Before I start talking about my issue, I wanted to thank Paul for his hard work, the Teensy 3.0 I've bought is really amazing.
So, now, my issue: I'm using Gentoo Linux, on a 64 bits computer (with a 64 bits system) and the Teensyduino installer segfaults on start. I can't get to see the installation window at all. Because the installer was compiled without the debug symbol, I was not able to get much out of GDB. I ran the installer with strace, but the output was not really helpful (I attached it to this message as 'trace.txt' though). The problem seems to be dating back from the Beta 12 installer, which segfaults as well.
It tried the 1.11 and 1.10 installers and it worked correctly (I could see the installation window at least, I did not went any further). Because I own a Teensy 3.0, I've been only been using the various beta, and I've always relied on the all-in-one tarballs so far, so it would seem I'm stuck with Beta 11 for the moment.
Do you have any other installer, or any source for the installer, so I can compile it from my machine (with debug symbols)?
Regards,
Shad
Regards,
Shad
