View Full Version : General Discussion
Pages : 1 2 3 4 5 6 7 [8] 9 10 11
  1. SD write and read with same time accuracy
  2. arduino.cc
  3. Free online Font creator for Adafruit libraries
  4. SD or SdFat for Tweensy 3.2
  5. Custom board with JTAG header for Teensy 3.2
  6. Tips on soldering pin headers on T3.2
  7. hey paul
  8. New Ticker (Timer) Library
  9. teensy 3.2 and Xbee connection
  10. Source code and definition for the followings:
  11. Add new function in SSD1351 to stop SPI Bus
  12. New Internal Temperature Library
  13. Is Teensy 3.5 compatible with X-Plane 10?
  14. Teensy 3.0 Problems with moderate range (~40m) OneWire Signals
  15. New Teensy 3.2/3.1 shield
  16. DIY Teensy 3.2 feat. zero-layer 'PCB'
  17. Question on pin mapping 2.0++ keyboard
  18. audio quality recording
  19. Paper printing from ArduinoIDE - OS X
  20. A wrong way to level covert RGB pixels (WS28xx/neopixel/API102/Dotstar)
  21. k66 ethernet rx interrupt
  22. Identifying a bad USB cable?
  23. pinMode(0, OUTPUT_OPENDRAIN);
  24. Teensy 3.6 USB MIDI host development status
  25. Microchip lead times
  26. New Stepper Motor Library
  27. Obtaining the Library: IEC60730B KINETIS Safety Routines VDE v2.0(REV 2)
  28. Teensy and Continuous Integration
  29. Examples PushButton and PushButton Pullup
  30. easy to understand built in sd card tutorial for 3.6 teensy?
  31. SPI vs I2C
  32. Teensy 3.5 & Adafruit NeoPixel
  33. Arduino to Eclipse (MCUXpresso or KDE)
  34. SPI display with no chip select - how to connect it
  35. Is the Teensy++ 1.0 still supported?
  36. Teensy 3.6 RS485 Support
  37. Extended database on Teensy 3.6
  38. Strange Compilation behaviour
  39. Low latency data logger
  40. elapsedMillis and Crystal for Real Time Clock
  41. minor disaster with T3.5 board
  42. Windows virus sanity check
  43. Charger + Soft Latch Power Switch for Teensy
  44. Speed test and optimizations--some surprises!
  45. Just for fun: Teensy 3.6 image under full load
  46. PRJC Shipping Times
  47. Bay Area Maker Faire 2017
  48. PinChangeInterrupt Library for Teensy 3.6
  49. Teensy 3.5 usb host?
  50. Fun with pins
  51. DiscoJar: Sound-Reactive-Lamp-With-288-RGB-LEDs
  52. Yield and SerialEvent... and when internal functions should call yield?
  53. High-Frequency High-Accuracy Photodiode with Teensy 3.2?
  54. Accessing SPI bus in Teensy 3.6
  55. Teensy 3.6 audio jack wiring?
  56. Using Teensy 3.6 with non-Arduino software?
  57. My first O/S hardware board: Teensy LC -> RFM95W Utility Board
  58. font, image and video extractor "MCU Resource Maker"
