View Full Version : x-plane 10.20 64 bits
antares190
02-07-2013, 06:48 PM
Since I updated to the version 10.20RC1 of x-plane (64 bits), the TeensyControls plugin does not work anymore (i tried it on mac), and as far as I can see in the last posts of x-plane.org (http://forums.x-plane.org/index.php?showtopic=55952&&page=55) forum, the problem affects other users too.
Is there any update of the plugin planned? As far as I can understand, the new x-plane 64bits changed the plugin sdk too, and can be found here:
http://www.xsquawkbox.net/xpsdk/mediawiki/Download
and the most updated blog is probably:
http://developer.x-plane.com
Thanks,
Giovanni, a Proud Teensy owner! (http://giovannimedici.wordpress.com/crj-200-panel/)
PaulStoffregen
02-07-2013, 10:59 PM
I've added a 64 bit build of the plugin to my to-do list. Right now, there are several higher priority items on the list, so it may be a while.
Can you use the 32 bit X-Plane in the meantime?
When I do this, I'll need a few X-Plane users to test... ideally at least one person for each platform. Are you using Mac, Linux or Windows?
antares190
02-08-2013, 06:52 AM
Wow, nice! I'm on Mac (I've Teensy 2.0 ++), and I would be glad to help you. Let me know.
cluster
02-26-2013, 11:55 AM
I am also hoping and waiting for a 64bit version of the plugin ;-)
I am running X-plane on Windows 7 and using FlightSim - Controls based on Teensy 2.0++ (right now 2 boards in parallel).
If you need a tester on the Windows platform, let me know!
Kaela
02-28-2013, 09:54 AM
Add me to the tester list too please. Best regards. kS
PaulStoffregen
03-13-2013, 08:53 PM
This is completely untested..... See the readme file.
http://www.pjrc.com/teensy/beta/teensycontrols_win64_experimental.zip
Please report success or failure. If you don't know how to use this, please just wait for beta test or regular release.
gjohn
03-16-2013, 05:27 PM
I'm happy to see that You, Paul are actually working on the 64bit plugin and I'm ready for testing on my Linux platform. I'm using the Teensy 3.0 and just starting to get some of the controls, mostly rotary and switches and two Lcd-panels out of the screen down to my fingers.
Best regards. Gerald
PaulStoffregen
03-17-2013, 10:17 AM
Again, completely untested....
http://www.pjrc.com/teensy/beta/teensycontrols_linux64_experimental.zip
cluster
03-17-2013, 05:01 PM
I tested the experimental Windows plugin version on X-Plane 10.20 final 64bit
with a flight control board based on Teensy++ 2.0 (encoders, buttons, LEDs, selectors, LCD display):
Everything worked as expected, and as it does on the 32bit version!
Thank you very much Paul!
PaulStoffregen
03-18-2013, 02:03 AM
Yet again, completely untested (for mac)....
http://www.pjrc.com/teensy/beta/teensycontrols_mac64_experimental.zip
PaulStoffregen
Thanks!
Hopefully we'll get a confirmation on the Linux and Mac versions soon?
Sadly, I can't get into doing much on X-Plane right now, but it all 3 work I'll make a new release with them.
gjohn
03-20-2013, 08:53 AM
My first test on Linux with the 64bit plugin was very successful. Encoders, Leds, LCD display and Switches all work correct for me. Great work!
Are there any special functions to take a look at?
Gerald
PaulStoffregen
03-20-2013, 09:08 PM
Great. Thanks for testing.
There's nothing particularly special to test. Except for some tiny tweaks to update to 64 bits and the newer X-Plane SDK, it's pretty much exactly the same code as the 32 bit version. If it works at all, everything should be the same.
Is anyone reading this thread able to give the Mac version a try?
antares190
03-20-2013, 09:16 PM
I will come back on Friday, and will give it a try (on mac) Thank you.
antares190
03-23-2013, 02:18 PM
I gave it a try on mac x-plane 10.20r3 (MacOSX 10.8.2), MacBook Pro 13.3'' everything (LEDS, encoders, pushbuttons http://giovannimedici.wordpress.com/crj-200-panel/ ) works great; thanks!
