noiseworker
Hi all!!
I m really new with arduino coding, recently I bought a teensy++ to make my controller .
I want to learn more about coding Midi-usb with teensy but i cant found to much information by internet .
I want to know how I can run a push buttons with a led ...The problem that i hav , is that i dont know how to make that the led follow the instructions of the DAW( Ableton live) .
For example : push one one physical button assigned to rec function of ableton ...then I want that the led go to "ON position".
I used the library bunce
#include <Bounce.h>
const int channel = 1;
const int led = 13;
Bounce button1 = Bounce(1, 5); // 5 = 5 ms debounce time
const int BUTON = 1;
int val = 0;
int old_val = 0;
int state = 0;
pinMode(1, INPUT_PULLUP);
pinMode(led, OUTPUT);
pinMode(BUTON, INPUT);
button1.update();
val= digitalRead(BUTON);
if((val==HIGH) && (old_val == LOW)){
state = 1 - state;
delay(10);
old_val=val;
if(state ==1) {
digitalWrite(led, HIGH);}else{digitalWrite(led, LOW);}
The problem that I have is that when i push "stop" to ableton live with the mouse ...the led still in "ON position"
Then I have to read the information of the ableton...the led have to work following ableton software and not the
"physical button"
I think that i should use this function callback of the Midi library https://github.com/ColinHarrington/...ensy_MIDI_Callbacks/Teensy_MIDI_Callbacks.pde
But I dont know how to use ...
SORRY for my level of english !!
Thanks for advance !
#include <Bounce.h>
const int led = 13;
int val = 0;
int old_val = 0;
int state = 0;
button1.update();
state = 1 - state;
delay(10);
old_val=val;
if(state ==1) {
"physical button"
