- Lightsaber sound from a computer sound card
- No audio output Teensy 3.2 using either onboard DAC or USB passthrough
- Finding I2S Pins on Pinout Diagram
- Sustituting arm_rfft_q15() into the Audio Library FFT functions?
- Audio Memory Not Declared in Tutorial
- Tie Teensy AGND to Audio Amplifier AGND?
- No sound when SD soundfiles are playing (synthesis is ok)
- With Teensy 3.2 w/ Quad Audio (2 Shields) can you select which SD card slot?
- use oled display conected with teensy 3.6 and audioshield
- Dual Audio Adaptor Boards with 23LC1024 RAM chips
- Anyone Doing Pitch Shifting?
- AudioAnalyzeFFT256 does not work like FFT1024 ? (works only once)
- Developing Teensy Audio effects as plugins
- Glitches When Sampling Quad Audio
- Help with volume control
- Any way to sync amplitude changes to zero crossings in the sine generator?
- Disable Audio lib
- Synchronizing Effects
- Cannot use Teensy as I2C slave when sgtl audio is enabled
- usbMIDI.read() and external USB Keyboard Not Playing Well Together
- Using delay with microphone input does not work
- I2S Microphone (SPH0645LM4H-B)
- Audio Board and stereo recording
- hang when trying to play raw files from SPIflash
- 4 channels input and output, 24bits USB soundcard
- Sound leak left to right speaker with teensy 3.2 + Audio shield
- Adding a gain to the AudioInputAnalog signal
- Distort Voice to Something Scary for Halloween?
- Teensy Audio Shield Volume control Headphone vs Line out
- Audio plus FastLED/DOTSTAR not working
- Wav file play from SD card (Audio shield) conflicts with Other SPI device(DWM1000)
- Audio and PWM motor control at the same time
- Save file to SD in a different thread (or use interrupts for sampling?)?
- Standalone Answering Machines
- Problem with encoder library and the audio shield
- Teensy USB audio not working
- How to avoid clipping with the filter "AudioFilterStateVariable"
- Adding 23A1024 RAM chip to audio board for "Reverb" effect?
- Problem - Wav audio file plays a little bit faster than it must
- Help for implementing bandlimited waveforms
- Balanced output from audio shield
- USB Audio recording interrupted after 18-22 seconds
- Extending the Audio library: moog filter, fm waveform and DC with multisegment env.
- I2S sound recording from Teensy Audio Board using I2S.h library
- simple headphone add on board?
- Buchla LPG like module
- distorted audio with teensy3.x as usb audio interface connected to an raspberry pi
- Flange Example Sketch extremely noisy(static)?
- How can I include the SdFat that came with Audio.h (not the default one)
- Crossfade and loop
- Will Teensy 3.2 suffice for my project?
- SD Card WAV Files Analyze
- Mono Channel with I2S
- Arbitrary Waveform Array Size
- Teensy 3.6 DAC0/1 to Audio Board Headphone amp
- Audio Record using AGC Microphone
- Implementing a basic EQ
- Karplus-Strong with continuous input?
- custom audio objects document ambiguity and more info
- Teensy 3.6 MIDI keyboard with knobs and buttons latency issue
- No Audio Library
- audio file continuous loop
- Teensy 3.2 ADC audio input with 11 analog reads - Possible?
- recording in stereo from mics
- Audio board is making strange sounds!
- Questions to Sampler Project
- Inverting Audio Channels in the Teensy audio boards
- Analog To Midi (voice To Midi)
- Auto Equalizer
- C1 Chameleon Project
- Teensy 3.5 + Codec used as a SDR based Ham Radio Transceiver
- Using Teensy with Audio Adapter as audio interface for a Pi Zero
- Multichannel (8-24) audio player for installations and performance
- Graphic EQ parameters
- recording audio with i2s microphone, teensy 3.6, audio shield or no audio shield
- Audio board alternative connection
- audio board with anything *other* than teensy 3.x?
