View Full Version : General Discussion
Pages : 1 2 3 4 5 6 7 8 [9] 10 11
  1. Where should a beginner start with?
  2. Freqcount library, can it be modded to use a gate input on capture pin 8?
  3. Smoker Temperature Controller
  4. read 2 differential analog signals simultaneously using teensy 3.2
  5. Best way to check if an array has changed
  6. Raspberry -> Teensy -> USB -> PC
  7. Raspberry pi for programming teensy?
  8. Teensy Comparison Website (Non PRJC)
  9. ACAN : a Teensy 3.1 / 3.2, 3.5, 3.6 CAN driver
  10. string help
  11. 3.5 eagle file?
  12. Teensy 3.6 write time to microSD
  13. Teensyduino on Arm64 Jetson TX1/TX2
  14. Teensys CHEAP
  15. Marlin 32 bit for teensy ?
  16. USB HOST Adapter
  17. TeensyStep build errors
  18. Teensyduino/Arduino - what do the predefined menu entries do? (i.e. "keyboard mode")
  19. teensy 3.6 is getting hot and not booting
  20. DipTrace Teensy 3.5 and 3.6 PCB Library Models?
  21. Teensy 3.2 + RTC: time_t number is negative (?!)
  22. High sampling ADC for teensy 3.6
  23. can I supply my teensy 3.2 with 1.5 volts or 3 volts(not 3.3)?
  24. PCF8574T / PCF8574AT running at 800 MHz
  25. Teensy 3.5 usb host
  26. Teensy 3.6 IDE
  27. Docs on DMA?
  28. Multiple 3.3v and Gnd connections to PCB
  29. Display for teensy 3.2
  30. Arduino 1.9 has multi-cpu parallel build
  31. Connect up to 16 rotary encoders on the I2C bus
  32. Serial monitor port problems (W7sp1)
  33. Teensy 3.6 high current when using RTC Vbat pin
  34. TFT display - text scroll or text wrap?
  35. RA8875 with Teensy 3.5 - not initializing
  36. Custom teensy 3.2 board with nRF52 bluetooth and more
  37. TeensyView numbers in full height on the displays
  38. Using Segger tools instead of Arduino IDE
  39. Arduino or C
  40. Commodore 64 VIC Emulation on the Teensy
  41. Teensy and DisplayLink?
  42. T3.5 LCD and RTC on I2C - lock up
  43. Serial communication between 2 teensy
  44. Eclipse Arduino Download Manager for Teensy
  45. Writing to microSD card Teensy 3.6
  46. Teensy programs Teensy
  47. Problem compiling IridiumSBD library with Teensy
  48. Teensy 3.6 Eagle Design Block
  49. Pin connection for touch screen.
  50. New Teensy project: Infrared Remote Control for your Computer
  51. New CBOR (RFC 7049) processing library
  52. Damn those SPAM postings ...
  53. Teensy 3.6 SD card
  54. Teensy with SD Card
  55. Debugging Teensy project with GDB & SWD?
  56. Arduino/Teensy. Would like ability to retrieve server client that hasn't sent data.
  57. T3.6 USB Host - Raw Hid
  58. TechShop closed
  59. New Teensy 3.5 based light saber kickstarter
  60. control DAC: conversion speed and voltage referance
  61. PCB trace width for high current application
  62. DAC:speed conversion and reference voltage
  63. Use Teensy with USB Hub and USB flash drive
  64. T3.5 Locks Up when assigning Long to Float... (Surprised)
  65. RA8875 + Teensy3.5 + Resistive Touch Scrren
  66. Octo rocks!
  67. generate a sine wave
  68. ALDI thongs killed my teensy 3.2
  69. SPI: important difference between Arduino Atmel and ARM
  70. Teensy 3.5/3.6 40 I/O + 2
  71. Possible to connect this to a Teensy 3.2?
  72. what are relevant defines for Teensy
  73. Teensy 2 -- Program is too big when I remove code?!?
  74. Teensy 3.6 + Audio Shield + TFT Screen + Ethernet = is it possible?
  75. Happy Chanukah!
  76. Rules to sell commercial products with teensy
  77. New board report
  78. teensy 3.x: port registers?
