raw hid on linux
cmason
Has anyone successfully used the hid_listen RAW hid serial console on linux? I'm trying to get it to work on a raspberry pi and hot having much luck. It works great on my mac.
I've tried the stock 1.0.2-beta 9 code with -DUSB_HID and this test program.
#include <stdlib.h>
#include "avr_functions.h"
#include "elapsedMillis.h"
int main(void)
    pinMode(13, OUTPUT);
	bool blink = 0;
	while(1) {
    	Serial.println("hello");
    	Serial.flush();
    	digitalWrite(13, blink);
    	blink = !blink;
This gives this lsusb output but the hid_listen executable just says waiting... forever. The same hid_listen program compiled on the mac results in the expected hello output.
I do have CONFIG_HIDRAW=y in the kernel config. Are there other config options I need?
If someone can confirm if this works on regular desktop x86 linux, it would be most helpful.
Thanks,
-c
When you plug the Teensy in, does a new /dev/hidraw# device file appear?
Did you install the udev rules? Or just run hid_listen as root, so it always has permission to access the device.
