View Full Version : Audio Projects
Pages :
1
2
3
4
5]
6
7
8
9
- Calculate Filter coeeficients dynamicaly
- Connecting Audio board to Li Po battery charger
- Reensy Raw player with buttons: No sound - no errors
- Using signal processing features in the SGTL5000
- Audio amplifier object library
- Waveform Modulation Speed?
- not recording
- No sound - no compiling errors - help
- A DX7 (Fm synthesis) replacement with Dexed on a Teensy
- Bits of audio missing from recordings.
- Question regarding FFT bins
- Audio Recording / Logging to SD card --> microSoundRecorder
- Testing if DAC pins are working
- Audio Output Without the Audio Shield, Teensy 3.5 Arduino
- Teensy 3.6 for 2 channel FFT processing. Use one or two
- what is Teensy Wave Machine?
- LMS for ANC with teensy audio board
- Teensy3.2 + Nand Flash
- Teensy based Lexicon Prime Time 93 style delay
- Teensy 3.6 and audio board
- Teensy LC +Prop Shield LC + AudioZero
- audio band Sample and Hold
- Can't play more than one audio file simultaneously
- Audio board recording while playing - sampling frequency problem
- Audio Board Summing Junction
- Teensy Audio Tool WaveformMod
- Custom FFT Bins for FFT1024?
- 24 bit audio using ICS-4342
- audio board and byte manipulation
- WavFileWriter
- fft analysis with microphone electret + amplification
- Teensy Audio Tool I2S Inputs and Outputs
- Online version of wav2sketch utility - need testers please!
- A few questions regarding FFTs and performance
- Breakout board for the microSoundRecorder including environmental logging
- Teensy 3.2 no audio out on dac pin
- Audio Adaptor Board and WAV Trigger / shared SD Card / polyphonic sampler
- How to set different voltage references for ADC0 and ADC1?
- AudioPlaySdWav delay
- Combining multiple audio sources?
- Custom Audio Source
- Audio Library AudioInputAnalog conflict with ADC library?
- Overclocking SGTL5000
- PlayFlashRaw Low quality sound (Prop shield)
- Simple 3 button foot pedal
- scale model making with teensy -- This is a kickstarter project --
- Renaming a recorded WAV file on SD card: Teensy 3.6 + Audio board
- Audible clicks when switching waveforms
- Cannot get Teensy 3.2 with Audio Shield to play my .wav files from SD
- Controlling Teensy Audio Shield with USB MIDI
- 4 channel audio (quad) with sd card
- Feedback ANC System
- The sound of a motor humming on a teensy 3.2
- Playing Sounds kind of simultaneously
- Batdetector: Time expansion (slow down replay) using granular-effect
- playsdwav, play from the specific time of the file.
- Audio files corrupt after some time !
- Teensy with PCM5102a Module via I2S
- WaveformMod Documentation
- Memory Spikes and Playback Stutters
- Right-justified I2S?
- 5 pin Midi key presses cause click on DAC output (Teensy 3.2)
- New classes: ParameterAutomation and AudioEffectSOS
- Do tone.threshold(level) and tone.available() work?
- Using USB Audio Input Module
- Receive MIDI alongside internal Sequencer for Teensy drone synthesizer
- 16 audio outs?
- Compiling Audio library
- Button Matrix is causing issues
- Efficient way to enable/disable filters
- Slowing down the PDB
- Audio Expander for Teensy
- Teensy Board suddenly stopped responding
- Physical Modeling a wind instrument
- Audio library & Stepper motor library + bounce compatibility
- Audio USB Out "hello world" program
- Custom FFT Frequency Range
- AudioInputUSB - AudioAnalyzePeak
- Calculation of FIR coefficients
- CS42448 TDM Input
- AudioPlugs, library for switching audio streams
- Teensy 3.6 ADC use breaks Analogread
- 4 Channel TDM (I2S) Teensy 3.6 with Invensense ics 52000
- Strange error when reconnecting Teensy (audio board not working on reboot)
- Line-in noise when using an LED library
- Issues with Placing Commands in a Loop Running a Waveform
- AudioOutputUSB does not name a type, on OSX, Arduino 1.8.5 and TeensyDuino 1.42
- Turning Freeverb On/Off?
