View Full Version : USB HID with Teensy 3?
orvtech
01-10-2013, 09:28 AM
Friends,
I am a noob when it comes to microcontrollers and would like to test the teensy for a couple of projects that involve faking a keyboard.
I see that there are multiple versions of the Teensy, being the Teensy 2 variants the more popular. Is there a disadvantage on using the Teensy 3? does the Teensy 3 support HID (can I fake a keyboard ?).
Thanks in advance.
PaulStoffregen
01-10-2013, 11:28 AM
Both have keyboard. 3.0 is faster, but today relatively few libraries are ported. In time, 3.0 will have much more capability as more code is written and ported. 2.0 is 5 volts, 3.0 is 3.3 volts. Either could be seen as an advantage, depending on the voltage of whatever circuitry you might try connecting. Long term, most things are going to 3.3 volts.
orvtech
01-10-2013, 01:43 PM
THank you, just pulled the trigger on the 3.0
anthony keane
01-11-2013, 03:32 AM
Hi Paul,
I received my 5x 3.0 last week and wanted to jump in and play, I have downloaded the 10beta
I have been coding atmel for a while on and off (atmega128) never used Arduino
I have installed AVR-GCC in Ubuntu and the main.cpp compiles and uploades to the 3.0 and the little led does as expected, changed the delay times and still all good.
what I am hopping to use the 3.0 for is to send key presses like a usb_keyboard but I cannot get even a simple test working,
Do U have a non-Arduino .cpp that will send keys to a usb_keyboard that I can build on.
PLEASE :):)
orvtech
01-11-2013, 03:48 AM
actually that code will help me too. :)
PaulStoffregen
01-11-2013, 03:59 AM
Using Arduino, select Keyboard from Tools > USB Type. Then just use Keyboard.print("test") in your program and upload. It's really that simple.
For Teensy 3.0, you're using beta 10, not avr-gcc, right? There's a sample makefile in hardware/teensy/cores/teensy3.
