neep
01-28-2013, 11:57 PM
I keep running into problems uploading to one of my Teensy 3s, whilst the other functions fine.
The main difference is one is built into a toy and the other is on a breadboard. I use the same USB cable and the same program, but the one on the breadboard always takes the upload while the other one doesn't.
They both have pretty much the same wiring to an SD reader and a WS2801 LED strip, although the one in the toy has the wires bundled close together, so I am thinking maybe there can be some crosstalk. Could that be it?
Sometimes it does work when I exit the IDE (beta 10), disconnect USB and do the reverse, but at some point it starts acting up again. It does show the "programming" window but then that appears to hang. In syslog there is this:
Jan 29 00:56:18 pauls-MacBook-Pro-2 [0x0-0x1c01c].com.pjrc.teensy[209]: file changed
Jan 29 00:56:18 pauls-MacBook-Pro-2 [0x0-0x1c01c].com.pjrc.teensy[209]: File "AnalogReadSerial.cpp.hex". 7812 bytes, 6% used
Jan 29 00:56:18 pauls-MacBook-Pro-2 [0x0-0x1c01c].com.pjrc.teensy[209]: remote connection opened
Jan 29 00:56:18 pauls-MacBook-Pro-2 [0x0-0x1c01c].com.pjrc.teensy[209]: remote cmd: "comment: Teensyduino 1.11 - MACOSX"
Jan 29 00:56:18 pauls-MacBook-Pro-2 [0x0-0x1c01c].com.pjrc.teensy[209]: remote cmd: "dir:/var/folders/p6/n8_p41b974qf8dzx7r_8nb2m0000gn/T/build4850910739712455861.tmp/"
Jan 29 00:56:19 pauls-MacBook-Pro-2 [0x0-0x1c01c].com.pjrc.teensy[209]: remote cmd: "file:AnalogReadSerial.cpp.hex"
Jan 29 00:56:19 pauls-MacBook-Pro-2 [0x0-0x1c01c].com.pjrc.teensy[209]: File "AnalogReadSerial.cpp.hex". 7812 bytes, 6% used
Jan 29 00:56:19 pauls-MacBook-Pro-2 [0x0-0x1c01c].com.pjrc.teensy[209]: remote cmd: "status"
Jan 29 00:56:19 pauls-MacBook-Pro-2 [0x0-0x34b34b].cc.arduino.Arduino.teensyduino[15939]: Binary sketch size: 7,652 bytes (of a 131,072 byte maximum)
Jan 29 00:56:19 pauls-MacBook-Pro-2 [0x0-0x34b34b].cc.arduino.Arduino.teensyduino[15939]: Estimated memory use: 4,044 bytes (of a 16,384 byte maximum)
Jan 29 00:56:19 pauls-MacBook-Pro-2 [0x0-0x1c01c].com.pjrc.teensy[209]: status data sent
Jan 29 00:56:19 pauls-MacBook-Pro-2 [0x0-0x1c01c].com.pjrc.teensy[209]: remote connection closed
Jan 29 00:56:19 pauls-MacBook-Pro-2 [0x0-0x1c01c].com.pjrc.teensy[209]: remote connection opened
[repeat many times]
Jan 29 00:56:26 pauls-MacBook-Pro-2 [0x0-0x1c01c].com.pjrc.teensy[209]: remote cmd: "status"
Jan 29 00:56:26 pauls-MacBook-Pro-2 [0x0-0x1c01c].com.pjrc.teensy[209]: status data sent
Jan 29 00:56:27 pauls-MacBook-Pro-2 [0x0-0x34b34b].cc.arduino.Arduino.teensyduino[15939]: Please press the RESET BUTTON on your Teensy to upload your sketch. Auto-reboot only works if the Teensy is running a previous sketch.
Jan 29 00:56:27 pauls-MacBook-Pro-2 [0x0-0x1c01c].com.pjrc.teensy[209]: remote connection closed
Pressing the reset button doesn't help either. This is really frustrating me, as I don't feel like taking the whole thing apart again. Any ideas?
[repeat many times]
