Raspberry Pi and Teensy 2.0 USB Serial communication
My Raspi and my Teensy 2 work just fine together.
Do you see a /dev/ttyACM0 (or ACM1 or whatever) device on the Raspi?
What is added to dmesg when you plug in your Teensy?
What does "lsusb" say on the Raspi?
Did you set the USB type to serial on Teensy?
I see a /dev/ttyACM0 on the Raspi, I have set the teensy to serial and the onlything that happens when I "ser.readline()" is it keeps waiting and never shows anything
this is what is added to dmesg
[ 177.013019] usb 1-1.3: new full-speed USB device number 4 using dwc_otg
[ 177.116199] usb 1-1.3: New USB device found, idVendor=16c0, idProduct=0483
[ 177.116229] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 177.116246] usb 1-1.3: Product: USB Serial
[ 177.116258] usb 1-1.3: Manufacturer: Teensyduino
[ 177.116270] usb 1-1.3: SerialNumber: 12345
[ 177.197091] cdc_acm 1-1.3:1.0: This device cannot do calls on its own. It is not a modem.
[ 177.197381] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
[ 177.200509] usbcore: registered new interface driver cdc_acm
[ 177.200540] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
and the last of these is added in lsusb>
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp.
Bus 001 Device 004: ID 16c0:0483 VOTI Teensyduino Serial
