RobM
11-10-2012, 09:18 PM
I am running Ubuntu 12.10 (64 bit) with a the Teensy Loader 1.07 program.
The Loader fails to react to a Teensy 3 reset.
I am running the Teensy Loader from the arduino 1.0.2 (Beta 7)download from the Kickstarter site.
The entry /dev/ttyACM0 is being created when the Teensy is first plugged in, and this device seems to have the proper permissions.
"crw-rw-rw- 1 root dialout 166, 0 Nov 10 14:07 ttyACM0"
I have updated the /etc/udev/rules.d directory with the 49-teensy.rules file.
UBSYSTEMS=="usb", ATTRS{idVendor}=="16c0", ATTRS{idProduct}=="04[789]?", MODE:="0666"
KERNEL=="ttyACM*", ATTRS{idVendor}=="16c0", ATTRS{idProduct}=="04[789]?", MODE:="0666", ENV{ID_MM_DEVICE_IGNORE}="1"
When I push the reset button, the Teensy 3.0 resets and Halfkay is active as observed by the lsusb command.
robert@robert-Ubuntu:~$ lsusb
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 029: ID 16c0:0478 VOTI Teensy Halfkay Bootloader
Bus 002 Device 003: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 002 Device 004: ID 07d1:3c0a D-Link System DWA-140 RangeBooster N Adapter(rev.B2) [Ralink RT3072]
Bus 002 Device 005: ID 054c:00d7 Sony Corp.
Verbose output from Teensy Loader shows that it isn't receiving much:
01:57:04 PM: Teensy Loader 1.07, begin program
01:57:04 PM: File "Blink.cpp.hex". 8072 bytes, 13% used
01:57:04 PM: Listening for remote control on port 3149
01:57:04 PM: initialized, showing main window
01:57:07 PM: Verbose Info event
Unfortunately, the Teensy loader fails to respond. Can anyone help me with some some insight as to what might be wrong?
Thanks in advance.
Rob
Thanks in advance.
Rob
