Teensy 3.0 pinout PDF in easy to find place?
JBeale
I left my Teensy 3 card at home, and I want to reference the pinout. There was a very nicely organized PDF showing the same image as the card, with the pinout on both sides, in one of the Kickstarter updates, but I don't remember which one, it takes a while to page through them- is there some easy-to-find place on the forum or pjrc.com proper with general T3 reference material?
Update: this is what I was looking for (www.pjrc.com/teensy/ doesn't apparently link to them.)
http://www.pjrc.com/teensy/card5a.pdf
http://www.pjrc.com/teensy/card5b.pdf
Thanks, I was just looking (again) for the same data and also wondering why it wasn't with the other Teensy pinout diagrams.
Bruce
I have a Teensy 3.1 and I see that both pin 1 and pin 5 are labelled in the pinout as "TX1", although pin 5 is much more dimly labelled. What do the dim labels mean?
That means that the pin can, given some work, be configured as an alternative pin for that signal. However, most users are likely to leave all the pin designations 'as is' and so you can likely ignore the dim label.
However, if you need to move inputs/outputs around due to pin conflicts, these are the pins that Paul has set aside as alternatives. HTH.
