  56. When is big enough to consider splitting a sketch up
  57. Part number of led D13
  58. Using CMSIS DSP for fast graphics FX
  59. setMOSI (et. al) on Teensy 3.6?
  60. Sparkfun is carrying 3.5/3.6 with headers soldered in
  61. Help needed with dual rotary encoder code
  62. How to be sure I'm using the FPU in T3.5/3.6
  63. VERY hard matlab problem!
  64. long double != double !?
  65. Teensy 3.1 PWM, TIP31C, and LED strips
  66. ST7735_t3: experimenting supporting multiple busses
  67. Teensy LC/3.5/3.6 WITHOUT Arduino
  68. Teensy 3.2's ADC Internal Reference Voltage and its Analog Resolution
  69. Seeking advice/opinions/ideas on combining HID devices
  70. IDE 1.6.13/TD1.32 works on beaglebone black
  71. Interrupt vectors for Teensy 3.5
  72. IDE Sketch Open Yields New Window
  73. PS2 Keyboard Library & Teensy 3.1 compatability
  74. If I had a magic wand for Arduino/Teensy development with multiple devices on one PC
  75. Starting PMBus library for Teensy with i2c_t3
  76. Teensy 3.5/3.6 Breakouts Available Now + Discount for PJRC Forum Members
  77. Troubleshooting LED strip
  78. T3.6 - Using an external clock for FTM timers
  79. Wiring Help -- Color 320x240 TFT Touchscreen
  80. too much GLOBAL VARIABLES ?
  81. Toolchain update - will need help testing
  82. Color 320x240 TFT Touchscreen - Touch Help
  83. Teensy LC port of OctoWS2811
  84. Higher Rate From FrequencyTimer2
  85. Alternative 'greyed out' pins on Teensy layouts
  86. Teensy 3.2 Pin 13 use as a data pin.
  87. Cmsis rtos?
  88. A DMX-controlled Christmas Tree
  89. 2.8 TFT Color screen: how to tft.println int values?
  90. DSP without CODEC - How?
  91. powering down gracefully?
  92. Have version of Wire library that supports Wire1, Wire2, Wire3...
  93. Separate board MK20 and MKL02
  94. Merry Christmas and thanks for creating teensy
  95. teensy available from mouser
  96. Non-deterministic program
  97. Using the SD card -- how to convert the file read data to int
  98. Accessing multiple hardware SPI busses
  99. Fritzing components for teensy 3.6
  100. Teensy 3.5 Autonomous Robot
  101. delay() in REDUCED_CPU_BLOCK using Snooze
  102. Addressable LED Strip Discussion
  103. May want to revisit Teensy pricing
  104. PJRC server migration
  105. Teensy 3.2 IC identification
  106. Maybe updates for: SPI, Wire, ili9341_t3 libraries...
  107. EMI Affects Teensy 3.6 More Than 3.5 and 3.2
  108. DMX controller for LEDs and Moving Heads with Bpm Tap
  109. USB panel jack part
  110. And yet another Teensy 3.6 breakout board.
  111. Docs on DMA?
  112. CPU Architecture
  113. Help integrating SBUS library for teensy?
  114. Teensy 3.6 lan8720a ethernet
  115. FTM Timing of up to eight simultaneous signals
  116. FTM Timer issue
  117. bit banding
  118. Poll: Anyone interested in my robotic arm work?
  119. Hardware - digital Input protection
  120. is this a fake teensy 2.0?