I've only a little problem (which I believe is due to some memory problems), because sometimes, although on the Arduino console everything works great (logs every button click), the x-plane plugin doesn't link every button / encoder / LED. Maybe it is due to the number of I/O I control with only one Teensy 2.0 ++. Do you have any suggestion on that?
Thanks
// The program is used to interface a Teensy 2.0 ++ with a custom designed
// Hardware that has the same functions as the CRJ-200 Autopilot panel.
// It is meant to work with the gorgeous CRJ-200 developed by Javier Rollon
// http://www.jrollon.com
// To use this script with x-plane, you shall install Teensyduino and the
// USB Flight Sim Plugin
// http://www.pjrc.com/teensy/td_flightsim.html
// Adds the great SimLED library, developed by Jack Deeth
// Adds two libraries to control Push Buttons and Encoders
#include "SimLED.h"
#include <Bounce.h>
#include <Encoder.h>
//#include <DogLcd.h>
// LED DATAREF
// Two statements to define a LED:
// FlightSimInteger intName; defines an integer linked to a x-plane parameter
// SiMLED intNameCtr (PIN_NUM, &intName, minDetect,maxDetect);
// ~ intName : is the name of the integer connected to x-plane parameter;
// ~ intNameCtr : is a function that calls the SimLED library
// ~ PIN_NUM : is the PIN number on Teensy
// ~ minDetect : is the minimum change value which calls the SimLED function;
// ~ maxDetect : is the maximum change value which calls the SimLED function;
FlightSimInteger apLight;
SimLED apLightCtr (PIN_C6, &apLight, 1,1);
FlightSimInteger xfrLight;
SimLED xfrLightCtr (PIN_F0, &xfrLight, 1,1);
FlightSimInteger speedLight;
SimLED speedLightCtr (PIN_F2, &speedLight, 1,8);
FlightSimInteger apprLight;
SimLED apprLightCtr (PIN_F4, &apprLight, 1,1);
FlightSimInteger hdgLight;
SimLED hdgLightCtr (PIN_F6, &hdgLight, 1,1);
FlightSimInteger navLight;
SimLED navLightCtr (PIN_A0, &navLight, 1,1);
FlightSimInteger altLight;
SimLED altLightCtr (PIN_A2, &altLight, 1,1);
FlightSimInteger vsLight;
SimLED vsLightCtr (PIN_A7, &vsLight, 1,16);
FlightSimInteger fdLight;
SimLED fdLightCtr (PIN_B5, &fdLight, 1,1);
FlightSimInteger turbLight;
SimLED turbLightCtr (PIN_B2, &turbLight, 1,1);
FlightSimInteger bcLight;
SimLED bcLightCtr (PIN_B7, &bcLight, 1,1);
FlightSimInteger bankLight;
SimLED bankLightCtr (PIN_C0, &bankLight, 1,1);
//FlightSimInteger fd2Light;
SimLED fd2LightCtr (PIN_C4, &fdLight, 1,1);
// X-PLANE COMMAND AND ENCODERS DATAREF
// Hardware objects, for accessing the buttons, and rotary encoder
Bounce apEngBtn = Bounce(PIN_C7, 10); // Pushbutton on pin C6, 10ms debounce