- Audio Library and 8k Sampling Frequency.
- I2S slave mode issue : all the stereo data goes through the left channel
- Incorrect/lossy audio sample values from PC to Teensy?
- Audio Library & using pin A8/A9 crashes Teensy
- Biquad-filter low corner frequency test-sketch
- Lowpass-RC-filter for MicIn: Code or resistor and capacitor?
- "AudioSynthWavetable" project, HELP
- 4 Channel Input/Output
- Is there any hope to use DAC PT8211 with teensy LC ?
- GeneralMidiSynth, help!
- arbitrary waveform funny signal squarewave unipolar to bipolar
- How can I change the volume from DAC0 pin while playing a file?
- FM demodulation
- Using Teensy Audio Library with SPI DAC (e.g. MCP4922)
- capacitorss for adc dac ?
- Teensy-based modular synth system
- Teensy in Raspberry I2S based digital chain.
- Anyone want to collaborate on a Teensy audio effects "thingy"?
- SGTL5000 compared to PT8211
- random WAV player
- Baxandall Tone control
- Spectrum Analyzer Noise with Frequency Sweep
- First Order Filters
- Grounding issue?
- Inner workings of the audio library
- wm8731+teensy schematics?
- Teensy Wavetable Synthesis example
- Issue with line in from android headset accessory
- Help - Noise caused by TRACO 5V?
- Good way to make a teensy based electric piano
- Library: AudioTiming
- Compatibility between Wavetable-Synthesis and teensy audio library
- Audio board automatic volume
- Audio input Audio board
- Problems with the Audio Shield.Is it broken?
- New convenience class for physical audio controls
- Lowering electromagnetic noise for audio recording via microphone and cable
- iOS / usb woes
- AudioProcessorUsage()???
- Memory usage on teensy 3.6 [replacing AudioSynthWavetable::instrument_data in memory]
- Pausing/Seeking audio
- Audio Streaming from Memory
- Dry/wet effect
- audio to pwm to led
- play_sd_wav library code questions
- Vader voice changer
- replacing W25Q128FV with smaller W25Q32FV OR MX25L1606E ?
- Ultrasound Chirp Problem
- How to use cpp code as a "black box" with the Audio System Design Tool?
- Got audio compressor code running. Now how do I debug the levels?
- connecting audio shield headphone output to my amp?
- [?] Some hints on choosing a quad audio codec and an OLED
- Inverting analogRead floats
- DIY Synth, question 1 of 10000.
- Using APA102 Midi controlled LEDs with Teensy
- Prop shield audio connector
- forcing the correct SD.h to be used? better wav playing capability?
- SGTL5000 Hiss?
- Generating a sine wave and altering amplitude within an IntervalTimer
- What does signed_saturate_rshift(val, 16, 0); do?
- TeensyTransfer Cannot open audio files
- Simpler way to compute sqrt(ch0^2+ch1^2)? My code example seems way to messy.
- Distorted waveform, please help!
- Multiple Teensys, Distorted Audio
- Hydrophone for Teensy
- Teensy 3.2 w/ Uncanny Eyes and use Internal DAC for Audio?
- 3.6 - Cannot use more than one AudioInputAnalog
- simple sound play while pause NeoPixel
- Why is the audio library block instead of sample based
- Creating a Library-Object
- Audio from AudioInputI2S works but data from AudioFilterBiquad does not work
- [?] CS4270 and Teensy 3.6... Maybe it is too much as first experiment
- USB Audio Clicking Noise
- Headphone Jack question
- Audio play single in memory WAV - fails
- Audio from wav file on SD card experiencing high distortion
- WateTable and labriry compress array
- Is there any short of incompatibility between audioshield and XPT2046_Touchscreen???