  121. Teensy 3.6 + Adafruit Ultimate GPS
  122. LoopLauncher
  123. LiquidCrystal Library
  124. min/nom/max power on Teensys
  125. Teensy LC game pad programming.
  126. Correct pins/headers for stacking
  127. Teensy Feather, OLED wing, lipo battery and Snooze library fun and results
  128. Does Teensy have an official logo?
  129. SPIFlash library problems
  130. Falling-Up Robot Project for Teensy 3.6
  131. code hanging
  132. Teensy 3.x multithreading library first release
  133. Why the switch from Atmel to NXP?
  134. Porting some high res timing routines from arduino DUE SAM3XAE Cortex M3 to teensy3.6
  135. CAN-BUS implementation of Stand-alone ECU to RS232 Serial stream
  136. Code for BerryIMU (accelerometer, gyroscope & compass) and Teensy 3.6
  137. Help with IntervalTimer scope
  138. Help with IntervalTimer scope - SOLVED
  139. Teensy Wifi and Sockets
  140. SPI chip select
  141. Tutorial on how to disasm / objdump via Arduino "Export compiled binary" menu
  142. Teensy used with X-Plane and Air Manager
  143. Serial connection to Mac computer closed for unknow reason: possible causes?
  144. Is the Teensy boot loader source available?
  145. Logging data from Teensy using the Arduino IDE
  146. Could a Teensy survive a trip to the moon?
  147. Access Denied.
  148. Encoder counts wrong on Teensy, fine on Arduino Mega
  149. Volatile. A little knowledge is dangerous
  150. virtual shields library support
  151. randomSeed( elapsedMillis)
  152. Flextimers and other timing routines + finding sourcecode for libs/functions
  153. USB Host vs Device power on T3.6
  154. Practical UART speeds for T3.6 to T3.6 Communication
  155. Silly Noob Question: What voltage do the PWM outputs deliver?
  156. Options for 'bare-metal' development
  157. Fritzing file for the Micro SD Card adaptor
  158. External Power Guide Teensyduino 3.2
  159. How to enable virtual COM port in Teensy 3.2 like Arduino Uno in Windows 7 OS ?
  160. Base resistors for transistors - Laundry room alarm and ventilation
  161. Reset and Program are I/O pins?
  162. voltage input trigger
  163. Teensy 3.6 resetting with Serial + Wiz820 Ethernet
  164. Best combination of components to make a great IoT-Device for beginner-students
  165. i2c_t3.h versus Wire.h with LCD w/i2c backpack and teensy 3.2
  166. Does the teensy 3.5 also have a second usb port?
  167. Newbie questions -> Teensy 3.2
  168. Wiring.h
  169. Teensy 3.6 - How to get started with Register level programming
  170. Stalled serial/USB port: how to unstall it without restarting the computer?
  171. Teensy and Xplane (I'm missing something)
  172. New board report
  173. shaft encoder situation
  174. New OctoSK6812 Library on Github
  175. How does 120 MHz FTM Clock rate drift over time?
  176. X-Plane 11
  177. What is the state of art about using hw resources in libraries with teensy 3.x?
  178. Two servos at once?
  179. Teensy tied with a little pink bow and a bag of pixie dust for sprinkling
  180. Question about SdFat-Beta
  181. Any experience using Adafruit VL6180X sensor with Teensy 3.2/3.5?
  182. Reliability: Teensy Appropriate for Dedicated Industrial Grade USB Device?
  183. Anyone interested in micro USB to PCB adpaters?
  184. baud rate calculation
  185. I made a Teensy LoRa board
  186. Blinky example preferrably CQ CQ GM
  187. life after teensy
  188. Bulk discounts?
  189. how to use GDB with teensy 3.2?
  190. What is a Reccomended performance envelop for Teensy Lab set-up
  191. RNGA - Random Number Generator
  192. teensy 3.2 random number generation?
  193. Teensy 3.6 uses?
  194. Teensy 3.2 live debugging?
  195. OctoWS2811 Signal & Power ?
  196. Teensy-LC 5v Pin?
  197. Blink example changes freequency?
  198. Encoder direction problem
  199. Max98357
  200. Pullup vs gpio output drive
  201. Teensyloader questions!
  202. Teensy 3.6 controlled motorfader panel
  203. teensy 3.2 overclock over 96Mhz
  204. .c files to teensy 3.x
  205. Gas Sensor Module Demo
  206. Teensy 3.2 I2S BCLK true value.
  207. Synchronized multi-frequency PWM outputs?
  208. Stumbled upon a Kicad library for most all of the Teeny models.
  209. ARM teensy without arduino
  210. MIDI projects with expression pedals
  211. EEPROM wear leveling
  212. ERV travails
  213. Teensy 3.1 3.2 power and communication with raspberry
  214. Suggestions for pcb design in Linux?
  215. New OLED shield for Teensy 3.x and LC
  216. Teensy 3.2 with NRF24L01+
  217. Teensy 3.6 USART receive interrupt
  218. DIY Helicopter-Controler for Arma3
  219. No such file
  220. Teensy microcontroller showing slow fall time (but fast rise time)
  221. Debugging strategies
  222. new audio project
  223. TeensyLC with 16x2 OLED display
  224. C64 Emulation with Teensy 3.6
  225. .MP3 Doorbell
  226. Digital harmonica
  227. Touch to MIDI interface using Skintimacy and Teensy
  228. Snooze - Finding all the Gotchas
  229. MIDI nearly silent stepper motor interface - motor loudness test
  230. New TeensyDMX library for Teensy 3
  231. A set of scope-tested 100-500 ns delay macros
  232. Buying Freescale processors on Alibaba
  233. Using Teensy with libPNG
  234. Fab terminology
  235. Question about the spectrum analyzer example, best practises and making it smooth
  236. Constant SD card write time on Teensy 3.6?
  237. Robot or Robotics projects using Teensy 3.6?
  238. Crc32
  239. BME280 Teensy Library
  240. Up to 8 channel delay timer
  241. Lincence "no commercial use"
  242. How best to manage multiple SPI busses?
  243. Writing to and Reading from Teensy 3.2 on MATLAB
  244. OS9 For Teensy 3.6/3.5
  245. Ant+ libarary and USB driver for Teensy 3.5/6
  246. My Arcade Machine (with Teensy controlled game-pads)
  247. Teensy 3.5 on TV
  248. Self calibrating scaled output: MIDI Guitar Pick project
  249. PIN Layout for the Teensy3.6 SPI Busses 0,1,2 can It be done like this?
  250. Firmata Test port menu just hangs?