Bounce xfrBtn = Bounce(PIN_F1, 10);
Bounce speedBtn = Bounce(PIN_F3, 10);
Bounce apprBtn = Bounce(PIN_F5, 10);
Bounce hdgBtn = Bounce(PIN_F7, 10);
Bounce navBtn = Bounce(PIN_A1, 10);
Bounce altBtn = Bounce(PIN_A3, 10);
Bounce vsBtn = Bounce(PIN_A6, 10);
Bounce fdBtn = Bounce(PIN_B6, 10);
Bounce apDiscBtn = Bounce(PIN_B4, 10);
Bounce turbBtn = Bounce(PIN_B3, 10);
Bounce bcBtn = Bounce(PIN_D7, 10);
Bounce bankBtn = Bounce(PIN_C1, 10);
Bounce fd2Btn = Bounce(PIN_C5, 10);
//ENCODERS BUTTONS
Bounce crs1syncBtn = Bounce(PIN_B0, 10);
Bounce crs2syncBtn = Bounce(PIN_A5, 10);
Bounce altsyncBtn = Bounce(PIN_C2, 10);
Bounce hdgsyncBtn = Bounce(PIN_E1, 10);
Bounce speedsyncBtn = Bounce(PIN_D5, 10);
//Bounce vssyncBtn = Bounce(PIN_C3, 10);
// ENCODERS
Encoder speedEncoder = Encoder(PIN_D0, PIN_D4);
Encoder hdgEncoder = Encoder(PIN_D1, PIN_E0);
Encoder altEncoder = Encoder(PIN_E5, PIN_D3);
Encoder vsEncoder = Encoder(PIN_D2, PIN_E4);
Encoder crs1Encoder = Encoder(PIN_E7, PIN_B1);
Encoder crs2Encoder = Encoder(PIN_E6, PIN_A4);
// X-Plane objects, Command refs and Data ref
// BUTTONS UPPER
FlightSimInteger apEng;
FlightSimInteger xfrEng;
FlightSimInteger speedEng;
FlightSimInteger apprEng;
FlightSimInteger hdgEng;
FlightSimInteger navEng;
FlightSimInteger altEng;
FlightSimInteger vsEng;
// BUTTONS LOWER
FlightSimInteger fdEng;
FlightSimInteger apDiscEng;
FlightSimInteger turbEng;
FlightSimInteger bcEng;
FlightSimInteger bankEng;
FlightSimInteger fd2Eng;
//FlightSimInteger batteryMaster;
FlightSimInteger testAllLights;
//FlightSimInteger crs2btn_A;
FlightSimInteger crs2btn_B;
FlightSimInteger crs2btn_C;
// ENCODERS
FlightSimInteger altVal;
FlightSimInteger speedVal;
FlightSimInteger hdgVal;
FlightSimInteger vsVal;
FlightSimInteger crs1Val;
FlightSimInteger crs2DHVal;
FlightSimInteger VTVal;
FlightSimInteger altsyncC;
FlightSimInteger speedsyncC;
FlightSimInteger hdgsyncC;
FlightSimInteger crs1syncC;
FlightSimInteger crs2syncC;
FlightSimInteger crs1BarosyncC;
FlightSimFloat crs1BaroVal;
// Variables used in the routine
//long encoder_prev=0; // used for detecting rotary position change
long altVal_prev=0;
//long altenc;
long hdgVal_prev=0;
//long hdgenc;
long speedVal_prev=100;
//int speedenc=0;
long vsVal_prev=0;
//int vsenc=0;
long crs1Val_prev=0;
long crs1BaroVal_prev=29.92;
// int crs1enc=0;
long crs2DHVal_prev=0;
/*int crs2enc=0;
int crs1EBtnClick=0;
int crs1EBtn_mode=0;
int crs2EBtnClick=0;
int crs2EBtn_mode=0;
long VTVal_prev=90;
int spd_val=0;
//elapsedMillis fd_click_timer; // double click timer fd
elapsedMillis inactivityTimeout;// an inactivity timeout
// SETUP runs once, when Teensy boots.
