sholland91
Hello, I am new to Teensy and have limited knowledge in programming with Arduino. I am working on a project to be able to use a Wacom digitizer an input device that stores data locally. Ideally, I want to create an image file from the wacom input data, but for now storing the data would be fine.
The digitizer would connect to the Teensy, which stores the raw USB data to an SD card. When the Teensy is plugged into the computer, I want to be able to "dump" the data and essentially play it back. This would enable me to draw on a digitizer pad and load the drawing later on my computer.
Is this feasible? can somebody point me in the right direction?
Thanks!
Thanks!