- Force integer-sample periods for "clean" audio test signals
- Teens 3.6 + Audio Adaptor + nRF24L01 + Multiple SPI
- Contact microphone pinMode problem
- Dynamically Change Chorus and Flange Sample Lengths?
- PropShield LC
- Multiple AudioInputAnalog Question
- Draw Waveform on display
- Using teensy audio library natively on linux
- Recording samples to prop shield flash memory
- Stereo fx, code suggestion
- Teensy LC to play WAV files through Prop Shield LC? I'm guessing No.
- Use Peak for non realtime analisys
- Hardware connections to headphone jack
- Update create date on SD card file
- Encoding multiple lower sampling rate audio signals in 44100 (over usb audio)
- How can I recreate a specific 'clacking' sound with the Audio Design Tool?
- Audio library doesn't play nice with SPI/SdFat.h ?
- Erratic static in playback
- Record what you Play (Recording the output)
- waveform.phase() error for some waveforms
- How to add a "freeze" function to Reverb effect?
- Including any file in Audio library causes entire Audio library to be included
- Teensy as outboard effects processor
- Maping sensor data for deeper audio processing resolution
- can't make audio work on my teensy 3.6+audio board
- Connecting Teensy USB Midi device to other device with Type B connector
- AUDIO_INPUT_LINEIN Issues
- Empty Module for User defined Audio Modules
- Cheap ICS-52000 Microphone Array Board for TDM evaluation
- Howto Filter with low steepness?
- Guitar Tube Amp Simulation Setup
- change pitch and decay sample WAV
- Possible to do delay longer than 425 ms with teensy 3.5?
- Reading SD card stopped working!
- lfo cutoff
- Makes Idea of differential input sense?
- I2S audio board (24bit/96Khz)- Working with 'generic' I2S ADC breakout?
- Starting Audio FFT from interrupt
- making Mozzi work with Teensy Audio Adaptor (SGTL5000)
- Sound for model railroading scale 1/32
- Soldering audio board to Teensy 3.6
- AK4556 codec library?
- More than one USB input?
- ADAT Multichannel In / Out?
- Touchscreen MIDI Controller
- Memoryboard 4
- Converter WAV-File to Hex-File in Javascript
- No usb audio from Teensy 3.2 to Mac
- ICS43434 I2S Digital Microphone and Teensy 3.2
- I2S input - Analog output - Note frequency analyzer
- How to stop analyzing notefrequency
- Audio Input Recording to SD Card
- Play MONO through both channels possible?
- USB Soundcard with additional control (Audio and Serial simultaneously?)
- Issue with analog.c
- Playing audio files randomly from a button
- Problem with new Teensy 3.5 DAC output
- High-Speed ADC Logger with Audio Library
- CS4272 issues
- 6 inputs audio recorder with CS42448 audio card from OSH Park
- Can't get signal into AudioInputAnalog on teensy3.0
- Convert -1/+1 stream before block transmit
- Transport Controls
- Multiple USB Audio/Serial Naming
- Choice-based audio narrative?
- Fade without clicks
- Teensy 3.2 not reading in audio correctly
- Raspberry Pi Audio Hats with Teensy 3
- Audio Board won't play any sound
- question about Teensy synthesis
- Teensy 3.5 Basic Gain using inbuilt ADC and DAC and MAX9814 mic
- Varying amplitude
- playFlashRaw not working correctly?
- Playing audio from SD whilst main loop is accessing different file on SD
- Tinsy 3.6 and Audio shield
- Audio library equivalent to pygame.event.pump?
- AudioEffectDelayExternal and ILI9341 display not compatable
- Teensy 3.2 for 747kHz AM radio
- Short Delay when looping SD RAW audio
- Sample Recorder / Sequencer
- Can the audio board be used along with an I2C sensor?
- Monitoring voice while recording it
- Two Teensy 3.6 to work together
- Temporarily selectively disable mixer inputs?
- Audio source from pc or smartphone to the SGTL5000?
