Hi all,
I have a VST plugin and I'm building a custom controller for it using the teensy 2.0. I've managed to configure my controller as a raw HID device and in the plugin I'm able to communicate with it fine. I chose raw HID because I wanted to make connecting to the device as user friendly as possible. The problem I'm having is with latency. It seems that using raw HID,I'm not able to communicate as quickly as I can with midi.
Is there any way to configure the raw HID device to communicate faster? I don't require two way communication if that helps. Is there a different device type that might be more appropriate? Any advice would be much appreciated and thank you in advance for any assistance you can offer.
Regards,
Rob.
Regards,
Rob.
