View Full Version : Audio Projects
Pages :
1
2
3
4
5
6
7
8]
9
- USE_TEENSY3_OPTIMIZED_CODE distorts SD playback
- TeensyUserInterface w/ Audio design tool
- Teensy 4.0 Synthesizer Project - Crashing Issues
- Monitoring AudioOutputUSB from Teensy 4.0
- Audioboard (CS42448) running 24 bit
- biquad filters - how to ?
- Drum elements in an array - Dynamic variable type confusion
- Drums with delay does not work.
- Teensy 4 PCM5242 Audio Shield - Stereo Balanced/Single Ended DAC Module
- Pitch shift vocoder/voice changer using teensy 4.0 and audio shield/prop shield?
- Optimizing Teensy for Polyphony
- Audio lib not functioning properly on Teensy 3.2
- Teensy 4.0, I2S, AudioPlayQueue, Timer interrupts & more
- QUAD SPI while using Audio Shield?
- Teensy 4.0 Audio Toolkit and Shield - An Open Source Audio IO Project in Kicad
- I can't get the envelope to work
- Teensy 4 + audio board guitar pedal
- WAV track randomly fails to load, locks up Teensy
- Logarithmic / More Natural Fade with Release
- teensy 4.0 - 16 channels TDM output
- Can't get FFT1024 to work with Teensy 4.0 and SPH0645 I2S Mic
- [q] Audio Library Play wav form SD card and write log simultaneously
- Please test this example on Teensy 3.6 for me
- using the eeprom for audio sample memory + Audio Library (playQueue Vs audio object)
- 2 track playback device - seeking elegant/effective solution for transport controls
- Guide/tips for writing custom audio effects for Teensy Audio Library
- Porting moog ladder filters to audio objects?
- Audi Shield - Micro SD Card
- need help with audio latency and noteFreq object
- Teensy 4.0 + Audio Library + Bluefruit LE SPI/BLE MIDI issues
- Simple ranging with Teensy 4. Recurring beeps + FFT trouble
- Help getting sound samples to play from SD card
- 48kHz 8i80 USB Audio
- TDM Out sending data even if inputs not connected
- How to connect S/PDIF coaxial as input to a Teensy 4?
- Brain transplant! De-BOSS-ing a ME-70 with a Teensy 4.0
- AudioPlaySdWav in an object?
- Write from SD Card to RAM
- I2S conflict with touchscreen?
- TDM CLK settings
- Wav playback does not work. Do you see what is wrong in my code?
- Please help
- Audio stops and strong ground hum takes its place with protoboard
- XLR Input on Audio Shield
- Teensy 4.0 PCM1865 Audio Shield - 4 channel ADC with balanced/single ended + preamp
- tlv320aic3206 audio ADC?
- Unable to get DAC working on Teensy 3.6
- Ranging using Teensy 4 + mic and speaker, timing variance issue
- Sharing some work and asking a couple questions
- SD card test, strange results
- Noise from USB Host connector on Teensy 3.6 internal DAC
- Linker Issue with including 2 Faust objects
- DC processors in the GUI
- On AudioPlaySdWav to play drum machine samples
- Polyphase decomposition to channelize audio input. Anyone done this on a Teensy?
- Fresh AudioShield Rev D not working
- phase() Not working
- Help controlling Audio Library parameters with pots, without Audio Shield
- Flash Memory help
- Looking for a CS42448 breakout to buy in the UK
- What Timer is used to derive the 44.1khz clock the audio library runs at?
- AudioDelayEffect() Maximum Delay Time on Teensy 4.0
- Point Triangulation from Sound with high accuracy
- Teensy 4 audio ticking with audio board and Neopixels
- Removing audio tool references to <SD.h> and <SerialFlash.h>
- Vector Math
- Teensy-4.1 and Teensy audio shield (on MicroDexed)
- ADAT white noise on Teensy 4.0
- Audio Board Equivalent for Custom PCB
- Audio Equalizer using FIR
- Low latency FFT to OSC for AV-shows
- Teensy 4: No Blink or sound for Tutorial Part 1 05 'Do More While Playing'
- Playing multiple WAV files at the same time - SD settings
- Pedvide ADC library with 4 microphones
- Teensy 4.0 Quad I2s with 2x PCM5102a - Working!
- SGTL5000 audio board codec on SPI bus
- #define USE_TEENSY3_OPTIMIZED_CODE for playing back multiple samples on T4 - how?
