View Full Version : Audio Projects
Pages :
1
2
3]
4
5
6
7
8
9
- Voltage output from AP7313
- Audio Board Fry Check
- Project "Seenthysizer"
- Node Red / Audio System Design Tool Modification
- USB tone?
- Audio Board 101
- Modifications for smooth audio playback with Arduino-Teensy-Codec-lib
- Really Simple Project Not Working
- I think this I2S idea should work, assistance please
- BPM detection
- 16 Bit Line Out
- Real-Time (Working) Vocoder
- Instructions or tutorials for using wav2sketch?
- Help with audio board schematic
- Assigning FFT Frequency Bins to LEDs
- Glitches when pushing buttons on my synth
- Audio Library Object for Weaver (Third Method) SSB Modulation/Demodulation
- noise in DAC aoutput on Teensy 3.2 using sine sample code
- wiring question / configure connections
- analogRead() Interrupts with audio library
- Stuck in a ground loop?
- Multichannel Codec?
- Audio Shield - Analog Inputs - Are these two functionally equivalent?
- Wireless mic: technologies for streaming realtime low or medium quality voice audio
- Teensy 3.6 with Electret Microphone (MAX914) with auto gain
- RF24 audio streaming
- MEMS i2c microphone SPH0645LM4H with teensy audio library
- Sub-Millisecond Delay
- David's MOS6581 SID network player (Teensy 3.2)
- Please Help with my MonoSynth emulation...
- Problem encountered with "AudioEffectDelay"
- Anyone successfully fading Neopixels while audio plays?
- Adressing multiple sine oscilators in for loop for additive synthesis
- Electret Microphone (MAX9814) gives values in range of 30-40 with teensy 3.6
- more flanger effect
- audio board and +4db connection
- Prop shield 3.6
- New Audio Board! TI TLV320AIC3206
- Teeny Guitar Audio Board
- ADCS object and T3.6
- Latency and the SGTL500, is there any?
- Connecting a piezo sensor to audio board
- Question on ADC1 FFT
- Monophonic Keys, Portamento and LFO Pitch Modulation
- AudioControlSGTL5000 problem
- Place cue points (markers) on .wav file
- BPSK demodulation
- Mozzi & PJRC Audio Adapter
- exit status 1 Erreur de compilation pour la carte NodeMCU 1.0 (ESP-12E Module)
- FFT on arbitrary data source
- FFT and floating point data
- I2S - PCM Format
- Teensy 3.5 ADC sampling frequency
- Clicking Sound when increasing volume from zero using IR distance sensor 4 Vol Cntrl
- Multi-threaing with Teensy3.6?
- Is 256kb/s a good rate for audio processing?
- ** HOW TO**Audio lib tutorial without using an audio shield
- Audioboards Die Running Quad Channel Example
- Timed recorder
- Buttons not responding in audio tutorial mash-up
- Controlling Audio library with Accelerometer.
- encrypt audio ---->decrypt audio
- Strange audio stuttering when using delay
- Clicks when setting FIR filters coefficients...
- Does Teensy 3.2 Have Two SPI Modules?
- Feedback Suppression in Teensy?
- ADC conversion time
- Issue - FFT Sample Program Returning 0's
- How to change midi notes using buttons (usb midi)?
- Question about reverb tails
- Generating a 25KHz Sine wave
- Teensyduino Multi Channel Audio Input
- Terminate an active Audio Object?
- Prop Shield and Tennsy 3.2 : no sound at all...
- Recording and reproducting audio in realtime
- Synth not capturing all key presses
- Audio Adapter humming
- Use Teensy 3.6's SD Card
- Change block size and sample rate of USB Audio
- Audio Mixer: Input Channel(s)
- Sampler/Granular Synth Project Idea
- Increase sine effect of Flanger
- Not all WAV Files are Created Equal
- Problem with Teensy 3.2 + Audio Adaptor
- I2S audio chain with multiple teensy
- W25Q128FV footprint
- Dynamic Mic capsule to Teensy 3.5 ADC (A2)
- Teensy 3.2 with Prop Shield lightsaber SFX
- Teensy 3.2 + Audio Board + MEMS Mic - Lots of noise but only when recording
- SPI DAC for audio library
- Adding files to Audio Library
- Audio Library T3.2 Frequency
- Audio Board + rotary encoder issue?
- Limiting white or pink noise frequency
- Read SD card on Audio Board over USB
- Crosstalk issue?
- Audio adapter stream to USB --> receive in MAX 7 with ASIO4ALL
- Crosspoint Mixer
- Audio Board + MCP23017
- Noisy output
- Gate
- Help: Playing wav from teensy 3.6 built-in SD while still using audio shield
- T3.1 + Audio Board, corrupted sound, possibly soldering issues
- Teensy 3.6 + Propshield to play MP3
- Monophonic Guitar Synthesizer with subtractive synthesis
- Multiple WAV playback problems
- FFT/Convolution object for Teensy Audio library (guitar cabinet simulation )
- TDM: how to use all the 16 available channels
- powering 8 ohm 2W speaker with teensy audio
- Making sense of FFT data
- Connecting to external board for additional memory
- AKM4558 support in library?
- convert midi note to note name
- Low volume with autoVolumeControl in Teensy SDR
- Playing WAV file from SD
- Audio library Play/Pause
- Teensy 3.6 and MEMS mic ICS-43432
- Line In Audio on Teensy Audio Adapter
- Teensy 3.2 Pin Questions
- Are there any WAV manipulation tools in-sketch available?
- How to Make Wavetables
- Teensy based multistage distortion modeling pedal
- Noises while feeding analog circuit (pre-amp) from the teensy 3.3v and GND.