// initialize all hardware
// ENCODERS PINMODE
pinMode(PIN_D0, INPUT_PULLUP); // SPEED ENC
pinMode(PIN_D4, INPUT_PULLUP); // SPEED ENC
pinMode(PIN_D5, INPUT_PULLUP); // SPEED BTN
pinMode(PIN_D1, INPUT_PULLUP); // HDG ENC
pinMode(PIN_E0, INPUT_PULLUP); // HDG ENC
pinMode(PIN_E1, INPUT_PULLUP); // HDG BTN
pinMode(PIN_D3, INPUT_PULLUP); // ALT ENC
pinMode(PIN_E5, INPUT_PULLUP); // ALT ENC
pinMode(PIN_C2, INPUT_PULLUP); // ALT BTN
pinMode(PIN_D2, INPUT_PULLUP); // VS ENC
pinMode(PIN_E4, INPUT_PULLUP); // VS ENC
//pinMode(PIN_C3, INPUT_PULLUP); // VS BTN
pinMode(PIN_E7, INPUT_PULLUP); // CRS1 ENC
pinMode(PIN_B1, INPUT_PULLUP); // CRS1 ENC
pinMode(PIN_B0, INPUT_PULLUP); // CRS1 BTN
pinMode(PIN_E6, INPUT_PULLUP); // CRS2 ENC
pinMode(PIN_A4, INPUT_PULLUP); // CRS2 ENC
pinMode(PIN_A5, INPUT_PULLUP); // CRS2 BTN
// BUTTONS UPPER PART
pinMode(PIN_C7, INPUT_PULLUP); // AP ENG
pinMode(PIN_F1, INPUT_PULLUP); // XFR
pinMode(PIN_F3, INPUT_PULLUP); // SPEED
pinMode(PIN_F5, INPUT_PULLUP); // APPR
pinMode(PIN_F7, INPUT_PULLUP); // HDG
pinMode(PIN_A1, INPUT_PULLUP); // NAV
pinMode(PIN_A3, INPUT_PULLUP); // ALT
pinMode(PIN_A6, INPUT_PULLUP); //VS
// BUTTONS LOWER PART
pinMode(PIN_B6, INPUT_PULLUP); // FD1
pinMode(PIN_B4, INPUT_PULLUP); // APD
pinMode(PIN_B3, INPUT_PULLUP); // TRB
pinMode(PIN_D7, INPUT_PULLUP); // BC
pinMode(PIN_C1, INPUT_PULLUP); // BANK
pinMode(PIN_C5, INPUT_PULLUP); // FD2
//pinMode(6, OUTPUT);
// LEDS X-PLANE DATAREF
// Links the variables to the proper DATAREF
apLight = XPlaneRef("CRJ/autopilot/ap_eng_light");
xfrLight = XPlaneRef("CRJ/autopilot/xpr_light");
speedLight = XPlaneRef("CRJ/autopilot/spd_light");
apprLight = XPlaneRef("CRJ/autopilot/appr_light");
hdgLight = XPlaneRef("CRJ/autopilot/hdg_light");
navLight = XPlaneRef("CRJ/autopilot/nav_light");
altLight = XPlaneRef("CRJ/autopilot/alt_light");
vsLight = XPlaneRef("CRJ/autopilot/vs_light");
fdLight = XPlaneRef("CRJ/autopilot/fd_light");
turbLight = XPlaneRef("CRJ/autopilot/turb_light");
bcLight = XPlaneRef("CRJ/autopilot/bcrs_light");
bankLight = XPlaneRef("CRJ/autopilot/bank_light");
//fd2Light = XPlaneRef("CRJ/mfd/nav_source"); // Forse da mettere cmq fd
// BUTTONS X-PLANE DATAREF
apEng = XPlaneRef("CRJ/autopilot/ap_eng_button");
xfrEng = XPlaneRef("CRJ/autopilot/xpr_button");
speedEng = XPlaneRef("CRJ/autopilot/speed_button");
apprEng = XPlaneRef("CRJ/autopilot/appr_button");
hdgEng = XPlaneRef("CRJ/autopilot/hdg_button");
navEng = XPlaneRef("CRJ/autopilot/nav_button");
altEng = XPlaneRef("CRJ/autopilot/alt_button");
vsEng = XPlaneRef("CRJ/autopilot/v_button");
fdEng = XPlaneRef("CRJ/autopilot/fd_button");
apDiscEng = XPlaneRef("CRJ/autopilot/ap_disc_button");
