View Full Version : General Discussion
Pages : [1] 2 3 4 5 6 7 8 9 10
  1. While you're at it...
  2. I guess I'll go first
  3. Running Teensy 3.0 from batteries.
  4. Teensy 3 Encoder Lib
  5. 2/3Wire LiquidCrystal Library
  6. a GUI for Arduino "Guino-Dashboard"
  7. Cutting traces to soldering holes to solder in other components?
  8. Will the Teensy survive 110 degrees Celsius in the oven for 30 minutes?
  9. TeensyDapter
  10. Teensy 2
  11. Has anyone got the DS3234 SPI RTC working on the Teensy 3? (Beta8)
  12. Is current Teensyduino compatible with Arduino 1.0.2 IDE?
  13. Tennsy 2.0 as an iCade emulator for iPad (with an Atari 2600 joystick)
  14. Interesting article in circuit cellar
  15. scons SConstruct file for teensy3
  16. Teensy, tiny, Electric IMP Wifi SD card teams up with the Teensy 3.
  17. vB testing
  18. Using Teensy with Atmel Studio
  19. Embedded "low cost" Webserver with "email SSL" mates with the Teensy 3.
  20. Teensy 2++ & two Wii Nunchucks (Working)
  21. Everyone, except Paul, take the day off tomorrow ---> its Doomsday !
  22. Teensy 3 Excel Sheet
  23. Anyone working on a WIZ820io (WIZnet W5200) library for T3
  24. Teensy 3.0 based accelerometer datalogger
  25. FreeRTOS on Teensy (GCC, Linux)
  26. Step past Arduino enviroment?
  27. POV levitation-wand project
  28. Teensy 2.0 INT6 in Arduino
  29. Linux 64 bit - Please help test new toolchain
  30. Teensy 3.0 as flight controller
  31. Teensy as USB Adapter for X-10 CM17A "Firecracker"
  32. Teensy Diehards - A "universal" USB cable for development.
  33. New ARM toolchain for Teensy 3.0
  34. USB HID with Teensy 3?
  35. Teensy3 ST7735 Library
  36. Teensy 3 MicroSD guide
  37. T3: FYI Adafruit DHT22/AM2302
  38. Teensy3 to Nintendo Entertainment System
  39. Teensy 3.0 and Fritzing
  40. AVR Emulation on teensy 3.0
  41. DEV_DISPLAY_128X64 with I2C I/O Expander: Has anyone done this?
  42. Kudos from a newbie!
  43. Running teensy 3 @ 96mHz, bad?
  44. Doomsday Atomic "Alpha Clock Five" Project using the Teensy 3
  45. Any Teensy 3.0 enclosures ?
  46. Looking for a Teensy 3.0 with a male USB-A plug ?
  47. Teen3 up and running
  48. Tutorial on digital I/O, ATMega PIN/PORT/DDR D/B registers vs. ARM GPIO_PDIR / _PDOR
  49. Paul - Audio question
  50. Teensy3Monitor: Terminal-based Teensy 3.0 Serial Monitor App for OS X
  51. PIP-GRL 31415 (not spam!)
  52. Black Hornet Nano UAV
  53. Seeking info on chip/chip differences re peripheral functions
  54. USB Raw HID, Version 1.1
  55. 2x2 demux driven led matrix
  56. Teensy 3.0 and Android ADK 2012
  57. Using SR04, SRF05, SRF06, DYP-ME007 ultrasonic sensors on Teensy 3
  58. FastSPI_LED2 preview release, now with teensy 3.0 support as first class citizen!
  59. Sparkfun Pulse Sensor (amplified) on Teensy 3.0
  60. General question on microsd card
  61. SPI read problem on Teensy 3.0
  62. TeensyTyper - Teensy 2.0 script running dongle
  63. MIDI CC88 High Resolution Velocity prefix
  64. hey there all
  65. Teensy2++ with stonyman vision breakout board part 1
  66. Si4703 FM Tuner on Teensy 3.0
  67. place to buy speakers
  68. Teensy 2.0 - acting as a switch?
  69. Better alternative to arduino IDE ?
  70. I just have to say for the record
  71. help on all these different types of processors
  72. pcDuino
  73. The battle between Teensy 3 vs MBED Freescale Freedom - who will win?
  74. New I2C library for Teensy3
  75. Coarse and fine control with a single encoder
  76. TWBR-using Arduino libraries (please add to this list)
  77. Assistive device- chord EMG input for virtual keyboard
  78. Dymo Stylus Tact Alpha Keyboard for Teensy 3.
  79. First use of the Teensy 3.0, Wow!
  80. Teensy++ 2: rebooting instead of uploading code
  81. Very cool E-Ink display shield that could be converted to the Teensy 3
  82. WIP advanced Integrated Command Panel (CMC NightHawk Style) for X-plane
  83. Second preview release for FastSPI_LED2
  84. Sparkfun now carries the Teensy 3!
