- Pitch Detection on an ADC input
- getting a larger spectrum window?
- Teensy3.2 not responding on USB-serial when A2 and A3 used in Audio library
- A New Accurate FFT Interpolator for Frequency Estimation
- Power from headphone port
- Simultaneous Hearing through headphone or line_out while recording
- Beginner Teensy Volume issue
- Simultaneous recording and playback
- Broken support for Teensy family in Midi Library
- USB Midi output code - Please help me! :)
- WS2812B LED Strip Blinks When Using Audio Adapter
- Audio webpage issues
- Recommendations for a 16-bit audio DAC/codec IC?
- Problem with microphone powering up a comparator circuit
- Teensy LC, One ADC two Pins, How to ?
- Data logging Audio board Metrics
- Wireless audio stream using teensy 3.2
- Teensy 3.2 Multiple I2S Input
- Best microSD card for reading?
- Using Teensy Audio in a custom Library
- Prop Shield LC -- standalone amplifier?
- Changing Chip Select of Audio Adapter?
- Audio Processing Benchmarking on Teensy 3.2 and K66 (Teensy 3.6)
- IFFT and the Audio Library
- Audio tutorial kit and wav files
- Saving patches
- Ableton Link is now Open Source
- Audio Workshop: Part 1_4 // .Wav resetting
- if statement question in Recorder Sketch (Examples>Audio>Recorder)
- Question about recording to SD card capabilities
- Glitches in sine_hires output
- An Alternative Processor Package for Teensy 3.2
- AudioConnection to AudioEffectDelay Prevents Serial Comm
- Change Audio Block Size
- Prop Shield LC and Teensy higher volume?
- Parsing Left & Right audio channels for recording
- Implementing a standart audio filter
- Phase invert real time audio.
- Serial+MIDI+Audio Windows Drivers issues
- RMS detector and dB level
- Compressor Design using the Audio System Design Tool
- Audio Shield & Onboard Mic Troubleshooting (Urgent Project - Portland Art Museum)
- teensy touch guitar example not working
- is this setup possible?
- Multiple simulatenous audio files from single board
- Playing Audio While Running FFT
- break an AudioConnection
- how to read output of sine_fm1?
- Teensy3.2 and BC127 for Audio Bluetooth
- Voltage Regulator on Audio Shield
- Attempting to Creating an Audio Looper
- Discreprency between LINEIN info in SGTL5000 and Audio System Design
- Line level of teensy audio output?
- Noise with mic-in and notefreq
- Stereo Audio Recorder
- Errors Using Fir Filter
- Doppler shift using Audio Library
- Suggestions for Sound chip/design for T3.6 - similar capabilities of Propshield
- changing frequency when using playMem
- Engine Sound Simulation
- Minimum number of pins to connect Teensy 3.2 and Audio Board
- Real time Convolution Reverb (large impulse file)
- Teensy 3.6 PassThroughUSB example
- trying to compile wav2sketch and I can't find i686-w64-mingw32-gcc
- Following tutorial audio - collect2: error: ld returned 1 exit status Error compiling
- Gain Structure of the Mixer
- Simple Beat Detection
- Serial.print doesn't work with MIDI library sketch using USB Serial + Midi connection
- Mix sound from mic with SD card playing?
- Modulated Tuning? Quasi-Periodic Waves?
- Biquad Filter Transfer Function
- Understanding DFT / FFT Interactive Link
- Excellent results with Floating Point FFT/IFFT Processing and Teensy 3.6
- Reducing Noise - Analog Supply?
- Teensy not showing on Serial Ports, Not the usual problem
- False Peek Read
- Help using a library
- Can Teensy 3.6 replace [Quad-Audio + Teensy 3.2]?
- Audio board with SD card and concurrent SPI usage
- Real-Time Audio Processing with Teensy Audio Board
- Audio Adapter Board r: how to connect SMT Speaker and configure SPI pin for SD card?
