I want to make a Wii to USB converter using the teensy 3.0.
I have started with basic code from Tod E. Kurt which works fine on teensy 2.0
But reading the nunchuck on teensy 3.0 does not seem to work probably due to 32Bit which I do not understand (reading i2C seems to work but values read are wrong).
Can anyone help?
Thanks
Loic
Code below:
* NunchuckPrint
* 2007 Tod E. Kurt, http://todbot.com/blog/
* The Wii Nunchuck reading code is taken from Windmeadow Labs
* http://www.windmeadow.com/node/42
Serial.begin(19200);
nunchuck_init(); // send the initilization handshake
Serial.print ("Finished setup\n");
nunchuck_get_data();
nunchuck_print_data();
// Nunchuck functions
static uint8_t nunchuck_buf[6]; // array to store nunchuck data,
// initialize the I2C system, join the I2C bus,
// and tell the nunchuck we're talking to it
void nunchuck_init()
Wire.begin(); // join i2c bus as master
Wire.beginTransmission(0x52); // transmit to device 0x52
Wire.send(0x40); // sends memory address
Wire.send(0x00); // sends sent a zero.
Wire.endTransmission(); // stop transmitting
// Send a request for data to the nunchuck
// was "send_zero()"
void nunchuck_send_request()
Wire.send(0x00); // sends one byte
// Receive data back from the nunchuck,
int nunchuck_get_data()
int cnt=0;
Wire.requestFrom (0x52, 6); // request data from nunchuck
while (Wire.available ()) {
// receive byte as an integer
nunchuck_buf[cnt] = nunchuk_decode_byte(Wire.receive());
cnt++;
nunchuck_send_request(); // send request for next data payload
// If we recieved the 6 bytes, then go print them
if (cnt >= 5) {
return 1; // success
return 0; //failure
// Print the input data we have recieved
// accel data is 10 bits long
// so we read 8 bits, then we have to add
// on the last 2 bits. That is why I
// multiply them by 2 * 2
void nunchuck_print_data()
static int i=0;
int joy_x_axis = nunchuck_buf[0];
int joy_y_axis = nunchuck_buf[1];
int accel_x_axis = nunchuck_buf[2]; // * 2 * 2;
int accel_y_axis = nunchuck_buf[3]; // * 2 * 2;
int accel_z_axis = nunchuck_buf[4]; // * 2 * 2;
int z_button = 0;
int c_button = 0;
// byte nunchuck_buf[5] contains bits for z and c buttons
// it also contains the least significant bits for the accelerometer data
// so we have to check each bit of byte outbuf[5]
if ((nunchuck_buf[5] >> 0) & 1)
z_button = 1;
if ((nunchuck_buf[5] >> 1) & 1)
c_button = 1;
if ((nunchuck_buf[5] >> 2) & 1)
accel_x_axis += 2;
if ((nunchuck_buf[5] >> 3) & 1)
accel_x_axis += 1;
if ((nunchuck_buf[5] >> 4) & 1)
accel_y_axis += 2;
if ((nunchuck_buf[5] >> 5) & 1)
accel_y_axis += 1;
if ((nunchuck_buf[5] >> 6) & 1)
accel_z_axis += 2;
if ((nunchuck_buf[5] >> 7) & 1)
accel_z_axis += 1;
Serial.print(i,DEC);
Serial.print("\t");
Serial.print("joy:");
Serial.print(joy_x_axis,DEC);
Serial.print(",");
Serial.print(joy_y_axis, DEC);
Serial.print(" \t");
Serial.print("acc:");
Serial.print(accel_x_axis, DEC);
Serial.print(",");
Serial.print(accel_y_axis, DEC);
Serial.print(",");
Serial.print(accel_z_axis, DEC);
Serial.print("\t");
Serial.print("but:");
Serial.print(z_button, DEC);
Serial.print(",");
Serial.print(c_button, DEC);
Serial.print("\r\n"); // newline
i++;
// Encode data to format that most wiimote drivers except
// only needed if you use one of the regular wiimote drivers
char nunchuk_decode_byte (char x)
x = (x ^ 0x17) + 0x17;
return x;
Can anyone help?
Thanks
Loic
Code below:
* NunchuckPrint
int cnt=0;
cnt++;
if (cnt >= 5) {
return 0; //failure
static int i=0;
int z_button = 0;
int c_button = 0;
z_button = 1;
c_button = 1;
accel_x_axis += 2;
accel_x_axis += 1;
accel_y_axis += 2;
accel_y_axis += 1;
accel_z_axis += 2;
accel_z_axis += 1;
Serial.print("\t");
Serial.print(",");
Serial.print(",");
Serial.print(",");
Serial.print("\t");
Serial.print(",");
i++;
return x;