- Audio Board Voltage Regulator?
- How Does Output Object Timing Work?
- External Speaker & Audio Shield Question
- AudioInputAnalog - Change ADC Reference Voltage
- Ethernet Audio library and web server in one project(?)
- Teensy 4 Audio Library with ASIO4ALL for Low-Latency Playback
- Which pin is OUT1A on Teensy 4.1?
- WavFilePlayer Clicks, pops and crunchy noises - solved but WHY?!
- Is there a way to increase the audio lib buffer?
- Problem with audio teensy
- Teensy4 with PCM5100 i2sslave, no sound
- Dropped Frames Using AudioInputUSB Object
- MIDI SYSEX buffer to small (USB-MIDI)
- TOSlink part is obsolete at digikey.com
- Unable to get FFT or SpectrumAnalyzer examples working
- Flash Mem Soldering Help
- Quad channel audio input through USB on T3.6 or T4.1
- Teensy 4.1 and 4-channel audio (AudioInputI2SQuad)
- USB Audio Frame Sync on Teensy 4.0
- teensy audio pc layout
- What actually happens when an audio effect's update function takes too long?
- How Come My Servo Won't Activate? RMS to Servo Map for Animatronics.
- reading S/PDIF data with Teensy 3.6 (or 4) for a beginner
- Pixel (Teensy Pixie) SDR
- Which Pin Headers for Teensy 4.0 and Audio Board rev. D
- Clicking noise When turning amplitude Knob coming from hardware or software ?
- Attempting to send voltage to teenssy board via Arduino.
- Can i use an envelope output in code?
- Issue with wavetable sound
- SGTL5000: Influence setting lineOutLevel() the output signal level?
- Generalized FIR Filter Block
- openaudion_arduinoLibrary not useable on t4 t4.1
- triangle & sawtooth oscillators : how to deal with aliasing ?
- Array handling in the audio tool.
- MI Braids into an audio object
- T 4.1 + MEMORY EXPANSION CHIP for queue object
- using a power in teensy gui.
- Looking for contractor for synth projects
- Best WS2812 Library to use with Audio Library
- Teensy 3.2 SPDIF and I2S
- Can AudioZero Library be modified to play 12bit audio on Teensy LC?
- Documentation Request and a Question
- Connecting Two Teensys via I2S
- Audio Board I2C Voltage Shift?
- Teensy 4.0 + Audio Adapter + WS2818Serial
- Creating custom audio objects with many inputs/outputs.
- CS42448 boot issues
- Connecting TOSLINK/SPDIF signal of a TV to Teensy 3.6 DAC
- Printing Audio Design
- Problem changing AUDIO_BLOCK_SAMPLES
- Mixers and multiple sounds example
- ESP32 with teensy audio Shield/library?
- Mounting issues
- Does anyone have the SGTL5000 filter spreadsheet file?
- Can i modulate the delay time?
- definition of the signed_multiply_32x16t() function
- Simple audio object which acquires an audio block - what's wrong with this code?
- Problems about using multiple audio objects, T4
- Live music performance with 5x Teensy 4.1 & 1x Tsunami
- Questions on documentation and screen choice for Teensy with Dual Audio Adapters?
- Audio Play queue help
- Teensy Synth crackling sound when midi notes trigger
- Difference between MCLK1 and MCLK2
- Using Teensy onboard ADC with audio library
- Question regarding effect of changing sampling rate and block sample size on queues
- Teensy 4 - FFT1024 from audiolib and ILI9341 display not work
- Direct audio samples into Audio Library objects
- Teensy 4.0 I2S connections to TAS2770
- A little FFT demo for 480x320 TFT (HX8357D)
- Glitch when Playing Audio from SD card in Teensy 3.2
- S/PDIF Input to Teensy
- Teensy Organ
- Teensy 4.1 DAC Output
- hydrophone with pre-amp connected to Audio board
- A subharmonic synthesiser and polymetric sequencer with Teensy 4 and audio library
- getting cv/gate in and out into and out of teensy
- connecting a MIDI keyboard to my teensy 4.0
- Teensy Audio + GNURadio
- Phasemodulation changes amplitude
- Teensy Audio Shield Not Detecting Anything from AUDIO_INPUT_LINEIN
- Teensy Audio + Ethernet
- Audio Shield rev D with Teensy 4.1 output is low pass filtered!