turbEng = XPlaneRef("CRJ/autopilot/turbo_button");
bcEng = XPlaneRef("CRJ/autopilot/backcrs_button");
bankEng = XPlaneRef("CRJ/autopilot/12_bank_button");
fd2Eng = XPlaneRef("CRJ/mfd/nav_source");
testAllLights = XPlaneRef("sim/weapons/z[13]");
//batteryMaster = XPlaneRef("CRJ/syselec/main_batt");
//crs2btn_A = XPlaneRef("CRJ/autopilot/alt_sync");
crs2btn_B =XPlaneRef("CRJ/spd/sel_button");
crs2btn_C=XPlaneRef("CRJ/spd/tgt_vspds");
// ENCODER DATAREF
hdgVal = XPlaneRef("CRJ/autopilot/hdg");
altVal = XPlaneRef("CRJ/autopilot/alt");
speedVal = XPlaneRef("CRJ/autopilot/speed");
vsVal = XPlaneRef("CRJ/autopilot/verticalspeed");
crs1Val = XPlaneRef("CRJ/autopilot/crs1"); // CRS1 MODE0
crs1BaroVal = XPlaneRef("CRJ/baro/pressure"); // CRS1 MODE1 Pressure
crs2DHVal = XPlaneRef("CRJ/dh_mda_tune"); // CRS2 MODE1 DH
VTVal = XPlaneRef("CRJ/spd/tune"); // CRS2 MODE0 VT Speeds
altsyncC = XPlaneRef("CRJ/autopilot/alt_sync");
hdgsyncC = XPlaneRef("CRJ/autopilot/hdg_sync");
speedsyncC = XPlaneRef("CRJ/autopilot/knots_mach");
crs1syncC = XPlaneRef("CRJ/autopilot/crs1_sync"); // CRS1 SYNC
crs1BarosyncC = XPlaneRef("CRJ/baro/pressure_std"); // CRS1 MODE1 BARO SYNC
crs2syncC = XPlaneRef("CRJ/dh_mda_hide"); // CRS2 SYNC DH
// hdgenc = hdgVal;
//altenc = altVal;
// Invokes the SimLED setup routine
SimLED::setup();
// LOOP runs repetitively, as long as Teensy is powered up
// normally the first step in loop() should update from X-Plane
FlightSim.update();
// Update the LED STATE or enable the test all lights command,
// only when the battery Master switch is on (airplane Feed ON).
SimLED::update();
//if (batteryMaster==1)
// TEST LIGHT MODE
SimLED::lightTest(testAllLights==1);
// HDG ENCODER
// read the rotary encoder, if it's changed, write to hdgValue
// HDG ENCODER SYNC BUTTON
if ( hdgsyncBtn.update() ) {
if ( hdgsyncBtn.read() == HIGH) {
if ( hdgsyncC == 0 ) {
hdgsyncC = 1;
Serial.println("HDGSYNC!!!");
else {
hdgsyncC = 0;
// ENCODER ROUTINE
long hdgenc = hdgEncoder.read();
if (hdgenc != hdgVal_prev) {
if (hdgVal>359)
hdgVal=0;
hdgEncoder.write(0);
hdgVal_prev=0;
Serial.print("HDGVAL: ");
Serial.print(hdgVal);
Serial.print(" HDGVAL_prev: ");
Serial.println(hdgVal_prev);
if (abs(hdgenc-hdgVal_prev)>1)
if (inactivityTimeout<25)
hdgVal = hdgVal + (hdgenc - hdgVal_prev)/abs(hdgenc - hdgVal_prev)*4;
hdgVal = hdgVal + (hdgenc - hdgVal_prev)/abs(hdgenc - hdgVal_prev);
// Serial.println(altVal);
hdgVal_prev = hdgenc;
inactivityTimeout=0;
Serial.print("torno?");
Serial.println(" No");
// ALT ENCODER
// read the rotary encoder, if it's changed, write to altValue
long altenc = altEncoder.read();
if (altenc != altVal_prev) {