- Faster Audio Library FFT Implementation
- Predominant frequency identification with FFT
- playmem latency
- Realtime audio processing with floating point math & new CMSIS lib in the Teensy 3.5
- Using Teensy 3.6 two DACs with Audio library
- Frank B's MP3 lib - changing sample rate
- How to mount Teensy 3.2 on Audio Adaptor Board properly?
- Audio Adapter Board not work?
- Using line-in for FFT
- Can I use a UA741 here?
- Using Audio objects within class
- Discussion about a simple way to change the sample-rate
- Increase number of I2S audio streams?
- Audio Shield Headphone to PC (MacBook) Stereo Mic input
- Repetitive click
- How to make bulb horn or squeaky toy sound with audio library?
- wavFilePlayerUSB
- Confusion about variable types w/ chorus tool
- Frequency shift with the Weaver method ("third method") using quadrature oscillators
- Bat detector
- Teensy 3.2, Audio Board and Optimized SD_t3.h failing.
- How to get audio output from dac pins on T3.5/3.6?
- Putting Formulas in HTML format on Audio System Design Tool
- Multiple microphones with Teensy Audio sheild
- Teensy for sending piezo sensors signal to MAX7 or Super Collider
- Audio visualization method
- fast inner product?
- Teensy Audio Adapter and Audio Library - Stream mic to serial USB interface
- Delay object in the library
- Offline Audio System Design Tool
- Male jack cable + connector for line-in
- Advice for working with multiple audio I/Os
- Stereo line in set-up question (GUI generated code crashes teensy 3.2)
- AudioMemory() - what parameter should I pass?
- Teensy LC with Audio board
- Question about Frank B's memory board
- A problem using the Audio library and ADC library
- Filter LFO issue
- Not able to get Sd Wav file to Play
- Audio Adaptor Board: Unable to play WAV song
- Teensy 3.2 + Audio + 16bit TFT ?
- Display BPM value
- Question about Teensy 4-channel setup
- Room analysis for room correction
- Routine for audio objects manipulation
- Slowing Down Playback
- help for REVERB effect memory usage
- Audio + LED in one Teensy Project
- PEAK object only reading 1.6v PP max
- Audio Library Interrupt Frequency
- Sinewave synth, modulated output
- Time signal LF Receiver Teensy DCF77 with minimal hardware effort
- Teensy Hearing Aid
- Pass I2SSlave input to headphone out or usb
- Hammond organ / roto2
- 16 Step 2 Layer Sequencer
- Fast Convolution filtering in floating point with Teensy 3.6
- Joining GND and VGND for latency test
- USB stereo output issue
- [ask]Need to Detect 1kHz tone peak amplitude by just using teensy 3.2 board?
- Audio Adapter Troubleshooting
- Reducing Power Consumption
- DAC on Audio System Design Tool not working
- Moving from Audio Shield to Prop Shield
- Planning the driver for the Teensy Audio Board LINEIN
- Latency and Jitter values for Teensy 3.2 DAC and for the Audio Board's i2s
- Problem with delay with extra memory
- Teensy 3.2+ ILI9341 +audio shield + 23LC1024 possible ?
- Confusion about Line in/out pins on Audio board
- SdioEX for 3.5/3.6 SD card playback?
- DAC freaking out with IR distance sensor
- Drum Synth clicking
- Avoiding aliasing
- Help with Basic Audio Lib results
- Audio Adaptor is not compatible with BLE SPI Friend
- Help required in design of a simple microphone circuit
- Teensy 3.6 / BUILTIN_SDCARD CPU pegged on Sandisk Ultra card (and not on other card)
- Midi Note Change with Potentiometers - Teensy LC - Help needed!
- Using Midi and USBMidi at the same time
- battery supply ground noise audio board
- Quick question regarding sample playback
- Simple_drum
- Floating-Point Audio Library Extension
- Teensy Convolution SDR (Software Defined Radio)
- String machine
- Not understanding wav2trw sketch
- sample/manipulate/jam instrument w/ Teensy. Possible???