  85. Are there two Pauls?
  86. TeensyControls X-Plane Plugin
  87. Will PJRC be at MakerFaire in Bay Area?
  88. Maximum Number of Buttons
  89. Arduino Web Server Control
  90. Teensy 3.0-based device for measuring photosynthesis
  91. Regression Testing
  92. Another Teensy 3 ARM Competitor - CooCox Cookie
  93. X11 selection copy & paste
  94. Teensy 3.0 Breakout Boards for sale!
  95. DmxSimple, please help test new version
  96. Official Distributors
  97. Teensy.mk -- port of Arduino.mk Makefile
  98. Flight Simulator Control Project
  99. Kickstarter Android/Due combo
  100. Teensy3.0/Arduino 1bit DAC example
  101. First Teensy3 on two wheels?
  102. Spark Core (kickstarter project): Wifi for everything
  103. CMSIS for teensy 3.0
  104. Does Teensy 2.0 need decoupling caps on the power pin?
  105. [ Interfacing RASPBERRY PI / LINUX with the TEENSY3.0 ]
  106. Low Power "Green" Battery Operation Solutions For The Teensy 3.
  107. LEDHSV - help me test a library
  108. Maker Faire
  109. USB/IP WiFi programming with openwrt
  110. Teensy 3.0 Voltage 3.3v - Pc problem?
  111. Teensy 2.0 16bit Fast PWM
  112. IR Question not directly related to Teensy 3
  113. FastSPI_LED2, now fully armed and operational, if a bit undocumented
  114. USB MIDI iPad joy
  115. Fpu?
  116. What are the most important parts of your projects design?
  117. Need a really fast way to connect your Teensy 3 to the Internet via Wifi?
  118. How to change Teensy 3.0 PRODUCT_NAME ?
  119. smaller led than the ws2811?
  120. Any low cost, low energy solutions for playing MP3 files from TEENSY 2.0 ++
  121. Curious: Code size for FreeRTOS port, ARM vs. AVR; CPU speed
  122. ARM math library for Teensy 3.0.
  123. Teensy 3.0 in Fritzing
  124. teensy3 with IAR's IDE/compiler
  125. Serial.print(number) speedup for Teensy2
  126. Giving info on components that seem to work nice
  127. Project share: Control garage door with a web relay control board
  128. Question for Canadian Customer on Customs Clearance
  129. AccelStepper Library with multiple stepper motors
  130. Teensy uSD Data Logger Project --> The high performance, battery operated data logger
  131. WiFi module with an SPI interface- project...
  132. Durability of Micro USB socket?
  133. Teensy-Arduino adapter shield
  134. Query: USB PORT-TO-PORT FILE TRANSFER MODULE WITH BLUETOOTH ACCESSIBILITY
  135. Teensy 3 didn't arrive
  136. Teensy 3.0 + Ada FRuit VS1053 Audio Breakout Board Problems
  137. New WS2811 LED controller firmware for Teensy 3.0
  138. OctoWS2811 breakout board + Burning Man sculpture using OctoWS2811
  139. HVAC thermostat SmartStat Micro (using Teensy) at JavaOne 2013 Sep
  140. Teensy 3.0 and Adafruit SSD1306's matrix
  141. How do others develop without delay()
  142. Eagle library for MK20DX128VLH5?
  143. Serial2 show up on Serial Monitor for Teensy 3.0
  144. Intelligent Led Matrix Display Library
  145. Teensy 3.0 Memsic 2125 Dual Axis Accelerometer ?
  146. Teensy 3 as a osciloscope and logic analizer.
  147. Teensy 3.0 Breakout Mark II now available on Tindie
  148. Teensy 3 & SD cardinfo compilation errors
  149. The ultimate teensy project
  150. complimentary pwm with teensy 3 ?
  151. PCB construction Time lapse
  152. Paul, Teensy in a commercial product?
  153. Just another test
  154. Modules, in my arsenal, used for portable (battery) low power operation of Teensy 3
  155. Teensy 2.0 Arcade!
  156. Audio For Teensy3 - What Features Would You Want?
  157. Water cooler for my laser, need to halve temp sensor output voltage :(
  158. Laser Vehicle Guidance Parking System Project using the Teensy 3
  159. WS2812 LED with integrated WS2811 IC question
  160. Movie2serial newbie troubles
  161. How to learn ARM Cortex M3 Microcontoller
  162. Two Teensy 3.0 and 1600+ WS2811s at Burning Man 2013
  163. Running teensy2 codes on teensy 1
  164. Why would I want a teensy 2 instead of 3?
  165. using teensy 3 with neo pixel strips from adafruit?
