- Distortion from running too slow?
- New Teensy 4.1 DIY Synthesizer
- Crosstalk / noise on audio
- Audio to UDP
- periodic freeze with FastLED
- Working with New Audio Objects
- Partitoned Convolution and EXTMEM perfromance
- No PC speaker audio from Teensy 3.2
- Draw filter curves on the display
- Can DMA to i2s Data Transfer Get Corrupted by a Write to Source Location
- Audio issues with Teensy 4.1 + Audio Board
- Teensy 4 guitar/mic mixer project
- my new project - any help appreciated
- Realtime Audio Reversing - is it possible using Teensy?
- AudioPlayMemory array layout?
- audio input/output noise
- play 1/2 second of audio at x2 x3... speed
- audio clock slip
- Applying ADSR to a filter?
- Linux audio device bug? + toslink on T4
- Possible to use AudioEffectEnvelope with analogWrite()?
- SD wave playback stutters on T4.1
- CPU Cycle Counter Formula in AudioStream
- Teensymoog desktop sound module
- Audio shield noise Teensy 4.0 / Raspberry Pi 4
- Running AudioAnalyzeNoteFrequency as quickly as possible
- micGain also changes LineLevel?
- I2S slave mode
- Can the Teensy 4.0 + audio shield Rev D play wav files and record simultaneously?
- General question about ADC inputs
- Using a T4.1 to play a WAV file from the audio shield on a separate T4.0
- Basic I2S Write function
- Iconic vintage synths with Teensy?
- I2S input -> Mixer <- playSDWav: should that be possible?
- Problem with multiple WaveformMod objects for teensy polyphonic synth
- Getting the best performance with SD cards and the audio library
- Closer consecutive Midi in readings
- Teensy 4.0 I2S with 768kHz stereo with TLV320ADC6140
- Set bit in register of sgtl5000 - how?
- start wav playback at specific time
- Interfacing Line in (audio in) and line out (audio out) on Teensy 4.0
- Access to Teensy pins through Blackaddr audio board
- Teency 4.1 i2s dac reccomendation
- Getting started Teensy 4.1 and audio shield rev B
- Plans for a Basic Compressor for Audio Library?
- Wavefolder possible?
- launching sound with push button
- Problem with adapter for using a Rev. B audio shiel with a T_4.1 (for MicroDexed)
- PT8211 and Teensy 4
- Audio Adapter Mic Bias - Can It Be Disabled?
- Dynamic Audio Connection Bug? A new one!
- Wacky MIDI readings from a 4067 multiplexer, until a delay is applied.
- phase correlation meter
- Teensy 4 with Audio Sheild Makes Noise
- how about an Audio Shield Lite?
- playSdWav in for loop
- usb virtual MIDI ports
- AudioOutputI2SQuad and memcpy_tointerleaveQuad
- New project with Teensy 4.1, DAC ADC and Analogs electronic....
- problem of noob with potentiometer
- SD Socket / Footprint
- Teensy reading SPDIF and triggering 12V to activate amp
- Simple Way to add Polyphony
- Project idea (phased mic array calibration for event recording)
- scaling detected frequency range in spectrum analyzer
- teensy dub siren and delay feedback problem
- Teensy 3.2 DAC output options / ideas
- .wav to Arbitrary Waveform
- Teensy 4.0 Audio 48kHz Sample Rate
- Need help amplify Teensy 4.0 for PA sound
- read analog input from 3.5mm jack? with audio board ( with fun images!)
- Cannot get any audio from Teensy 4.1 and Rev D Audio Shield
- help for pitch lfo
- band limited waveforms
- Recording while playback
- Ferrite 600 on the audio adaptor board?
- Making Faust run on Teensy 4.0 - Programmable Audio Workshop 2020
- Stream audio to a browser
- potentiometer controller for Teensy (D&D)
- AudioEffectRectifier Causing Audio Underrun / Dropouts
- basic PCB / audioshield question - HF noise
- Issue Modifying the SimpleDrum Example - Any help appreciated
- MIDI input from sequencer (help) Teensy 4.0
- Multichannel audio over IP
- Memory allocation for short sample playback
- Teensy 4.1 Wavetable Synth
- Audio recording with teensy audio shield 4.x
- SPH0645 with Teensy 4.X Audio Board?
- Can't change 7 segment display
- T4 with Audio Shield, FIR filtering, and Nextion display
- Various I2S chips output levels, questions, and opinion on options
- Sound interface (audio from and to the teensy) and bidirectional serial
- playSdWav By Only Using Part of File Name
- Static in mic input
- setI2SFreq fails on T4.x when sampling frequency is 8000Hz
- duplicate I2S out
- Setting up custom I2S communication
- Connecting MIDI-Keyboard with Macbook using Teensy 4.0 + Audio Adaptor Board
- SGTL5000 volume(level);
- Basic I2S Input Example for T4.x
- Possible to detect pulses over an audio cable without audio board/ADC?
- stuck with polyphony (last note priority)
- problem compiling tutorial example
- Using the Teensy audio board as an effects loop bug
- "clics" when playing from SD card
- Teensy as Audio (Matrix) Mixer and ADAT convert
- Is Two TDM input data bus on a Teensy 4.1 possible?
- Software control of AudioConnection types
- Why does MIDI.read() pass MIDI from Input to Output?
- Use core adc1 instead of adc0 with AudioInputAnalog in order to make analogread ?
