slurry bowl
Hello, I have been having fun using flexible LED strips with the LPD8806 chip. I am currently running them with an Arduino UNO and it works great.
I want to shrink my board down and have it be battery powered. Does the TEENSY have the ability to run on battery? If so is it also 9 V like the Arduino. Does it have Voltage out pins on it that send out a lower voltage? Which pins would a battery connect to?
Also, can the TEENSY send out data/clock pin info in the same way as an Arduino?
The strips run at 5 V. Can I use LPD8806 library like in Arduino ?
Any help or guidance much appreciated, I want to use the smallest board possible.
I know these are basic questions, so I really appreciate any help.