  166. Two cool displays that can be used for Teensy 3 user applications.
  167. Teensy 2.0++ Excel cheat sheet
  168. 3.3v character lcds
  169. Forum : add tapatalk support ?
  170. Amateur radio repeater voltage monitor
  171. The LED is not always greener on the other side
  172. Having the hardest time with code that simply duplicates a mouse click or f5 push...
  173. Usb Type: Disk(Internal) Missing for Teensy3
  174. DSP Course Using Teensy 3.0
  175. $100 3D Printer/Scanner
  176. arLCD - 320x240 color LCD with touch screen
  177. Eigen math library for Teensy 3?
  178. Intel Galileo
  179. NeoPixel Teensy 3 Green AC Mains Clock Project The greenest AC Mains Clock in USA!
  180. How do I use teensy 3.0 without the USB port?
  181. My Teensy alarm clock
  182. gameduino 2
  183. PJRC Website Speed & Reliability, Feedback Wanted?
  184. Completed project: MIDI to DMX Interface
  185. Teensy 3 vs. Teensy 2 power consumption
  186. Logic analyzer
  187. Test
  188. Hole in the market
  189. Viewer counting problem - PJRC
  190. How to press <Alt>+<Shift> simultaneously?
  191. Alternative to WIFI shield, Yun, TP-Link??
  192. Teensy, Ws2811 and 18650 litihium ion batteries
  193. For those (like myself) that would like to learn Embedded C- UTAustin Edx!
  194. Mini project: do something with dma
  195. "Complete" implementation of Teensy 3.0 ADC as a library
  196. Goertzel
  197. Strange WS2812 NeoPixel backfeed current. FYIO
  198. Nominate forum users... for a special thank you gift
  199. Making A Custom Teensy3 HID Joystick
  200. Producing a product after Teensy
  201. badBIOS
  202. Any other way to use the sd card with the teensy 3.
  203. Sell a project
  204. Onboard Teensy 3.0 Compiler/Interpreter
  205. PJRC - Teensy
  206. Espruino Javascript STM ARM Microcontoller Board
  207. Teensy2++ with MacOS 10.9 Maverick and Xcode5.1
  208. male micro-B to male micro-B USB connector
  209. Teensy 3.0 Project: Twitter Taxi - Come see it in LA next week (11/21)
  210. Simulating a printer ?
  211. Permission request for Paul
  212. Teensy 3.0 Project Template
  213. Teensy 3 SPI wrapper class
  214. Altium library for teensy 3.0
  215. Footsy - Teensy 2 based MIDI foot pedal controller
  216. Father/son Noobs with basic questions?
  217. Is it possible to have a Teensy 3 I2C slave with the standard release library?
  218. Teensy 3.0 SD Card + SPI Encoder
  219. Before I sell them on eBay...
  220. Oh no, not another ARM microcontroller with built-in Python.
  221. Custom Declarations confuses customs and me!!!
  222. (Serial) messaging library for Teensy and .NET/Mono, with thermostat example
  223. Anyone in Australia/NZ looking to sell a teensy 3.0?
  224. Windows users: where do you put Arduino?
  225. Wireless SimpleHMI (Human Machine Interface) Project for the Teensy 3. FYIO
  226. Interesting Temperature Data.
  227. deal alert: SP-320-5 PSU's for $40 + $9.99 shipping (active PFC, variable fan, etc)
  228. OSH Park currently selling Teensy 3.1 at an amazing price
  229. Xmas trees and lights with Teensy and WS2811
  230. What wire to use?
  231. PT2313 audio chip
  232. Fun with cross-talk / inductance! :)
  233. here's some USB MIDI controller code
  234. " error=86, " message on teensyduino verify??
  235. Some libraries and a serial monitor for the Teensy
  236. teensy 3.1 as a GPIO extension
  237. Very Large WS2812B LED Project Using Parts of OctoWS2811 Library Help
  238. Simple Mutex and Lock classes
  239. Teensy 2 MDI Question
  240. WS2811 LED cube project description
  241. Visual Micro help needed
  242. I2CEEPROMAnything
  243. OctoWS2811 design
  244. GPIO expander chip library
  245. ATSHA204 Authentication Chip plus Teensy
  246. Anybody in Houston?
  247. Teensy USB options 1. Mass storage device, 2. USB pass through?
  248. Teensy 3 - Controlling Stepper Motors Guide
  249. printf and sprintf example
  250. TeensyLoader seems to choke on large .hex files
