virtualdave
Just checking to make sure this:
http://www.pjrc.com/teensy/td_libs_Ethernet.html
...minus the teensy-to-wiznet adapter kit (assuming the pins aren't compatible with the teensy3)
will work with the teensy 3.
OR...if anyone had any suggestions for a similar, small, ethernet module to use with the teensy 3.
Much thanks!
David
Much thanks!
David