  79. Teensy 3.6 USB Host MIDI
  80. variable historical tracking
  81. Error Compiling for Board Teensy 3.6 - McAfee Problem
  82. 8 Bit uLaw decoder
  83. Voltage limit on Teensy 3.6 for RTC Vbat?
  84. Weird digital write behavior in TeensyDelay library and digitalWrite in interupts
  85. Program Teensy from another Teensy?
  86. uNav AHRS
  87. Current Windows Update (V1709) slows down compiling with Visual Studio
  88. 'minimal' Nixie tube clock
  89. “String” function
  90. USB MIDI Foot Controller with OLED v3.01
  91. Accessing bottom pads on T3.6
  92. 3.5 144 lqfp diy
  93. Any Plans for a Teensy Board with Bottom Pads on Top?
  94. Hardware Sega Genesis Video Game Music Player (Teensy 3.5, YM2612, SN76489
  95. Use of the bootloader chip question
  96. SN74HC165 shift register revisited
  97. T3.1 DS1307RTC and BME280 i2c communication
  98. I2C, SPI, ESP webSockets controller for teensy
  99. Kicad component for LQFP version of the K66
  100. Timed loss of serial port in Arduino IDE
  101. Installing Teensyduino on Raspberry Pi 3
  102. New project code named: teensquitto
  103. PCB layers for teensy 3.
  104. uNav INS
  105. Giant LED Sculpture - Know anything about it?
  106. Using GDB & the Segger probe with platformio
  107. hybrid male/female 24 pin headers ?
  108. Teensy 3.5(6) PCB cut :)
  109. Teensy 3.6 problem reading analog channels 14 to 17
  110. Encoder direction problem
  111. Multiplexer with 3.3v logic
  112. where is that writeup on serial comms paul S did a few months ago. I can't find it.
  113. T3.6 USB Host - Joysticks
  114. Custom SPI1 code on Teensy 3.5, has anyone bus-analysed 1st byte output in all modes?
  115. forum changes? can't edit old posts
  116. increase usb polling rate
  117. Is there a way to install linux?
  118. Teensy 3.2 & Noritake VFD
  119. controlling the amplitude of a PWM
  120. Any idea to make the old sensors compatible with 3.3V teensy 3.6?
  121. Yet Another Teensy Flight Controller Implementation
  122. Need help!
  123. T3.6 USB Host - Bluetooth
  124. How Do You Compare the STM32F4 (180MHz) with the K66?
  125. Any concerns about Spectre?
  126. KiCad Symbols for bare K66 Chips, as used with Teensy
  127. Midi / sound card
  128. TI ADS1256 8 CH, 24 bit A/D
  129. new audio project
  130. Teensy 3.2 Together with "USB Host - Keyboard to ASCII Converter" Need help
  131. External A/D 4.096v Reference - Teensy 3.5?
  132. Need help
  133. Weird issue with Serial.dtr() ?
  134. how fast is the analogRead on 3.5 and 3.6?
  135. Way to Check Hardware Serial in Use?
  136. bus frequency
  137. Ports menu changes coming
  138. PlatformIO: Huge update for Teensy development platform 3.0.0
  139. Teensy 3.2 CAN-Bus ECU Reader with OLED: VIN request
  140. Teensy 3.2 - product life cycle
  141. Bluetooth Low Energy (BLE) Connectivity for Teensy 3.X Boards
  142. Ili9341
  143. Teensy 3.2 Keylogger with SIM800L Need help
  144. proper way to override functions in the distribution library
  145. binFontsTool - Excel based multi-libraries fonts editor and converter
  146. Teensy 3.6 - Wow, what a platform
  147. Multiple SPI Devices - Two's Good, Three's a Crowd
  148. PIT timers not working
  149. Existing systick_ISR and Event Responder Library
  150. Total idiot can’t work things out - midi controller - multiple usb out
  151. Datatype selection
  152. Slow ST7735 on Teensy 3.2
  153. Does the Arduino dev sys compile 32 bit code for Teensy 3.2?
  154. My USB to I2C/GPIO/UART/SPI/ADC/PWM/INT... Adapter Cable
  155. Project: SPI_MSTransfer
  156. HID Device Supporting Turkish Keyboard Layout ?
  157. Configurable usbMIDI Port Names
  158. I would like a 3.5 inch 480x320 touchscreen display!
  159. Through-hole plugs/clips instead of headers?
  160. T3.6 SDR Control Box
  161. Teensy Pin Planner Spreadsheet
  162. Neopixels and encoders
  163. Using two Teensy LC to handle 16 rotary encoders
  164. 3.6/3.5 Dimensions
  165. Arduino - Teensy difference?
  166. Teensy Goes to Space!
  167. wanted: 3.5's already pinned
  168. Where to start
  169. Domesticating an encoder
  170. General questions about implementing a 88-key MIDI keyboard
  171. Does anyone want a standalone Teensy 3.6 REFBOARD bare PCB?
  172. Continually blowing UART RX on teensy 3.5
  173. How to get a
  174. JTAG/cJTAG/SWD on teensy and achitecture
  175. (Question) zephyr support for teensy.3.x ?