- Synth envelopes not updating?
- usbMIDI.sendControlChange() breaking DAW
- 7KHz High Pass filter
- Simple Drum Example improvement (maybe)
- Converting analog input
- Why is there no audio thru from mic -> usb in this simple sketch? (whitenoise works)
- Teensy 3.2 - I2s object - CS4334 DAC - Aliasing
- quad problems with 2 audio shields and teensy 3.2
- Problem with mp3 library
- Monitoring currently recorded audio
- Breath Control and Smoothing
- Teensy 3.6 USB Audio Interface
- 3.6 MIDI Host via micro-USB?
- buffer store
- Teensy 3.6 Interference between Fast Sampling and SD Logging
- Waveform.begin no longer resets the wave?
- Possible to change duty of an WAVEFORM_ARBITRARY ?
- Combining MIDI and USB Audio on one board
- FM synthesis - 808 drumkit
- Need Help with 4051 Mux and Audio Library
- AudioShield and built-in LED
- Poll
- Amplitude latency?
- Quick and Dirty, Real-Time BPM Detection
- potentiometer troubles
- Analog in speed
- How to pass a String variable into AudioPlaySerialflashRaw::play() ??
- Advice for low latency audio
- Portamento / Slew ?
- Deriving New Class from Existing Audio Class
- Teensy audio not working with external power
- The way to enable SPH0645LM4H with Teensy 3.2
- Avoiding the delay(), RAW or re-use the WAV header?
- SD card problems going through Audio Tutorial
- Playing very short Sounds gapless
- how to mate the audio card to teensy 3.6
- Envelope Array Problems
- Help with List of Teensy Eurorack modules
- Can the SD Card play WAV sounds into a mixer block for layered/overlapping sounds?
- Teensy audio library
- DC Coupled CS42448 osh park board
- Fisrt attempt to pause SdPlay ; AudioLib update
- Teensy 3.6, Audio Shield and the use of pins
- Sound clips to be sent to one of three devices?
- How to synthesize a chord or multiple notes at the same time.
- Sound Reactivity Question
- Changing ADC Reference Voltage for Audio Library
- Audio and Steppermoter at the same time
- Audio board or no Audio board?
- Faint high pitch noise when using Audio Board & USB
- Question about AudioPlaySdRaw and interrupts
- Disable Effects at runtime or Add Remove Patch Cables
- How to use Audio Shield SPI and off board SPI
- polyphonic code example
- AudioPlaySdRaw samples seem to play at (approx) half speed
- Effects routing
- Audio stops working when repeatedly creating/disconnecting AudioConnections
- polyphonic pitch and/or volume changing
- New audio effect: TREMOLO
- buffer to mixer
- I think the audio shield would help with my distortion (demo video)
- Adafruit Trellis and Teensy 3.2 with Audio Shield - communication problem
- Create Custom Objects in Audio System Design Tool?
- Multiple CS42448
- TeensyMIDIAudio PCB and MicroDexed/MicroMDAEPiano: Synths based on the Teensy
- midi input and midi output at the same time ?
- SD card audio library to scan SD card for valid files and make a list?
- Can I detect incoming sound on Line In, Audio Shield?
- How to use TDM Microphone Array Demo Board
- How many cycles should I use for a specific frequency?
- Is adjustable pulse width possible using modulated waveforms?
- Song identification from PC into the line-in jack
- Frustrating issues with SD card not working: Unable to find partition
- How many wavetable synths?
- Midi
- Get audio out from a MIDI controller when it is not hooked to a computer?
- Distorted sound and no peak level on TFT while trying tutorial Part_3_03_TFT_Display
- Audio Tutorial - Getting started
- Audio board line I/O connections
- Audio board lo-fi options
- Audio shield for mallet controller
- Audio library with a digital I2C accelerometer
- AudioPlaySerialflashRaw and Multiple Flash Chips
