Muesli_Reep
I'm having some trouble setting up eclipse to program my Teensy 3.
I followed the instructions I found here: Click
But I run into errors.
In HardwareSerial.h I get:
I solved this by changing line 22 in Print.h to:
removing the “=0″ from the function. Source: Click
But then I get another error in HardwareSerial.h:
I'm guessing this has to do with the pre-processor symbols? Should this be 115200?
Also if I change F_CPU from 48000000 to 96000000 do I change the CPU speed to 96MHz?
I'm using Eclipse Juno with win7
Help would be much appreciated!
The type 'HardwareSerial' must implement the inherited pure virtual method 'Print::write'
virtual size_t write(uint8_t); // = 0;
Symbol 'F_BUS' could not be resolved