if (altVal<-10)
//Serial.println("OUTBOUND!!");
altVal=-10;
altEncoder.write(-10);
altVal_prev=-10;
Serial.print("ALTVAL: ");
Serial.print(altVal);
Serial.print(" ALTVAL_prev: ");
Serial.println(altVal_prev);
//Serial.print("ENCODER: ");
//Serial.println(altenc);
//Serial.print("timer: ");
//Serial.println(inactivityTimeout);
if (abs(altenc-altVal_prev)>1)
altVal = altVal + (altenc - altVal_prev)/abs(altenc - altVal_prev)*4;
altVal = altVal + (altenc - altVal_prev)/abs(altenc - altVal_prev);
altVal_prev = altenc;
//delay(50);
if ( altsyncBtn.update() ) {
if ( altsyncBtn.read() == HIGH) {
if ( altsyncC == 0 ) {
altsyncC = 1;
else {
altsyncC = 0;
// SPEED ENCODER
long speedenc = speedEncoder.read();
if (speedenc != speedVal_prev) {
if (speedVal<100)
speedVal=100;
speedEncoder.write(100);
speedVal_prev=100;
Serial.print("SPEEDVAL: ");
Serial.print(speedVal);
Serial.print("SPEEDVAL_prev: ");
Serial.println(speedVal_prev);
if (abs(speedenc-speedVal_prev)>1)
speedVal = speedVal + (speedenc - speedVal_prev)/abs(speedenc - speedVal_prev)*4;
speedVal = speedVal + (speedenc - speedVal_prev)/abs(speedenc - speedVal_prev);
speedVal_prev = speedenc;
//return;
if ( speedsyncBtn.update() ) {
if ( speedsyncBtn.read() == HIGH) {
if ( speedsyncC == 0 ) {
speedsyncC = 1;
else {
speedsyncC = 0;
// VS ENCODER
long vsenc = vsEncoder.read();
if (vsenc != vsVal_prev) {
if (vsVal>50)
vsVal=50;
vsEncoder.write(50);
vsVal_prev=50;
else if (vsVal<-40){
vsVal=-40;
vsEncoder.write(-40);
vsVal_prev=-40;
Serial.print("VSVAL: ");
Serial.print(vsVal);
Serial.print("VSVAL_prev: ");
Serial.println(vsVal_prev);
if (abs(vsenc-vsVal_prev)>1)
vsVal = vsVal + (vsenc - vsVal_prev)/abs(vsenc - vsVal_prev)*4;
vsVal = vsVal + (vsenc - vsVal_prev)/abs(vsenc - vsVal_prev);
vsVal_prev = vsenc;
//return;
delay(50);
// CRS1 ENCODER BTN ROUTINE
// First part of the script catches a click, stores the
// information in the variable crs2EBtnClick and starts a timer
// inactivityTimeout.
// Catches single click
if (crs1EBtnClick ==0)
if ( crs1syncBtn.update() )
// ROUTINE BOTTONE 2
if ( crs1syncBtn.read() == HIGH)
Serial.println("SYNC");
inactivityTimeout = 0;
crs1EBtnClick =1;
// Timer for Double Single click
if ((inactivityTimeout<200) && (crs1EBtnClick==1))
//ROUTINE DOUBLE CLICK
if (crs1syncBtn.update() )
//Serial.println("DOUBLE CLICK");
//Serial.println("SYNC");
// inactivityTimeout = 0;
if (crs1EBtn_mode==1)
// SWITCH BETWEEN TWO MODES OF SINGLE CLICK
crs1EBtn_mode=0;
crs1EBtn_mode=1;
// SINGLE BLINK OF THE LED
//digitalWrite(6, HIGH);
//delay(40);
//digitalWrite(6, LOW);
crs1EBtnClick =0;
// SINGLE CLICK ROUTINE