- Differences in Timers
- How to achieve linear FM with waveform modulated?
- How to combine a mono and a stereo line inputs
- Latency Teensy 4
- Question about waveform modulated.
- Teensy 4.0, audio shield, and RN52SRC
- Teensy 4.1 - Using the audio shield with other SPI devices
- Non- linear adc dac, and floating point audio library?
- Amplitude Modulation with offset
- zero crossing audio object for frequency detection
- DD4WH Convolution Filter Audio Object- truncating impulse responses
- Problems With Coding My First Teensy 4.0 Sawtooth Synth
- New to teensy audio, done some audio DIY
- Dynamic Audio Connection Bug?
- Accept audio at 16khz , 16bit via USB.
- Sound Generation with T4.0 and AudioShield RevD
- issue Using Pin Interrupt and I2C with Audio Library
- Fun with FM synthesis
- Power supply for Teensy 4 + Audio Adaptor?
- Teensy 4.0 I2S MIC Breaks FastLED
- PDM audio into the teensy
- FSK Demodulation with ADSR
- Settings waveform modulated phase.
- New Audio Object: polyBLEP Oscillator with bandlimited hard-sync
- Teensy used as MIDI receiver
- Nuts and Volts Synth
- I2S Timing Issues
- Teensy 4.1 noise when adjusting audio delay effects delay length.
- Teensy 4.0 and Talkie Library
- Need more sound sample memory
- Nonlinear Decay with Effect_Envelope?
- How could I use an array in the audio synthesis Guitar example?
- Teensy 3.6 Development System
- Handle buffer overrun in AudioOutputI2S
- Complex Signal Modulation Synthesis - new??
- Struggling with SGTL5000 Auto Volume settings
- Soundfont decoder loop/sample index
- Teensyduino: Missing Audio.h
- Code for oscilloscope audio display wanted
- Delay object and memory usage
- Noise issues and power
- Teensy 4.1 and Audio board at 96 kHz sampling rate?
- Audio Block Compatibility
- Simple Teensy MPC-like Audio Sampler Launchpad
- Multiple Teensy Devices - NAMING
- Teensy 4.0 ADC FFT - Current State
- Audio breakout-Board Rev-D Teensy 4.(0/1)
- Large wavetables using waveform object.
- Audio System Design Tool -- Save different designs--
- How to read an EXTMEM array within an audio object
- Prop Shield
- Audio Library - Output audio through SPI DAC chip.
- Teensy 4.0 doesn't enumerate as Windows 10 USB Device
- Sample alignment in I2S streams - issue still present?
- Simple Vibrato effect
- USB input to I2S output does not work for Teensy4.1
- Teensy 4.1 and DAC PCM5102a.
- WaveTable audio Datas and structures on SD ?
- Simple SD Card Read Issue
- Teensy 3.2 playFlashRaw TDM polyphony
- Using Pins for GPIO on 3.2 with Audio Adaptor
- Teensy 4.0 44.1k or 44.117k for sample rate
- Problem with numbering of objects in Audio System Design Tool
- Arbitrary sized mixers
- Wolfson WM8960 DAC
- Audio Effect Delay Pops & Clicks when changing tap times
- DSP Noise File Filter
- Alternative sine-wave oscillator object
- Teensy 4.0 Alternate I2S Pins
- Audiolib RMS/PEAK value range
- Maximum Simultaneous File Playback T4 + Audio Board
- Streaming audio through USB using Teensy 4.1 and Digilent Pmod I2S2 board
- Faster pitch detection algorithm
- Formant Isolation
- Cheap Audio output on Teensy 4.x ?
- Quick way to convert wav file audio to bytes I can paste into a header file?
- SuperCollider on Teensy
- External DSP only for fx
- Teensy 4.0 Audio Project Multiplexer Wiring Help
- well done...
- 909 drum machine using realtime dynamic sample selection?
- Understanding the Teensy Example Codes
- Can volume change percision
- Silly C++ question re: "utility/dspinst.h"
- Audio lib ..Oscillator object can it be run above 22k ?
- Pitch control of sample playback: current state of things?
- Hammond style vibrato/chorus via circuit simulation
- pro and con of teensy versions for midi/audio
- Writing Directly to SGTL5000 CODEC DACs
- Debugging tips and tricks
- MAX98390 5W DSP Audio Chip Paul has been testing?
