Azzuro
01-14-2013, 05:55 PM
My name is Romain, i'm not a programmer, only tester for MediaPortal Team. (HTPC project)
an French Dealer ( MediaHD.fr) has lent me Adalight Ambilight "Teensy 2 + WS2801 Led 12mmBullet (+5V)" for test with MediaPortal, but Adalight is not supported by AtmoWin (work with Atmolight plugin made for MP)
i would try to use Atmoduino https://bitbucket.org/RickDB/atmoduino/overview on Teensy 2, made by an user of MediaPortal.
I have tested to flash Atmoduino on Teensy 2, with Teensyduino 1.11 (Arduino IDE 1.03) without problem for Vreify - Compil - Flash eeprom, only one issue is when Teensy reboot, Windows detect Teensy as "Unknow device", i must unplug -> plug many times, for detect it as "Abstract ... COMX"
After Many test, with Atmoduino, i have tried FastSPI example, for test if LED works with it !
and i can't turn LED ON, with "Testled" example, maybe i don't know how configure it !
and i have the same issue as AtmoDuino Flashing about "unknown device " in Windows when Teensy reboot.
i have posted an Issue on FastSPI Google code http://code.google.com/p/fastspi/issues/detail?id=26
and send email to M. Garcia, maybe Adafruit WS2801 is not supported or Teensy . ... i don't know :(
Please, Help Me ! i'm limited with programming and english
Led Stip is connected to
Data PIN : B2
Clock PIN : B1
Ground : Common GND
(+5V) directly on LED
StandTest working From Adafruit WS2801 library https://github.com/adafruit/Adafruit-WS2801-Library.
#include "SPI.h"
#include "Adafruit_WS2801.h"
Example sketch for driving Adafruit WS2801 pixels!
Designed specifically to work with the Adafruit RGB Pixels!
12mm Bullet shape ----> https://www.adafruit.com/products/322
12mm Flat shape ----> https://www.adafruit.com/products/738
36mm Square shape ----> https://www.adafruit.com/products/683
These pixels use SPI to transmit the color data, and have built in
high speed PWM drivers for 24 bit color per pixel
2 pins are required to interface
products from Adafruit!
BSD license, all text above must be included in any redistribution
MODIFICATION Romain :
Data PIN TEENSY : 2
Clocl PIN TEENSY : 1
// Choose which 2 pins you will use for output.
// Can be any valid output pins.
// The colors of the wires may be totally different so
// BE SURE TO CHECK YOUR PIXELS TO SEE WHICH WIRES TO USE!
int dataPin = 2; // Yellow wire on Adafruit Pixels
int clockPin = 1; // Green wire on Adafruit Pixels
int NumLED = 50; // Number of LED
// Don't forget to connect the ground wire to Arduino ground,
// and the +5V wire to a +5V supply
// Set the first variable to the NUMBER of pixels. 25 = 25 pixels in a row
//Adafruit_WS2801 strip = Adafruit_WS2801(25, dataPin, clockPin);
Adafruit_WS2801 strip = Adafruit_WS2801(NumLED, dataPin, clockPin);
// Optional: leave off pin numbers to use hardware SPI
// (pinout is then specific to each board and can't be changed)
//Adafruit_WS2801 strip = Adafruit_WS2801(25);
//Adafruit_WS2801 strip = Adafruit_WS2801(NumLED);
// For 36mm LED pixels: these pixels internally represent color in a
// different format. Either of the above constructors can accept an
// optional extra parameter: WS2801_RGB is 'conventional' RGB order
// WS2801_GRB is the GRB order required by the 36mm pixels. Other
// than this parameter, your code does not need to do anything different;
// the library will handle the format change. Examples:
//Adafruit_WS2801 strip = Adafruit_WS2801(25, dataPin, clockPin, WS2801_GRB);
//Adafruit_WS2801 strip = Adafruit_WS2801(25, WS2801_GRB);
strip.begin();
// Update LED contents, to start they are all 'off'
strip.show();
// Some example procedures showing how to display to the pixels
colorWipe(Color(255, 0, 0), 50);
colorWipe(Color(0, 255, 0), 50);
colorWipe(Color(0, 0, 255), 50);
rainbow(20);
rainbowCycle(20);
void rainbow(uint8_t wait) {
int i, j;
for (j=0; j < 256; j++) { // 3 cycles of all 256 colors in the wheel
for (i=0; i < strip.numPixels(); i++) {
strip.setPixelColor(i, Wheel( (i + j) % 255));
strip.show(); // write all the pixels out
delay(wait);
// Slightly different, this one makes the rainbow wheel equally distributed
// along the chain
void rainbowCycle(uint8_t wait) {
int i, j;
for (j=0; j < 256 * 5; j++) { // 5 cycles of all 25 colors in the wheel
// tricky math! we use each pixel as a fraction of the full 96-color wheel
// (thats the i / strip.numPixels() part)
// Then add in j which makes the colors go around per pixel
// the % 96 is to make the wheel cycle around
strip.setPixelColor(i, Wheel( ((i * 256 / strip.numPixels()) + j) % 256) );
delay(wait);
// fill the dots one after the other with said color
// good for testing purposes
void colorWipe(uint32_t c, uint8_t wait) {
int i;
strip.setPixelColor(i, c);
strip.show();
delay(wait);
/* Helper functions */
// Create a 24 bit color value from R,G,B
uint32_t Color(byte r, byte g, byte b)
uint32_t c;
c = r;
c <<= 8;
c |= g;
c <<= 8;
c |= b;
return c;
//Input a value 0 to 255 to get a color value.
//The colours are a transition r - g -b - back to r
uint32_t Wheel(byte WheelPos)
if (WheelPos < 85) {
return Color(WheelPos * 3, 255 - WheelPos * 3, 0);
} else if (WheelPos < 170) {
WheelPos -= 85;
return Color(255 - WheelPos * 3, 0, WheelPos * 3);
WheelPos -= 170;
return Color(0, WheelPos * 3, 255 - WheelPos * 3);
Data PIN : B2
Clock PIN : B1
Ground : Common GND
#include "SPI.h"
Data PIN TEENSY : 2
strip.begin();
strip.show();
rainbow(20);
rainbowCycle(20);
int i, j;
delay(wait);
// along the chain
int i, j;
delay(wait);
int i;
strip.show();
delay(wait);
uint32_t c;
c = r;
c <<= 8;
c |= g;
c <<= 8;
c |= b;
return c;
WheelPos -= 85;
WheelPos -= 170;
