Bill Greiman
11-11-2012, 05:04 PM
I have been chasing several bugs with corrupted memory. It finally dawned on me that global variables were in the heap/stack area.
I added the symbol _end after the .bss section in mk20dx128.ld like this:
.bss : {
. = ALIGN(4);
_sbss = .;
*(.bss*)
. = ALIGN(4);
_ebss = .;
} > RAM
. = ALIGN(4); /* added by Bill Greiman*/
_end = . ; /* added by Bill Greiman*/
_estack = ORIGIN(RAM) + LENGTH(RAM);
And ran the following sketch:
extern unsigned long _ebss;
extern unsigned long _end;
while(!Serial) {}
delay(2000);
Serial.print("&_ebss ");
Serial.println((int)&_ebss, HEX);
Serial.print("&_end ");
Serial.println((int)&_end, HEX);
void loop() {}
The result is:
&_ebss 1FFFEB34
&_end 1FFFEB60
So something is loaded after _ebss. The problem is that _sbrk() in mk20dx128.c assumes the heap starts at _ebss.
void * _sbrk(int incr)
static char *heap_end = (char *)&_ebss;
char *prev = heap_end;
heap_end += incr;
return prev;
If I add other libraries the difference is greater.
If I add *(COMMON) to the .bss section in mk20dx128.ld like this:
.bss : {
. = ALIGN(4);
_sbss = .;
*(.bss*)
*(COMMON) /* added by Bill Greiman*/
. = ALIGN(4);
_ebss = .;
} > RAM
I get the correct result:
&_ebss 1FFFEB60
&_end 1FFFEB60
And my memory problems are fixed.
I noticed other linker scripts for CM4 add other stuff to the bss section so this fix may not be correct.
.bss : {
. = ALIGN(4);
_sbss = .;
*(.bss*)
. = ALIGN(4);
_ebss = .;
} > RAM
while(!Serial) {}
delay(2000);
void loop() {}
The result is:
&_ebss 1FFFEB34
&_end 1FFFEB60
heap_end += incr;
return prev;
.bss : {
. = ALIGN(4);
_sbss = .;
*(.bss*)
. = ALIGN(4);
_ebss = .;
} > RAM
&_ebss 1FFFEB60
&_end 1FFFEB60
