I had some code with delays that wasn't working quite right, so I modified the blink example to do a shorter delay:
When I hooked the output pin up to my multimeter, it said the pulse width was 3.002 ms, not ~2ms. Making the following change fixed my test:
That obviously breaks delay(0), but that's probably best handled by an early-out at the top anyway (the current code waits 1ms for delay(0)).
digitalWrite(ledPin, HIGH); // set the LED on
delay(2); // wait for a second
digitalWrite(ledPin, LOW); // set the LED off
void delay(uint32_t ms)
uint32_t start = micros();
while (1) {
if ((micros() - start) >= 1000) {
+++ ms--;
if (ms == 0) break;
--- ms--;
start += 1000;