- Change waveform of Sine Fm
- Switch from Teensyduino 1.36 to 1.41 causing issues
- Spikes in Audio
- Realtime EQ + Reverb
- Line in protection SGTL5000 ESD / EMI causing SGTL5000 to stop
- Choppy WAV audio recording
- ANOTHER Teensy Audio Board Synth
- 16k (and other) low sampling rates with T3.6
- Audio Transmission using Teensy+ Audio Shield+ NRF24L01
- Teensy C- SDR
- code to restart SD card if lost mechanical contact temporarily?
- galvanic isolation for audio output?
- Strobe FFT
- Teensy 3.5/3.6 and simple headphone hookup
- piezo velocity
- Looping a sound in memory
- dac in on propshield with teensy 3.2
- Teensy Voice Changer?
- Voice Transmission using Teensy+ Audio Shield+ NRF24L01
- Is it possible to use the Audio library with low power modes ?
- Teensy 3.2 (with audio shield) PlaySDWav > Notefreq issues
- New audio effect: AudioEffectAnalogDelay
- Free MIDI Controller application to use with Teensy
- Recording Mic and line-in into the SD card with audio shield
- Connecting nothing but a normal line out to the Audio Adaptor Board
- Teensy 3.2 Sketch read error
- audio library and encoder
- Play audio with midi clock
- Teensy 3.6 no audio using DAC
- Is it possible to read two different notefreq items at the same time?
- Wav sound player with SPI memory chip
- Translating sound into movement, using FFT
- Play a wave file --> Connected Headphones --> No Sound
- Small size AudioBorad
- Is there any chance to get longer enveloppe in the next teensyduino version :) ?
- Enable / Disable audio objects programmatically
- Power Supply for Teensy 3.6
- Midi --> Receive Notes --> Play Polyphone samples
- Pitch changing for audio playback application
- Filtering VGND DC
- Waveform Object Problem with Midi Input
- AudioRecordQueue limited to 53 blocks? Why 53?
- Noise on teensy 3.2 with audio adapter when using digitalRead
- Find "unplaying" playSdWav-Object or create playSdWav Object on the fly
- Teensy 3.2 Quad Channel Input - Pad 30 came off
- Weird pitch quirk I noticed with arbitraryWaveform
- Waveform Average value
- Working on a BPM detector - am I stepping on anyone's toes?
- Why MEMS i2s microphone ICS-43432 with teensy audio library not working?
- preparing audio with wav2sketch getting error message in terminal
- When playing multiple wav files it have distortion when overlapping files! teensy 3.6
- Sandisk alternative for multi-file playback?
- Wireless audio transmission to teensy
- Required file format for unsing playSDRaw
- Advanced Midi Sampling
- Are 2 1024 FFT too much for the audio sheild?
- SGTL5000 for DC control voltage output
- Audio Board Problems: intermittent pauses
- Scaling USB audio for analog output
- Paul: suggestion for audio library
- Audio shield inverts the input?
- Teensy as I2S Slave-- frame size question.
- CS42448 Audio Board BOM Replacements
- Can't get Audio Shield to work
- Timing accuracy using Audio library
- Syntax for AudioEffectFade
- Making progress with my DSLR mic monitor Basic filter question
- TDA1308 headphone pre-amp from DAC
- Audio waveforms not outputting
- Change head phone jack to stereo mic on SGTL5000 audio boards?
- AudioSynthWaveformModulated not working. (err: does not name a type)
- Connecting DAC directly to powered speakers. Result?
- Delay: Longer timing? And crunchy sound in feedback loop?
- PassThroughUSB with queues
- PCB with Audio Adapter
- Multichannel audio input object with 1 ADC, keep the other ADC for slow analogRead()
- Data access light on a teensy lc?
- FFT decreasing BW modifiying sampling frecuency?
- Fried Audioboard
- Arbitrary waveform object issue
- Start using AudioPlaySerialflashRaw
- Midi into DAW
- sample and hold
- Using Audio and the new Wire library causes duplicate symbol linker errors
- AudioInputI2Sslave to SGTL5000 analog output?
- write to AudioMemory
- Sgtl5000 I2S_DIN/I2S_DOUT
- My mic input into the audio shield is super distorted/hot
