neep
As I've been making good progress with my LED staffs, I want to start a hoop project as well using a Teensy 3. I already found that to make it fit inside the tubing I am using I can saw off the edges of a Teensy 3, still leaving me enough copper to solder wires onto. The main problem I still have to overcome is now to connect USB to it when it's built inside a hoop. Since the micro USB connector is not facing in a direction I can get to through the side of the hoop, I need to make an extension for it.
Are there pins on the Teensy 3 that I can connect an external USB connector to? Maybe just RX/TX? Anybody knows or done this before?
