Zombie Detector
shouldice
Hi all.
I'm a software developer by profession, but I've really enjoyed what little electronics tinkering I've done. My only project so far has been using a Teensy and the USB keyboard library to make an arcade game controller. (http://andrewshouldice.com/like-honey/)
My next project is more ambitious, mostly because (correct me if I'm wrong) it involves running on external power.
Here's the idea:
I live with my girlfriend, who is really spooked by the dark in our house. I'll occasionally hear "there's no such thing as zombies" only half-jokingly muttered at night. We've got night lights, but what I'd really like to give her is 100% assurance that no zombies are within, say, 500 meters.
A small enclosure has a status LED, a two-digit seven-segment-display, and a pushbutton. Whenever the pushbutton is pressed, the status LED starts blinking, and the 7SDs play a little figure-8 "scanning" animation. After a few seconds, the status LED locks to "all clear" green, and the 7SDs happily display that there are exactly 0 zombies within 500 meters. It'd be neat if there was a little speaker crammed in there to make a cheery beep.
So, does this seem reasonable? Any gotchas leap out at anyone? Any tips for someone new to this sort of thing?
I'm pretty sure I can figure out the wiring part, possibly excepting the sound effect. (Pulse width modulation I guess? Haven't played around with that before.) It's the battery thing I'm apprehensive about.
How long should I expect 3 AA batteries to last if I follow the low power tips? (http://www.pjrc.com/teensy/low_power.html) The page seems like it's missing some parts, so I'm a little nervous about making something that'll drain power unnecessarily or melt or something.
Thanks!
Last reply dissapeared. I've read of someone doing something similar for their child. For an adult you strongly need a slight but nonzero chance of detecting zombies just far enough away that you might not be able to detect them yourself. And oh yeah, to accurately detect zombies takes a lot more than a teensy amount of horsepower. We're talking 8 cores, 32gb ram, 400+ gpu stream processors, 128gb ssd, a few terabytes of spinning disk storage. Whatever you think you can milk it for.
Seriously though, nothing you describe sounds like a battery hog. LED's for viewing in near total darkness don't require a lot of current. The audio can be a few hundred milliwatts tops, and its low duration. The thing can sleep virtually all the time. The only potential power hog is your data storage / processing requires a lot of horsepower.
Use Teensy 2.0, running directly from the batteries. In the lowest power mode, the current is under 30 uA. The batteries should last for a few years if you stay in that mode.
Then again, I need to see a datasheet for the "zombie sensor" to know how much power is uses.....
I have a stockpile of them I use for more mundane purposes. The pullup (or pulldown, if its active low) swamps the power dissipation calculation. However...
You really should also consider a companion project. RTC + Photocell + PIR. If dark, between 12am - 530am, on motion detect emit a random "Braaaaiiinnnnsssss"
random chance low enough to cast doubt on inferences of causality.
Thanks, everyone. First, replies.
Paul: Teensy 2.0 it is.
warfrat: Your motion detector idea sounds fun, but I think she'd kill me.
Now, all kinds of questions.
Interrupts: After some experimentation I've figured out how to use the INT0 interrupt on D0. Because I just want the device to sleep and have the button perform a fixed routine, I just have an empty ISR. The interrupt still wakes up my while(1) loop in main() and re-executes the routine. Comme ça:
	main(){
		// ...Setup...
		while(1){
			sleep_enable();
			sleep_cpu();
			sleep_disable();
			// ...Do something...
	ISR(INT0_vect) {
Is that pattern kosher?
"Pin change" interrupts: As above, I've got the INT0 interrupt firing when I ground D0. That sounds like a "pin change" to me, but the datasheet also talks about "pin change" interrupts as something seperate. (PCINT01, for instance) What's the difference?
Audio: I learned a bit about PWM, and got a lovely square wave coming out of a pair of headphones. PWM, it seems, is for changing the duty on the wave, not for precisely controlling the frequency. If I want to get cute and have this thing play a little tune, how can I more precisely control the frequency? I've seen the ISD1820 audio chip mentioned a few times on these forums, but I'll hold off on something that fancy for the time being. I sort of want to write a Tone(int freq, int duration) function that uses _delay_us(), but is there a better way to do this? Perhaps something asynchronous, so I'm not using the main program loop to flick the pin on and off at the right frequency?
Also, is a little piezoelectric speaker ok for this? It doesn't need to sound good, just be audible and capable of playing a few notes. (http://ca.mouser.com/Search/Product...virtualkey66500000virtualkey665-AT-1220-TT-5R)
A side note: I'm compiling a shopping cart at Mouser and I was overwhelmed with the selection they have, and not always in a good way. In the case of resistors: what am I looking for if I want "the old beige peanut" style? Is this ok? http://ca.mouser.com/Search/Product...Fvirtualkey66000000virtualkey660-MF1/4DC47R0F
Putting it all together: I found a handheld enclosure I like on Mouser (http://ca.mouser.com/Search/ProductDetail.aspx?R=1593PTBUvirtualkey54600000virtualkey546-1593PTBU), but I'm wondering how to actually organize the internals. Do I need something like this? http://ca.mouser.com/ProductDetail/Parallax/28310/?qs=sGAEpiMZZMtgbBHFKsFQghwteFaXWDFuWTbAOwjryy8= My previous project (the arcade controller, above) is an absolute nightmare on the underside, but it doesn't really matter because there's just the chip and wires going to the controls; there's no real chance for shorting. I don't imagine cramming a knot of resistors, etc. into my zombie detector box is going to work as well. Am I on the right track with that perforated board I linked to?
This is all very exciting to me.