  176. LED Pin on Teensy 3.6
  177. sk6812 side 4020 smd led datasheet
  178. Any Teensy Library for Proteus
  179. New lightweight OSC processing library, LiteOSCParser
  180. New to Teensy
  181. Runtime errors maybe
  182. Newbie question about serial pins on teensy 3.2
  183. Digital Logic Voltage Threshold (w/ FreqMeasure library)
  184. Teensy 3.6 ADC interval timer read problems
  185. Cortex M0+ on the Teensy 3.6?
  186. ADF4351 Modules - UHF Signal Generation
  187. Can we edit posts now?
  188. Port interrupt programming in Teensy 3.5
  189. Circular_Buffer
  190. The apps Midi Monitoring and Teensy
  191. Teensy ++ 2.0 prints randomly, with interruption.Р
  192. Hydreon connection with teensy board 2++
  193. Private talk
  194. Best way to communicate with Windows program
  195. Teensy 2.0 interrupt
  196. How do I monitor serial output on raspberry pi 3.
  197. Problems with 8x8 RGB LED Matrix
  198. Does addressable UV LEDs exist?
  199. Voltage reference question
  200. Three broken Teensy 3.2s
  201. I2S Microphone List
  202. Teensyduino
  203. Teensyduino installation
  204. MagicDragon board from Hackster.io
  205. How to implement digital logic with diodes?
  206. "async write" SD card access, filesystem library (Teensy 3.6)
  207. <MIDI.h> in external .hpp/.cpp file and callbacks question
  208. Teensy 3.6 and LCD screen
  209. How Can I Get A Stable And Accurate Sample Rate?
  210. PCB's with the Audio Shield
  211. SSD1306,DIGISpark OLED not working with teensy 3.2
  212. <Audio.h> in external .hpp/.cpp file compile errors
  213. EnchantOS and LiteFXOS, Libraries for Props
  214. Teensy USB Serial
  215. New Forum Look
  216. How to use Teensy USB Serial in external library?
  217. 24Vdc Analog data logger 200hz - Has someone already done the work for me.
  218. Rotary encoders on i/o expander 16x
  219. Teensy Feather, OLED wing, lipo battery and Snooze library fun and results
  220. DS3231 32khz output instead of crystal for Teensy 3.2?
  221. Any ideas ? SPI talking to MAX11633 ADC
  222. 3.6 USBHost_t36 USB Hub examples?
  223. Teensy Wifi and Sockets
  224. Midi Controller Completed!Thank you Forum Members for your Guidance with my Project.
  225. SDFat writing good files and corrupt ones
  226. Teensy 3.5 RX1 PTB16 RX1
  227. Teensy 3.x with LabView & LIFA
  228. Examples PushButton and PushButton Pullup
  229. Three cheers for Daniel Gilbert's Teensy 3.2 Breakout board!
  230. 6-bit dac in comparator on K64 and k66
  231. Android wireless kbd/mouse/ and macro recorder/player. Control any system/OS.
  232. Improving range between two nrf24l01+?
  233. Availability of Teensy 3.5 uC's
  234. Common Mode Issues
  235. MIDI nearly silent stepper motor interface - motor loudness test
  236. Can the MK20DX256 be replaced with NXP MK20DX128VFT5
  237. New playback videos all MCU with FTDI screens
  238. Early version small screen graphics library
  239. How to spend hours debugging a Teensy3.5
  240. "async write" SD card access, filesystem library (Teensy 3.6)
  241. i need help
  242. Login problem with my mini desktop pc
  243. ADC problem with 3.xx
  244. RA8875 with 3.6 and touch debounce
  245. Anti-Spam efforts, May 2018
  246. Project: libxm_t3 (XM music module player)
  247. Hi all
  248. I an having trouble starting out with Teensy 3.6
  249. Interrupt controlled measurement of analogue values with TEENSY 3.6, FFT
  250. Watchdog timer and audio SGTL5000