  59. 2 For 1 CMSIS FFT
  60. How to quickly toggle 38kHz signal?
  61. Make Teensy and Raspberri Pi communicate? (without effort for the Teensy)
  62. Teensy guitar tab player
  63. Teensy 3.6 maximum pin toggle rate
  64. Xplane move aircraft
  65. How to describe the teensy 3.6 more than a review ?
  66. Can I use teensy 3.6 or 3.2 with scratch for arduino ?
  67. FreeRTOS availability?
  68. Neopixels (WS2812 or SK6812), interrupts and IntervalTimer
  69. Arduino 1.8.3
  70. Multichannel Sterile filler/checkweigh machine. Teensy 3.6, Teensy 3.2 slaves, RPI W
  71. Sound Reactive Light Bulb Installations using Teensy Audio
  72. Teensy 3.5 and Xplane
  73. Graphing library for the ILI9341
  74. Digole C2I 3/5v Colour display On Teensy 2.0
  75. C++ - Teaching old dog new tricks?
  76. Replace MKL26Z64 by MKL26Z128
  77. Teensy like a SPI Slave
  78. USB serial transmits blocking ADC interrupts? (75000Hz -> ~74700Hz)
  79. Happy about the new project, a DMX Controller
  80. Finished Fast 8080 Parallel ILI9341 Library
  81. Teensy_PGA
  82. Encoder Tester
  83. W25q128fvsig eol
  84. USB not recognized
  85. Teensy 3.6 SD Card Write Time Summary
  86. Teensy & Arduino
  87. how to handle teensy programming
  88. Teensy 3.1 DMA with SPI ... small bug?? Not quite working :-(
  89. Using Teensy 3.2 with 2 TFT Screen
  90. Event Driven API for PulsePosition
  91. informations about teensy 3.6 timers
  92. Teensy 3.5 ADC characteristcs
  93. Simple potentiometer
  94. Ease of programming with "raw" C++?
  95. FTM timers
  96. Intel discontinues galileo, joule, and edison
  97. what is the best way to detect a 131KHz square wave?
  98. how warm the teensy 3.6 gets
  99. Reduce power consumption in the SD card.
  100. Vector Font library for Teensy 3.6
  101. Lost Mac Serial Port: Found it
  102. i2c_t3 Wire.endTransmission() return values 2 and 4?
  103. Video: FastLED simplex noise modulated by itself
  104. Split main sketch into multiple files?
  105. Board2Make, Makefiles generated from boards.txt
  106. Generate ESC DSHOT pulses using PDB PulseOut to an output pin.
  107. Installing Teensyduino on an Arduino portable
  108. PCB Assembly
  109. Trouble with Pololu QTR sensor library
  110. Programming serial transcievers--need help
  111. ADC Anti Alias Filter
  112. Best / Good Components starter kit
  113. Came across this video from 1979 describing computers/programming.
  114. Freelance proposal
  115. 17" Macbook Pro is obsolete this month, so no more OSX upgrades. which linux to use?
  116. Teensy 3.5 Single SPI vs. Multiple SPI
  117. Teensy Compatible Libraries
  118. Pedvide's ADC library - multiple channel simultaneous & continuous acquisition
  119. DIY Car Heads Up Display Using LED Strip
  120. MPU-6050, RTC DS3231 and Reset button Problem
  121. Jitter-free DAC output using the FIFO and DMA
  122. Quadrature encoder help
  123. Forum bug
  124. Is this a fake Teensy 2.0
  125. Code tag button now shows in quick edit
  126. Stella - The Electronic Trumpet!
  127. Not to undercut Sparkfun, love the company, but I saw a deal
  128. SPI files/libraries - SPI, SPIN, SPIFIFO, ...
  129. Teensy LC with NS-RS232-01
  130. uSD card write time and coding around it
  131. Complete newbie interested with Teensy for MIDI foot controller
  132. Using several SPI units om Teensy 3.6
  133. 5V Boost and Lipo/Li-ion Charger
  134. Teensy UART (Hardware Serial) and I2C problem
  135. Wanted: a USB charge-only cell phone cable
  136. Example code for MIDI controllers with Pots and Buttons
  137. Serial buffer size increase Teensy 3.2
  138. teensy not so teensy?
  139. How to program MKL02/MKL04 MCU without soldering them?
  140. FPGA for Teensy?
  141. Sdio
  142. Best communication interface for multiple Teensy LCs and 3.Xs
  143. Base Emitter Resistor for 6N139 on MIDI input?
  144. Touch7834 driver for resistive touchscreen
  145. another FFT application: doppler radar processing
  146. Clever spam bots
  147. Problem with a software SPI, teensy interface BNC DAC pin 14
  148. Bringing Projects Through Airline Security
  149. Android phone/tablet or micro wireless kbd/mouse/macro player. Control any system/OS.
  150. Any takers: "nearly all pins" teensy 3.5 connector board
  151. Defective Teensy 3.2's ?
  152. Teensy 3.1 keyboard script execution
  153. New to Teensy, got a few questions for those with knowledge
  154. TELEZ Teensy realtime, Raspberry fileserver, PARTICLE cloud connection
  155. How to protect from 3v/ground short
  156. Access pin registers
  157. Second DAC output from Teensy 3.2
  158. 8x8 RGB LED PWM matrix with TLC5947 which IC to use on the cathode end?