else if (inactivityTimeout>=200 && crs1EBtnClick==1)
// DO SINGLE CLICK MODE 1
if (crs1EBtn_mode==1) // BARO SYNC
if ( crs1BarosyncC == 0 ) {
crs1BarosyncC = 1;
//DECISION HEIGHT KNOB ON OFF
else {
crs1BarosyncC = 0;
crs1EBtnClick=0;
// DO SINGLE CLICK MODE 0
else // crs1EBtn_mode=0
if ( crs1syncC == 0 ) {
crs1syncC = 1;
else {
crs1syncC = 0;
crs1EBtnClick=0;
// ENCODER CRS1 TWO MODES
if(crs1EBtn_mode==1) // BARO
long crs1enc = crs1Encoder.read();
if (crs1enc != crs1BaroVal_prev) {
if (crs1BaroVal>31.00) {
crs1BaroVal=31.00;
crs1Encoder.write(31.00);
crs1BaroVal_prev=31.00;
else if (crs1BaroVal<27.90)
crs1BaroVal=27.90;
crs1Encoder.write(27.90);
crs1BaroVal_prev=27.90;
if (abs(crs1enc-crs1BaroVal_prev)>1)
crs1BaroVal = crs1BaroVal - (crs1enc - crs1BaroVal_prev)/abs(crs1enc - crs1BaroVal_prev)*4*0.01;
crs1BaroVal = crs1BaroVal - (crs1enc - crs1BaroVal_prev)/abs(crs1enc - crs1BaroVal_prev)*0.01;
crs1BaroVal_prev = crs1enc;
else // CRS1
if (crs1enc != crs1Val_prev) {
if (crs1Val>360)
crs1Val=0;
crs1Encoder.write(0);
crs1Val_prev=0;
if (abs(crs1enc-crs1Val_prev)>1)
crs1Val = crs1Val - (crs1enc - crs1Val_prev)/abs(crs1enc - crs1Val_prev)*4;
crs1Val = crs1Val - (crs1enc - crs1Val_prev)/abs(crs1enc - crs1Val_prev);
crs1Val_prev = crs1enc;
if (crs1Val>360)
crs1Val=0;
crs1Val_prev=0;
crs1Val = crs1Val + (crs1enc - crs1Val_prev)/abs(crs1enc - crs1Val_prev)*4;
crs1Val = crs1Val + (crs1enc - crs1Val_prev)/abs(crs1enc - crs1Val_prev);
if ( crs1syncBtn.update() ) {
if ( crs1syncBtn.read() == HIGH) {
crs1syncC = 1;
else {
crs1syncC = 0;
// CRS2 ENCODER BTN ROUTINE
if (crs2EBtnClick ==0)
if ( crs2syncBtn.update() )
if ( crs2syncBtn.read() == HIGH)
crs2EBtnClick =1;
// Second part of the script verifies the click/timer condition:
// - if elapsed time is less than 200 ms, a click was previously
// made, and another click is received, the double click routine
// cycles through the 2 modes.
// - if elapsed time is more than 200 ms, and a click was previously
// made, the single button click routine is performed.
if ((inactivityTimeout<200) && (crs2EBtnClick==1))
if (crs2syncBtn.update() )
if (crs2EBtn_mode==1)
crs2EBtn_mode=0;
crs2EBtn_mode=1;
//delay(40);
crs2EBtnClick =0;
else if (inactivityTimeout>=200 && crs2EBtnClick==1)
if (crs2EBtn_mode==1) // DECISION HEIGHT SYNC
if ( crs2syncC == 0 ) {
crs2syncC = 1;
else {
crs2syncC = 0;
crs2EBtnClick=0;
else // crs2EBtn_mode=0
//Serial.println("SINGLE CLICK");
//Serial.print("SPD_VAL=");
//Serial.println(spd_val);
// CUSTOM ROUTINE DUE TO V1 V2 VR VT
// crs2btn_B = V1 V2 VR
// crs2btn_C = TGT SPEED KNOB
// spd_val goes from 0 to 3, and is used for the encoder
// to adjust the values of V1 V2 VR and VT.