- Biquad setLowShelf / setHighShelf methods not accessable from Audio library
- Anti Alias filters on SGTL5000
- Wierd problem with analogRead(26,27,28) when using audio library
- Need Help coding motion detection with prop shield
- The resistance is not enough when I try to pan an audio signal between 2 speakers
- triggering audio files with button from SD card
- Quad audio output
- Open Source DSP Audio Processor for FT-817
- Filter with Envelope - how to continuously modulate?
- APA102 + PropShield = no Audio
- Teensy 3.6 + SPW2430
- Loud pop on Teensy reboot from Audio Line Out
- Getting integer value from AudioSynthWaveformDc? Alternatives?
- Strange behavior in controlling SGTL5000
- Wire Line-In and Microphone to Same Jack?
- Bass Enhance in Teensy Audio
- "Screaming" low pass filter / Clipping issue?
- ADC input gain
- DAC Broken ?
- Variable delay triggering T3.2 audio output by T3.6 controller
- strong noises while adding patchcords to fft256 objects
- USB-Audio
- Audio resampling
- Would slowing down the I2C bus cause any issues with the Audio Adaptor board?
- Noise on ADC A1 input with audio board connected (Teensy 3.2)
- analyze_fft1024, duffs optimization
- Spectrum analyzer; low/high fft.read() bins triggering at wrong frequencies
- sd card data flow
- port manipulation instead of dac output while reading from sd
- audio delay?
- Connecting a piezo to 3.2.
- Using the SGTL5000 Audio Processor
- Overclocked Teensy 3.6 + Audio Adaptor + APA102?
- Audio board and I2C-t3 library
- audio library wakes up teensy from hibernate
- Teensy Audio Tutorial, need some help.
- Q31 in analyze_fft1024
- Problems with AudioEffectDelay Teensy3.2 vs Teensy3.6
- Audio Board line out question.
- Sketch for triggering .wav with buttons.
- Audio Library not working?
- HC-SR04 & Audioshield
- Real-time Audio Detection - Teensy 3.6
- Use touchread pins on audio shield teensy 3.2
- OctoWS2811 use pins 14,20,21 as analoge input
- Two GUI related bugs
- Feedback on audio output circuit?
- Playing two .RAW files at once
- what's the best ground pin on the Teensy to return the DAC signals to?
- How to put the SGTL5000 into a low power state?
- Using i2c_t3.h instead of wire.h for audio examples?
- Teensy 3.6 TDM mode support for ad1938 codec
- PT8211 Audio Kit Playback Distortion
- Disabling Audio Passthrough - Teensy 3.6
- Newbie audio amplitude modulation
- autoVolumeControl and hardLimit
- Audio Adapter Not Working
- SPDIF Input and Output
- How to Audio Library?
- How to Pitch Shift?
- Piezoelectric Vibrations
- Error: 'release' cannot be used as a function
- Sinewave efficiency and quality
- Teensy 3.6 with Audio Board - audio out is clipping
- MIDI Synth Shield for the Teensy
- SD Card Test
- A Question about Peak
- Question about Hardware SPI with Audio Board
- Change Audio Device Configuration
- Audio Tool PT8211 Oscillator stability
- AudioSynthWaveform to emulate DC
- Teensy 3.6 + prop shield playing WAV files
- help a noob out
- Recursive delay
- resonant bypass filter
- fft1024 with smaller delta-F bins (decimate? run ADC slower?)
- Design filter coefficients of FIR and Biquad
- T3.2 with FFT improves performance of cheap doppler radar
- Problem changing AudioMixer4 gain in library
- Audio Adaptor Board - pcb audio connector
- Teensy 3.2 Quad Channel Input
- Problem with sending audio data over ethernet
- DC Offset Removal in input_adc.cpp, input_adcs.cpp
- Pinouts for Connecting Alternate LCD to the Teensy Audio Board?
- Floating Point Biquad
- Audio I2S Input not working
- Working Audio output queue example
- Usb output to a speaker
- Help needed with audio in circuit
- Selecting reference voltage for built-in ADC with Audio Library
- 4 channel mono output?
- Polyphony problem in a synth project using Teensy 3.6
- Teensy 3.6 mic > FreqMeasure
- AudioAnalyzeRMS problem
- Source separation on a microphone recording and a know generated signal
- Memory Chip for Audio Adaptor Board ?
- Broken 0.1 uF capacitor - could the Audio Adaptor Board work without it?
- Mono USB Audio
- Audio Library with sparkfun SD breakout
- Audio tool help needed
- Audio Board Line In Noise
- Yet another SimpleAudioLogger
- Audio library Sample Player retriggering on plugin power
- Using Audio board without Teensy with Linux
- Opus codec library
- Teensy 3.6 and SPDIF Coaxial
- Wave-File Header (recording)
- Software Phase Lock loops
- Audio and Ethernet
- Processor Selection for Audio Analysis
- Measuring microphone amplitude
- Audio project and T3.6.. a lot of problems!
- Teensy 3.6 + Audio Board USB streaming interruption
- dacs output don't play on Teensy3.5
- Feedback FM
- MAD - Modular Audio Devices
- Using received audio information and play this
- An Audio Phase-Locked-Loop (PLL) Block
- Teensy Audio Library create melody
- Hexaphonic (6 discrete channels) passive guitar pickup for pitch detection
- Code is freezing after playing a sample from SD card
- Two audio mono ouputs
- Teensy 3.2, Teensy Audio shield and APA102 LED Strip
- Audio Buzz Project board
- Accurate Digital PPM Meter possible with Teensy 3.2?
- Is this flash memory chip compatible?
- Audio Hacker to Teensy 3.2
