LPD8806 code on TEENSY 2.0++
slurry bowl
I have experience running LPD8806 code on an Arduino UNO.
I am trying to run the same code on my TEENSY 2.0++ and its not working, yet.
I know I need B1=clock and B2=data
Where would I assign these within the code? Here is my current code for mapping between 2 colors on a strip with 80 LEDs:
#include "LPD8806.h"
#include "SPI.h"
// Number of RGB LEDs in strand:
int nLEDs = 80;
// Chose 2 pins for output; can be any valid output pins:
int dataPin = 2;
int clockPin = 1;
// Magenta:
#define COLOR1_R 0
#define COLOR1_G 0
#define COLOR1_B 120
// Blue:
#define COLOR2_R 0
#define COLOR2_G 120
#define COLOR2_B 0
LPD8806 strip = LPD8806(80, dataPin, clockPin);
// Start up the LED strip
strip.begin();
// Update the strip, to start they are all 'off'
strip.show();
int r,g,b;
int rA, gA, bA, rB, gB, bB;
uint16_t i, j, k, l, m;
for (j=0; j < 140; j++) // fade over a range of 140 steps
// calculate pixels 0-39 color
int rA = map(j, 0, 140, COLOR1_R, COLOR2_R);
int gA = map(j, 0, 140, COLOR1_G, COLOR2_G);
int bA = map(j, 0, 140, COLOR1_B, COLOR2_B);
// calculate pixels 40-79 color
int rB = map(j, 0, 140, COLOR2_R, COLOR1_R);
int gB = map(j, 0, 140, COLOR2_G, COLOR1_G);
int bB = map(j, 0, 140, COLOR2_B, COLOR1_B);
for (i=0; i < 30; i++)
strip.setPixelColor(i,(strip.Color(rA,gA,bA) )); // set pixels 0-39
strip.setPixelColor(i + 30,(strip.Color(rB,gB,bB) )); // set pixels 40-79
strip.show(); // write all pixels to the strip
delay(1); // pause to appreciate...
int rA = map(j, 0, 140, COLOR2_R, COLOR1_R);
int gA = map(j, 0, 140, COLOR2_G, COLOR1_G);
int bA = map(j, 0, 140, COLOR2_B, COLOR1_B);
int rB = map(j, 0, 140, COLOR1_R, COLOR2_R);
int gB = map(j, 0, 140, COLOR1_G, COLOR2_G);
int bB = map(j, 0, 140, COLOR1_B, COLOR2_B);
int dataPin = 2;
int clockPin = 1;
I believe this should output the signals on pin 1 and 2, as labeled on the Arduino side of the pinout reference card that came with your Teensy++ 2.0 board (also available here).
Those pins are labeled "D1" and "D2" on the C language side of the card, and on the printing on the board itself.
ok. after consulting with some other folks on the web it seems I should expect B1 aka pin 21 and B2 aka pin 22 to be for clock and data respectively with the code below.
I am still not getting any control of my LPD8806 strip. I am also not getting pin 11 to light up with BLINK sketch, but the pin is still working and will blink a standard LED.
Anybody have any working code for LPD8806 and specific pins I could try? THANKS
#include "SPI.h"
// Example to control LPD8806-based RGB LED Modules in a strip
int nLEDs = 3;
//int dataPin = 22;
//int clockPin = 21;
// First parameter is the number of LEDs in the strand. The LED strips
// are 32 LEDs per meter but you can extend or cut the strip. Next two
// parameters are SPI data and clock pins:
//LPD8806 strip = LPD8806(32, dataPin, clockPin);
// You can optionally use hardware SPI for faster writes, just leave out
// the data and clock pin parameters. But this does limit use to very
// specific pins on the Arduino. For "classic" Arduinos (Uno, Duemilanove,
// etc.), data = pin 11, clock = pin 13. For Arduino Mega, data = pin 51,
// clock = pin 52. For 32u4 Breakout Board+ and Teensy, data = pin B2,
// clock = pin B1. For Leonardo, this can ONLY be done on the ICSP pins.
LPD8806 strip = LPD8806(nLEDs);
strip.begin();
strip.show();
// Send a simple pixel chase in...
colorChase(strip.Color(127, 127, 127), 50); // White
colorChase(strip.Color(127, 0, 0), 50); // Red
colorChase(strip.Color(127, 127, 0), 50); // Yellow
colorChase(strip.Color( 0, 127, 0), 50); // Green
colorChase(strip.Color( 0, 127, 127), 50); // Cyan
colorChase(strip.Color( 0, 0, 127), 50); // Blue
colorChase(strip.Color(127, 0, 127), 50); // Violet
// Fill the entire strip with...
colorWipe(strip.Color(127, 0, 0), 50); // Red
colorWipe(strip.Color( 0, 127, 0), 50); // Green
colorWipe(strip.Color( 0, 0, 127), 50); // Blue
rainbow(10);
rainbowCycle(0); // make it go through the cycle fairly fast
void rainbow(uint8_t wait) {
int i, j;
for (j=0; j < 384; j++) { // 3 cycles of all 384 colors in the wheel
for (i=0; i < strip.numPixels(); i++) {
strip.setPixelColor(i, Wheel( (i + j) % 384));
strip.show(); // write all the pixels out
delay(wait);
// Slightly different, this one makes the rainbow wheel equally distributed
// along the chain
void rainbowCycle(uint8_t wait) {
uint16_t i, j;
for (j=0; j < 384 * 5; j++) { // 5 cycles of all 384 colors in the wheel
// tricky math! we use each pixel as a fraction of the full 384-color wheel
// (thats the i / strip.numPixels() part)
// Then add in j which makes the colors go around per pixel
// the % 384 is to make the wheel cycle around
strip.setPixelColor(i, Wheel( ((i * 384 / strip.numPixels()) + j) % 384) );
delay(wait);
// Fill the dots progressively along the strip.
void colorWipe(uint32_t c, uint8_t wait) {
int i;
strip.setPixelColor(i, c);
strip.show();
delay(wait);
// Chase one dot down the full strip.
void colorChase(uint32_t c, uint8_t wait) {
int i;
// Start by turning all pixels off:
for(i=0; i<strip.numPixels(); i++) strip.setPixelColor(i, 0);
// Then display one pixel at a time:
for(i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, c); // Set new pixel 'on'
strip.show(); // Refresh LED states
strip.setPixelColor(i, 0); // Erase pixel, but don't refresh!
delay(wait);
strip.show(); // Refresh to turn off last pixel
/* Helper functions */
//Input a value 0 to 384 to get a color value.
//The colours are a transition r - g -b - back to r
uint32_t Wheel(uint16_t WheelPos)
byte r, g, b;
switch(WheelPos / 128)
case 0:
r = 127 - WheelPos % 128; //Red down
g = WheelPos % 128; // Green up
b = 0; //blue off
case 1:
g = 127 - WheelPos % 128; //green down
b = WheelPos % 128; //blue up
r = 0; //red off
case 2:
b = 127 - WheelPos % 128; //blue down
r = WheelPos % 128; //red up
g = 0; //green off
return(strip.Color(r,g,b));
Relatedly - I just got a Teensy++2.0 last week and will hopefully getting the FastSPI_LED2 library up and running on it over the next few days. (I decided to step away from library dev/maintenance/packaging for a few days to work on a personal project - need to remind myself that I can also be a user of my library sometimes! :)