  159. Need some help passing arrays
  160. SPI Library use on Teensy 3.5
  161. Teensy: Technical nostalgia
  162. Post in wrong forum
  163. Windows Serial Installer distribution
  164. Send a GPS String with a length more than 64 bytes via i2c (as slave_writer)
  165. Remove device from I2C
  166. display white balance / color correction
  167. prototyping/software develpment on 3.6, running on a LC of 3.2
  168. Teensy LC not turning on!
  169. Temperature rating?
  170. k6x LAN8720(A) & lwip
  171. A second T31 Precision Frequency Standard
  172. USB Host Mouse Driver
  173. Another T3.5 Rover with a OpenMV Camera (Machine Vision)
  174. Bike computer project
  175. Pioneer NEX control Windows 8 PC
  176. Teensy 2.0 input pin?
  177. cheapest USB C to Teensy solution?
  178. Teensy at the SFMOMA
  179. Can you use C++ or Objective C with a Teensy 3.X?
  180. Teensy Plugin and XP11
  181. Teensy 3.6 VGA driver
  182. Eclipse & Fire Art
  183. Contiki IoT OS port for Teensy Boards
  184. Add a library to Teensyduino
  185. alternatives to the MK20DX256VLH7
  186. Two 4 Digit Adafruit displays for 8 digits
  187. Thumb operated joystick question
  188. FPGA for beginners ?
  189. noob problem w breadboard
  190. A UBlox GPS Module Primer for beginners
  191. Raspberry Pi Hardware
  192. Help with some math
  193. pitch/zoom/scrolling
  194. Compress ili9341 images (Tool)
  195. LEDscape is it still a thing?
  196. Teensy USB MIDI - adding Song Position Pointer (SPP) to core library
  197. Pixy Camera with Teensy 3.5 and SPI
  198. Teensy: USB MIDI Bandwidth
  199. HiRes Spectra with LoRes FFT
  200. High Reliability Serial Firmware - Library and Template
  201. Sending Commands to Windows (or Mac)
  202. Teensy 3.2 as Flight Sim Controls + Joystick
  203. Internship
  204. Bug in delayMicroseconds: 25% too short for const delay < 64us
  205. A tutorial for using custom fonts with Adafruit GFX libraries
  206. Teensy 3.x Flextimer as counter: external reset?
  207. Arduino shield tft to Teensy
  208. Updated TeensyDMX to support Serials 4-6
  209. Weensy 3.6 now available
  210. Teensy 3.2 max current
  211. some simple mathematical exercises
  212. Toggle TO momentary button press code:
  213. Ia anyone using the Fusion dual can shields or GPS shield
  214. Multiple functions for same button (Single press, double press, hold, long hold)
  215. How much current can I get from the Vin pin on a Teensy-lc?
  216. doing FFT from an existing array, not from ADC?
  217. A few questions about teensy 3.6 , leds , and ethernet
  218. Olga
  219. LiFePo4wered group buy (Germany and maybe close neighbours)
  220. Double counts with magnetic hall effect sensor--desperate for help.
  221. Is long SPI cable earth shield needed?
  222. Sub microsecond time measurement-again
  223. Teensy 3.6 in circuit programmer
  224. T3.6 standby commands?
  225. What's the max USB Serial speed of Teensy 3.6?
  226. A PWM/FMT minimal example
  227. Sharp PC-900V Optoisolators for sale (Used for MIDI input)
  228. What's the fastest clock that can be used with FTM?
  229. SPISettings
  230. Wiring devices to Teensy 3.2
  231. Teensy 2.0 EEPROM default?
  232. MK20DX256VLH7 out of stock EVERYWHERE??
  233. Control IOs from your Mac or Windows computer (Wirekite)
  234. What's the relation between Teensy 3.6 pins and the PWM MUX value?
  235. nRF24L01 with Teensy 3.5
  236. Products made for use with Teensy
  237. i2c slave controller for multiple slave arduino/teensies
  238. FTM code from documentation doesn't work
  239. FT6206 on Teensy 3.x with multitouch
  240. Custom Teensy LC
  241. Serial Output with External Power Supply
  242. Who bought up all the MK20DX256VLH7 ?
  243. Proramatically initialize arrays of library defined data types?
  244. Feather Adalogger vs Teensy 3.6
  245. Formating icons not showing in FireFox
  246. Compiling the Atmel cryptoauth-arduino library
  247. Teensy 3.5 reduced power mode
  248. Stacking of two Teensies
  249. T 3.6 reading two analog inputs simultaneously
  250. cheap pots over wire-wound for uC controls?