if (spd_val==0)
// CHANGES BETWEEN the other Velocities to VT
spd_val=spd_val+1;
crs2btn_C=0;
else if(spd_val==1)
// CHANGES BETWEEN VT and the other Velocities
spd_val=spd_val+1;
crs2btn_C=1;
crs2btn_B=1;
else if (spd_val<=3)
// CYCLES through V1 V2 VR
crs2btn_B=1;
spd_val=spd_val+1;
if( spd_val==4)
spd_val=0;
crs2EBtnClick=0;
//Serial.println("FineSingle2ON");
// ENCODER CRS2 TWO MODES
if(crs2EBtn_mode==1) // DH
long crs2enc = crs2Encoder.read();
if (crs2enc != crs2DHVal_prev) {
if (crs2DHVal<0)
crs2DHVal=0;
crs2Encoder.write(0);
crs2DHVal_prev=0;
if (abs(crs2enc-crs2DHVal_prev)>1)
crs2DHVal = crs2DHVal + (crs2enc - crs2DHVal_prev)/abs(crs2enc - crs2DHVal_prev)*4*10;
crs2DHVal = crs2DHVal + (crs2enc - crs2DHVal_prev)/abs(crs2enc - crs2DHVal_prev)*10;
crs2DHVal_prev = crs2enc;
//Serial.print("torno?");
//return;
//Serial.println(" No");
//delay(50);
if (crs2enc != VTVal_prev) {
if (VTVal<90)
VTVal=90;
crs2Encoder.write(90);
VTVal_prev=90;
if (abs(crs2enc-VTVal_prev)>1)
VTVal = VTVal + (crs2enc - VTVal_prev)/abs(crs2enc - VTVal_prev)*4;
VTVal = VTVal + (crs2enc - VTVal_prev)/abs(crs2enc - VTVal_prev);
VTVal_prev = crs2enc;
//return;
//delay(50);
// || BUTTONS NORMAL ROUTINES ||
// Autopilot Engage Button
if ( apEngBtn.update() ) {
if ( apEngBtn.read() == HIGH) {
if ( apEng == 0 ) {
apEng = 1;
else {
apEng = 0;
// XFR Engage Button
if ( xfrBtn.update() ) {
if ( xfrBtn.read() == HIGH) {
if ( xfrEng == 0 ) {
xfrEng = 1;
else {
xfrEng = 0;
// SPEED Engage Button
if ( speedBtn.update() ) {
if ( speedBtn.read() == HIGH) {
if ( speedEng == 0 ) {
speedEng = 1;
else {
speedEng = 0;
// APPR Engage Button
if ( apprBtn.update() ) {
if ( apprBtn.read() == HIGH) {
if ( apprEng == 0 ) {
apprEng = 1;
else {
apprEng = 0;
// HDG Engage Button
if ( hdgBtn.update() ) {
if ( hdgBtn.read() == HIGH) {
if ( hdgEng == 0 ) {
hdgEng = 1;
else {
hdgEng = 0;
// NAV Engage Button
if ( navBtn.update() ) {
if ( navBtn.read() == HIGH) {
if ( navEng == 0 ) {
navEng = 1;
else {
navEng = 0;
// ALT Engage Button
if ( altBtn.update() ) {
if ( altBtn.read() == HIGH) {
if ( altEng == 0 ) {
altEng = 1;
else {
altEng = 0;
// VS Engage Button
if ( vsBtn.update() ) {
if ( vsBtn.read() == HIGH) {
if ( vsEng == 0 ) {
vsEng = 8;
else {
vsEng = 0;
// FD Engage Button
if ( fdBtn.update() ) {
if ( fdBtn.read() == HIGH) {
if ( fdEng == 0 ) {
fdEng = 1;
Serial.println("FDENGAGE");
else {
fdEng = 0;
// APDISC Engage Button
if ( apDiscBtn.update() ) {
if ( apDiscBtn.read() == HIGH) {
if ( apDiscEng == 0 ) {
apDiscEng = 1;
else {
apDiscEng = 0;
// TURB Engage Button
if ( turbBtn.update() ) {
if ( turbBtn.read() == HIGH) {
if ( turbEng == 0 ) {
turbEng = 1;
else {
turbEng = 0;
// BC Engage Button
if ( bcBtn.update() ) {
if ( bcBtn.read() == HIGH) {
if ( bcEng == 0 ) {
bcEng = 1;
else {
bcEng = 0;
// 1/2 BANK Engage Button
if ( bankBtn.update() ) {
if ( bankBtn.read() == HIGH) {
if ( bankEng == 0 ) {
bankEng = 1;
else {
bankEng = 0;
// FD2 Engage Button
if ( fd2Btn.update() ) {
if ( fd2Btn.read() == HIGH) {
if ( fd2Eng == 0 ) {
fd2Eng = 1; // NAV1 VOR MODE
else if (fd2Eng ==1) {
fd2Eng = 2; // NAV2 VOR MODE
else if (fd2Eng ==2) {
fd2Eng = 3; // FMS MODE
else if (fd2Eng ==3) {
fd2Eng = 0; // OFF
Serial.println("NAV1 NAV2 FMS OFF");
Ros
03-31-2013, 11:59 AM
Hi everyone, any Win plugin? all I can see is Linux and Mac...
Thanks
Edit: I saw the first link is for Win thanks
