I'm trying to use the Teensy 3.0 to interface with an older keyboard using UART0. Since the Arduino libraries do not do what I want (I need very fine grain control of the UART), I have to modify the registers directly.
Anyways, my code is nearly working, but I'm having an issue getting the Freescale chip to output as MSBF rather than LSBF (Datasheet page 1062). Something I'm doing (or not doing) is forcing it in LSBF mode.
The code for the UART0 control is as follows:
Afterwards, I just write to UART0_D.
I have added a few things to mk20dx128.h which is located at Lib/mk20dx128.h
Posting all of the code would fill many pages, so to build:
This will generate a kiibohd.hex to load onto the Teensy 3. Only an arm-none-eabi installation is necessary.
// Setup the the UART interface for keyboard data input
SIM_SCGC4 |= SIM_SCGC4_UART0; // Disable clock gating
// Pin Setup for UART0
PORTB_PCR16 = PORT_PCR_PE | PORT_PCR_PS | PORT_PCR_PFE | PORT_PCR_MUX(3); // RX Pin
PORTB_PCR17 = PORT_PCR_DSE | PORT_PCR_SRE | PORT_PCR_MUX(3); // TX Pin
// Setup baud rate - 1205 Baud
// 48 MHz / ( 16 * Baud ) = BDH/L
// Baud: 1205 -> 48 MHz / ( 16 * 1205 ) = 2489.6266
// Thus baud setting = 2490
// NOTE: If finer baud adjustment is needed see UARTx_C4 -> BRFA in the datasheet
uint16_t baud = 2490; // Max setting of 8191
UART0_BDH = (uint8_t)(baud >> 8);
UART0_BDL = (uint8_t)baud;
// 8 bit, Even Parity, Idle Character bit after stop
UART0_C1 = ~UART_C1_M | ~UART_C1_PE | UART_C1_PT | UART_C1_ILT;
// Number of bytes in FIFO before TX Interrupt
UART0_TWFIFO = 1;
// Number of bytes in FIFO before RX Interrupt
UART0_RWFIFO = 1;
// TX FIFO Disabled, TX FIFO Size 1 (Max 8 datawords), RX FIFO Enabled, RX FIFO Size 1 (Max 8 datawords)
// TX/RX FIFO Size:
// 0x0 - 1 dataword
// 0x1 - 4 dataword
// 0x2 - 8 dataword
UART0_PFIFO = ~UART_PFIFO_TXFE | /*TXFIFOSIZE*/ (0x0 << 4) | ~UART_PFIFO_RXFE | /*RXFIFOSIZE*/ (0x0);
// Reciever Inversion Disabled, LSBF
UART0_S2 = ~UART_S2_RXINV | UART_S2_MSBF;
// Transmit Inversion Disabled
UART0_C3 = ~UART_S2_TXINV;
// TX Disabled, RX Enabled, RX Interrupt Enabled
UART0_C2 = UART_C2_TE | UART_C2_RE | UART_C2_RIE;
// Add interrupt to the vector table
NVIC_ENABLE_IRQ( IRQ_UART0_STATUS );
- git clone git://gitorious.org/kiibohd-controller/head.git
- cd head
- mkdir build
- cd build
- cmake ..
- make
