Hi all,
while I'm waiting for delivering of the teensy 3.0, I'd like to find out how can I use T3 with external power. I read some topics on this forum related to this but I didn't find the answer.
I'm going to power T3 with single Li-Ion battery (18650). As per T3 datasheet I know that I should supply 1.7 - 3.6 volts to work properly. In theory, 18650 batteries have 3.6v output, but in practice it can go up to 4.1 volts. Therefore I have some questions, please be kind to help me.
1. Can 4.1 volts destroy T3?
2. Does T3 have onboard voltage regulator? If so, which one is it? Can I use it to reduce voltage of the 18650 battery?
3. How voltage of the Teensy USB connector is converted to 3.3v to supply MCU?
Thank you.
Thank you.