- I2c issues & amplitude modulation
- Crackling when Processor usage reaches 35%
- BLE I2S Teensy audio board and I2S BLE
- Audio filter
- Audio Adaptor Shield REVD Kicad Symbol and Footrpint
- freeverb noise ?
- i2s input problem on Teensy4.0 with 32-bit transfers
- Constant-Q Transform on T4 w/ Audio Shield
- set min/max frequency with AudioAnalyzeFFT1024?
- USB host mode audio
- Playing audio from PSRAM.
- Extreme audio problems when USB Serial not in use
- larger soundfonts on SD or flash memory
- Is it possible to rename the individual ports in MIDIx4 or MIDIx16 mode?
- Changing DC level freezes Teensy
- pots
- Codec recommendations please for standalone keyboard/sequencer
- T4.0 working as Quad inputs with 2 audio Shields Rev D
- Help! Tsynth / Audio board problem with lifted VGND pad
- Stereo Plate Reverb for Teensy4.x
- soundfontdecoder.exe
- Scale Volume (0-1) to Logarithmic Volume (0-1)
- The I2S INMP441 microphone and the Teensy Audio Library?
- Currently purchasable audio codecs
- Teensy LC, audio library support?
- teensy 4 issue
- SGTL5000 line-out sometimes doesn't work?
- resource for SGTL5000 methods
- multiples usbMIDI Teensy 4.1 on the same USB HUB problem
- freeverb "ringing" modulation
- Programmable guitar/microphone effect pedal
- Losing COM Serial Port when adding StreamAudio object
- Best cheap stereo headphone and line level dac?
- display spectrum with logarithmically horizontal scale
- How to reduce power supply noise
- Audio library, I2S DAC oversampling?
- TLV320AIC3110 Codec breakout
- Teensy 4.1 MQS and the ILI9341_t3 library ?
- JayShoe's Pro Audio Series - Teensy 4 ADC & DAC Audio Shield - TLV320ADC5140 PCM5242
- Bandlimited waveforms for Teensy Audio library :)
- List of supported Audio Lib Hardware
- Teensy 4.1 I2S Pins - Map to different pins?
- sgtl5000 ADC lineInLevel() Gain Control
- Using the Audio Record Queue Object to get Raw ADC Data
- Unable to use audio library for ADC input of teensy4.0
- Can Granular simulate an EH POG pedal?
- Audio Library Mixer Gain bug?
- audio block size change and AudioEffectBitcrusher issue
- Looking for a Library AUDIOSHIELD_REVD.lib
- Teensy 3.6 SoundTest and WAVPlayer works with test files but not my own
- Strange error in complilig sketch for Simplewavetable
- Teensy or Mozzi ? Don't know what to choose.
- Status of Audio Library for Teensy 4.x?
- Teensy 4 + HiFiBerry DAC
- Music installation with visual Feedback
- Custom audio object issues
- audio objects 'update' relations
- Custom resonant variable filters
- sgtl5000 Delay from ADC to DAC
- Audio Library with -fexceptions
- Hydrophone amplifier and sampling
- 8 Channel TDM Audio Test Source
- USB Audio for Teensy 4
- I need help getting Faust code to run on teensy
- Teensy 3.2 48KHz noise issue on Mac OR windows
- Synthesizing sine wave and playing it like a wave sound
- Teensy as USB Audio interface for Mic / Line in
- Teensy 3.2 PropShield no Audio
- Multi channel audio over USB
- How to chose the right speaker
- I can only program in Assembly Language - help?
- Reduce Artifacts in a Granular Synth Project?
- envelope without note off
- USB Host device powered by Teensy 3.6 host port or power rails.. which is advisable?
- Audio Sinal Inverter Using Teensy 4.1
- Voice Authentication with FFT
- OPEN SOURCE BOUNTY: volumeInput(); similar to volume();
- Control Surface with Teensy for Beginners
- ham radio DSP processor source posted on github
- Envelope Object Stops I2S Input Sound
- General guidance needed on MP3 (22.05kHz & MTP)
- Interference between SDFat/SDIO and I2S on T4.1
- Teensy 3.5/4.1 Standalone Synthesizer - Trying Modular DYI approach
- Issues playing 2 WAV files
- Implementing built-in speaker
- 12 stage Phaser effect
- Audio adaptor board - low output level after turning on SGTL5000 audio processor
- F32 Audio Spectrum/Waterfall guidance - AudioAnalyzeFFT1024_F32
- wav2sketch inside Teensyduino
- MidiSynth Wavetable Examples Don't Compile for 4.1
- Hearing I2C Transmission In Audio Output? (Teensy 4.1/3.6)
- Can't get the "guitar" example to output to USB?
- Repurposing the 1/8" jack on the audio shield to be a Line In jack
- Cannot get Teensy Audio shield line out to produce sound
- sgtl5000 32 bit ADC and DAC
- Using a "real" microphone?
- Read analog input value in Volts
- Teensy 4.x + audioboard, Microphone and speaker feedbackloop
- Resampling I2S slave inputs at the T4/ T4.1
- NLMS Audio Echo Cancellation 2016 Code Modification
- Help me decide on a DAC for a poly synth
- How does AudioSynthWaveformDc work?
- Attempting to make an internal bpm/clock
- "Plop" while using PULSE or SQUARE waveforms with envelope
- Group Multiple Audio Objects into One Class