- Guitar Multi-Fx Project Feasibility?
- Using the Serial Ports within an Audio object
- Gunshot Detection
- Swing and quantization for beat machine
- How do I implement cross-correlation to prove two audio files are similar
- Resonance?
- what is Audio Module Pin Mapping
- Audio Workshop FFT Sketch Issue
- Problem with FastLed Library and Audio Library Dac Object
- Teensy 3.6 I2S input without board
- shortwave radio simulation
- Strange Sound with T3.6 & Audio Adaptor
- MIDI vs. I2C at a level shifter
- can I use pins A4+A5 for I2C with Audio lib running
- Teensy 3.2 as USB Sound Card
- First Teensy Project: Algorithmic ASS [Attention Seeking Sequencer]
- Drum pad
- Contributions audiolibrary
- FIR taps and use of CMSIS arm_fir_q15
- Midi Send Note - Error spotting!?
- Ping Pong Delay
- Comb Filter
- Just noise with Teensy 3.6 and Audio Adaptor Board
- Midi Send Note - Displaying Scale Names on LC-Display
- Need help choosing an amp for 3.6
- [ASK] Compute THD and SNR thru teensy 3.2 board only
- file.seek(pos)
- file.seek(pos)
- Virtual Midi Cables - 8 ports OSX and PC
- USB Audio in not working?
- Configuring Teensy 3.2 as USB MIDI + Serial device without Arduino IDE
- My audio.h fork - Tape delay, FM waveform input, granular effect and more
- Loud white noise on the edge of filter
- clicking noise interference (at higher frequencies) on SPDIF output T3.2 or T3.5
- Update - Audio Vector Network Analyzer
- Audio Adapter ADC Square wave with no input
- Issues reading audio queue
- MIDI Note sequence (Newbie help)
- Audio Amp Suggestions?
- Teensy 3.5 & Adafruit Max98357 I2S audio amp
- Teensy Audio Shield Serial Ram - chip compatibility question
- USB Audio speakers not working on the audio adapter
- Package outline for 23LC1024 for the Audio Board?
- SGTL5000 signal routing
- Parallel OLED LD7222 with Teensy 3.2/3.6
- Audio + RA8875 - SPI?
- Audio Library for Linear Timecode (LTC)?
- Dynamic Object instances--Dynamic Rewiring
- Audio Adapter board input only & Octo2811
- Teensy 3.6 - Using both Audio ADC and analogRead - works for me!
- Teensy and FastLED - in a Tuba
- Teensy Microphone Module
- Noise and teensy board
- How did I fry an Audio Shield Board?
- USB / MIDI controlled synth, via MaxMSP
- Audio board components matching with schematic V2
- I2S IN 16bit, 16KHz in Teensy 3.2
- Volume/Loudness/Amplitude - which to use
- I2S sampling rate
- MIDI notes to trigger Audio Board synth?
- Does anyone have a Teensy Guitar Pedal board?
- Modifying voice spectrum and outputting
- Band limited Sawtooth wavetable C++ generator for "Arbitrary Waveform" (and its use)
- Audio lib for non real-time processing?
- 8 bit Frequency Shift Keying Teensy 3.6
- MP3/OGG encoding
- Fried Audio Board?
- Audio tool
- Multiple Phase Shifted Mono-Outputs (8+) Possible?
- Audio Sample Rate: how to change from 44100 Hz (44117.65 Hz) to 48000?
- Audio shield and accelstepper
- Where to find what I2C address used.
- Audio board and LED pin 13
- Phase Shift of Pass Through Signal
- Filter for on-board Teensy 3.6 DACs
- Simple Wav Player
- project planning for teensy 3.6 audio convolution
- Help with Teensy 3.2 + Audio Shield
- Audio Library and 4096 point FFT on Teensy 3.6
- I2S Input Question
- Using FLASH NOR chip instead of micro SD card.
